Go Back   MP3Car.com > Mp3Car Technical > General MP3Car Discussion
Old 04-03-2006, 09:25 AM   #16
_
Quote: Originally Posted by Caelric
I have a case made of plexiglass, and my radio reception goes to ***** when I turn on the CarPC. Additionally, my alarm won't trigger from my keyfob until the CarPC is fully shut off. So, yes, radio interference can be a problem.
Dave
the alarm thing is interesting to me....what alarm? was it professionally installed?
I've yet to run into a single issue with mine....
also, on your radio, how close is your PC located to your Radio source?
are you running a FM card on your computer or just FM from your head unit?
Jan Bennett
PLEASE do NOT PM/Email/IM me asking me to spoon feed you. Please post on the forums! Chances are, someone else has or will have the same questions.
RedGTiVR6 is offline   Reply With Quote
Old 04-03-2006, 12:18 PM   #17
Caelric's Avatar
Stock factory alarm. Not sure where the antenna/receiver for the alarm is.
The radio antenna is in the back window, part of the glass. I have my wireless antenna and gps antenna right there; I think it *might* be the gps antenna, although that is not a transmitting antenna, only recieving, the power going to it as part of the USB might be a problem.
I know the wireless is not a problem, since I disabled it, and it makes no difference.
The radio is the factory radio, and it is located in the dash, the carPC is in the trunk. Plenty of wires running everywhere around the car, though.
Next weekend, I will be doing some more troubleshooting.
2005 Infiniti G35 6MT Coupe Black/Black
Core Duo CarPC
CarDomain page
Caelric is offline   Reply With Quote
Old 04-03-2006, 12:25 PM   #18
_
are your wires run seperate?
as in power and signal wires are as far appart as they possibly can be?
Jan Bennett
Old 04-03-2006, 12:54 PM   #19
Caelric's Avatar
Which power and signal?
The reason I ask, is that no, all the wires are run together; however, every RCA cable I have is twisted pair, noise rejecting, as well as every speaker wire. Additionally, the only problem I have is with radio reception. Playing CD's on the stock CD changer, or on the carPC, playing mp3's on the PhatBox mp3 drive, or on the carPC, or just any sound in general is perfectly fine, EXCEPT for radio reception. And, when the carPC is turned off, radio reception goes back to normal.
The power cable runs from the battery via 0 gauge to a distro block in the trunk, and from the distro block to the various amps, and to my CarPC, also in the trunk. Until I installed the carPC (which came after the amp install) the radio reception was great. This is why I believe it to be a CarPC related problem, as opposed to a power/ground issue.
Dave
Core Duo CarPC
CarDomain page
Old 04-03-2006, 02:36 PM   #20
_
I understand every speaker and RCA being noise rejecting, but, that doesn't prevent it 100%.
You should never run them together with power, no matter how good they are, there will ALWAYS be a chance for interference. Different signals can cause different things to happen.
Jan Bennett
Old 04-05-2006, 06:38 PM   #21
Caelric's Avatar
Hmm, well, okay, I concede, BUT, I never had any interference when it was just the amps. Only when I added the carPC did I start getting radio interference, and only radio,m not on any other audio. So, I still seem to think that isn't the problem, although I haven't been able to discover what exactly is the problem.
Dave
Core Duo CarPC
CarDomain page
Old 04-05-2006, 08:27 PM   #22
_
well, if you do discover, be sure to post up!
Jan Bennett
FAQ: EMI / RF Interference aoLhaTer The FAQ Emporium 7 02-05-2008 12:44 PM
Question about power wire interference Mears Car Audio 9 06-09-2004 01:20 AM
Hard disk interference noise. (long) MikeHunt79 General Hardware Discussion 22 07-01-2003 07:28 PM
