Quote: Originally Posted by e39dream
try this. goto control panel>sounds and audio devices> pull up sounds tab. under program events highlight a sound and press the play button. search thru sounds in program events until you find the sound you don't like. once you find it use the browse button to find a .wav file you like better, select it, hit apply and close control panels. you should be able to change it, unless it is a hardware based beep, then you may be screwed.
It's not there, can't figure out what causes it
I'm sure I read a fix on here last year but I can't find it
