Go Back   MP3Car.com > Mp3Car Technical > General MP3Car Discussion
Old 04-18-2006, 12:52 PM   #1
Touch Screen Problem
I got a lilliput (Newvision) 8" touch screen, a Dell lattitude laptop, and a car
the problem im having is that the 8" touch screen's touch function isnt working. I bought it new and it came with the software/driver disk, but still no luck in getting the touch function working with my laptop.
Im running Windows XP BTW
any help would be great
azunboy is offline   Reply With Quote
Old 04-18-2006, 06:34 PM   #2
ilyassx's Avatar
Try one of these drivers http://www.egalax.com.tw/eg/drivers.htm
The old setup http://flickr.com/photos/ilyassx
The new setup http://my.opera.com/ilyassx/albums/show.dml?id=110701
Jetway J7F2WE VIA C7 1.5 GHz
512 DDRII 533
3.5" SATA2 H.D.D 200GB
M1-ATX
ELM327MS OBDII
Creative Audigy 4
PROGRESS:[########-]90%
ilyassx is offline   Reply With Quote
Old 04-19-2006, 02:59 AM   #3
nope =/ ive uninstalled it and reinstalled it several different ways, all it does is it shows that its connected...the program detects it, but it still doesnt work
Old 04-24-2006, 05:50 PM   #4
i have the exact same problem with my brand new 7'' lilliput and i'am quite fed up with it, especially since the horrible people at extreme audio electronics (ebay seller) stopped resonding to emails and would not replace it, i would love to get it to work also, and i'am leaning towards its a touchscreen problem, if you fix yours please let me know
tymans is offline   Reply With Quote
Old 04-24-2006, 06:35 PM   #5
Fusion Brain Creator
2k1Toaster's Avatar
I know the Ex-Audio ones have that stupid seal on the bottom that when you open the case, your warranty goes with it, but If it shows up saying that it is connected, and that bubble says "new hardware installed and rdy", then the signal is getting there. I would check the insides where the touchscreen surface's ribbon cable connects. Could be loose, could be disconnected, could be missing! If you really have no warranty because they won't help you, then you have nothing to lose, but if it is still covered, try to fix it externally and then RMA. If you have tried drivers and tried different computers and don't/can't open it up, then just replace it. Just my .02...
2k1Toaster is online now   Reply With Quote
Old 04-24-2006, 10:07 PM   #6
DaveTN's Avatar
sounds like your mouse/pointer driver is overriding your touchscreen/pointer driver.
David
DaveTN is offline   Reply With Quote
Old 04-25-2006, 01:42 AM   #7
2k1Toaster's Avatar
It shouldn't override it, it should act like the 2 are 1 in a way. It doesn't know whether you moved the mouse or touched the screen, and it doesn't care, it just does what its told blindly (in essense).
I have never had anything driver related in XP become overridden. In 95/98/ME sure, but XP prettyy much got rid of that problem. I'm sure some hardware still has bumps, but tymans' screen is like mine and having the same issue.
I dunno. Could be the driver thing, but I would guess faulty panel. Could be the resistive sheet over the screen is no good.
Old 04-25-2006, 02:24 AM   #8
susuking's Avatar
check all software, install first then plug usb, still not okie , then get it changed or no warranty, then open up and check all connections. if still can't try bios setting. it happen to me once
Progress Bar: [//////////]100%
Have M10000, 40gb 2.5"hdd, i guidance, wireless,slim slot drive, delorme gps, roadrunner, liliput touchscreen, opus150w ...
all fabrication done...
susuking is offline   Reply With Quote
Old 04-25-2006, 08:42 AM   #9
got the screen new, so im sure internally its working...gonna check the cables today, thanks
any feedback info. on Dynamix 7" VGA Touch Screen TFT ??? xtreamvette LCD/Display 29 04-22-2007 04:19 PM
DWW700M touch screen problem All Road LCD/Display 0 08-02-2005 04:04 AM
Xenarc Touch screen issue with SONY T-140 Laptop riuster LCD/Display 0 07-22-2005 11:52 AM
Someone pease help me. Cd touch screen? dallasyoung General Hardware Discussion 2 12-14-2004 11:55 AM
lilliput touch screen Win XP SP2 problem? alphaforcex Software & Software Development 1 12-06-2004 03:20 AM
