Go Back   MP3Car.com > Mp3Car Technical > General MP3Car Discussion
Old 12-21-2006, 06:32 AM   #181
Quote: Originally Posted by jpk View Post
I SENT MY DVD 990 BACK because the cd stopped working after 10days.
you were warned http://www.mp3car.com/vbulletin/show...&postcount=160
hohenyi is offline   Reply With Quote
Old 12-26-2006, 07:48 PM   #182
in-367DTM
Somebody please post a review for the IN-367DTM or its siblings. I want to know:
What is the background when in radio mode? Hopefully not that God-awful blue
Can you load your own wallpaper?
How much does the faceplace go over a standard din size?
And anything else you can offer
ollicat is offline   Reply With Quote
Old 12-28-2006, 06:53 AM   #183
Well, my one has pooped as well. TV works fine, radio too, same with the memory card slot and USB but the unit won't play any discs at all. Fukcen crud!!!!
skapan is offline   Reply With Quote
Old 12-29-2006, 04:16 AM   #184
Angle settings! Is it working?
Hello ! I'm from Romania. I bought a 993 DVD and I have tried to angle it, but it hasn't worked. Could you help me? Thank you!
dorelpuiulet is offline   Reply With Quote
Old 01-03-2007, 08:10 AM   #185
Quote: Originally Posted by jhart View Post
If you wire the back sight wire to a camera's 12 volt positive cable and then connect the both of them to the rear back up lights of the vehicle, when you put the vehicle in reverse the camera will power on and the video screen will display the image as long as the cameras video input is connected to the receiver....
i had an innovatek dvd990 but when i search for a fm frequency it search with steps from .20 to .20 is that correct? i must change something to search better? is there anyone that has the manual?
thank you
mimmish1977 is offline   Reply With Quote
Old 01-04-2007, 11:16 PM   #186
dvd-386 to dvd-993
i had the 386 dvd unit and everything worked fine for a month then the dvd stopped working so i got the 993 so far so good i'm looking to add the 10.4 fip downs i got ...got them for 67.00
mr9inchez is offline   Reply With Quote
Old 01-14-2007, 08:25 AM   #187
All greetings!
If you have problems with DV-990, can write on kapriol@apollo.lv. This problem has been caused by incorrectly adjusted chip. Now we change the chip, and all works ideally. In case of need, we can send you the necessary chip. Its cost 20 $.
With respect,
SIA " Instrumentu Pasaule "
www.incaraudio.lv
Masteroff is offline   Reply With Quote
Old 01-15-2007, 06:47 AM   #188
in need of a broken 990/993
I took my DVD993 completely apart due to a reception problem with my radio. As mentioned, these are very cheap units and very poor workman ship.
My unit is fine except the radio – does anyone have one they want to get rid of that the dvd/cd doesn’t work but the radio does…. Between the two – I should be able to get one good one. I believe a DVD990 will also work for me..
Lou
steinbl is offline   Reply With Quote
Old 01-21-2007, 10:40 PM   #189
has anyone tried any of the other cheap or no brand's in dash motorized screen dvd players w. monitor? i an looking into buying one of these and if you have any experience of buying any of these no brand players can you give me advise on to buy or not. how are yours' in the long run (atleast a year). I would like for mine to last atleast for 6 months where i can sell my car. Should i buy this cheap stuff?
mr_cheap_stuff is offline   Reply With Quote
Old 01-24-2007, 01:38 PM   #190
hi,,
I am trying to install my dvd990-4 system aswell but not avail. i did a dummy run and connected all the wires before i soldered them etc and everything worked fine.i soldered them and now i have problems.the unit wont power up.i checked all the fuses and they are ok.the led security light now just flashes rather than just staying constant.does this mean anything?
themaiden is offline   Reply With Quote
Old 01-25-2007, 07:34 AM   #191
FM Tuner 0.2 to 0.2
My question is very short :
Does someone know how to change parameters of my DVD993!
Indeed, the FM tuner goes 0.2 to 0.2 !! i want it in european mode ( i.e. 0.1 to 0.1 )
Thanks for answering me !
hutche33 is offline   Reply With Quote
Old 02-20-2007, 05:32 PM   #192
I sent my dvd-990 on decmeber 6th 2006 to hong kong. It arrived in HK on the 9th December. I was told by the ebay POWER SCAMMER (mostwantedauction) that he has it and has sent it off for repair. Come january 6th i ask what is the story with the unit and when am i getting it. He explained to me to be patient cos of the christmas holidays. Now come feb 6th, 3 months later he tells me that he never got the unit saying i never sent it and i never gave him the tracking number. Emailed him and told him that hong kong post says that it is ready to pick up from the post. All lies cos i do have every email sent to him and also the tracking number. He now says it has been stolen and its not his problem. WTF??? Now feb 21 he refuses to answer any emails. Just a warning do not buy from the ebay shifty prick MOSTWANTEDAUCTION. He is based in Hong Kong.
falkna is offline   Reply With Quote
Old 02-23-2007, 01:00 PM   #193
can't we just put a new dvd laser pick-up in there?
it would save the hassle of changing the whole unit and sending it back to the retailer
ek247 is offline   Reply With Quote
Old 03-01-2007, 07:59 AM   #194
my innovatek 993 works 100 percent with no ebrake hooked up
Quote: Originally Posted by GHETTOFIED GEEK View Post
HI all I'm new here anyway's I'am considering the innovatek dvd990 and just wondering how well does it work are you guy's happy with it. Also do all of those buttons light up blue or white the buttons such as EQ,LOU,END,REW,& FWD ETC. If not all of them which buttons do light up. And did any of you get the dvd to play while the car is in drive, also did any of you get your local TV stations thru it's tunner. THANKS FOR YOUR REPLY'S.
hi all i installed a innovatek 990 in my car and the only wires i hooked up are the POWER, GROUND,IGNITION AND A YELLOW RCA VIDEO CABLE TO ME BACK HEADREST SCREENS AND I NEVER HAD A PROBLEM WITH MY HEADUNIT. IT PLAYS DVD;D AND CD,S ALL DAY ALL NIGHT NO MATTER WHAT I TURN OFF OR ON IN Y CAR AND I DID NOT HOOK UP THE E BRAKE WIRE OR THE ILLUMINATION WIRE OR THE BACKSIGHT WIRE. SO WHY IS EVERYONE HAVING A PROBLEM NOT BEING ABLE TO SEE ANY VIDEO WHEN THEY HOOK UP THESE WIRES.. LEAVE THEM DISCONNECTED AND TAPE THEM OFF. ASK ME ANY QUESTION ABOUT HOW TO GET IT TO WORK AND ILL TELL YOU. MY ONLY PROBLEM IS I CANT SEEM TO FIND THE DAMN REMOTE WIRE ON THIS RADIO AT ALL.. SO I USED THE IGNITON WIRE AS MY REMOTE AND JUST INSTALLED A CUTOFF SWITCH IN LINE WITH ALL MY EQUIPMENT.
88bonneville is offline   Reply With Quote
Old 03-01-2007, 01:34 PM   #195
It dosent have a power ant. wire?
EvilGTI is offline   Reply With Quote
DVD mp3 playback crackling barney0001 General Hardware Discussion 12 07-22-2006 10:03 PM
HELP with DVD Overhead Fabrication & Mounting! Man Ace Fabrication 47 05-13-2005 09:40 AM
MediaCar DVD RobMR2 MediaCar 1 06-04-2004 03:38 AM
Storix External USB 2.0 DVD Review VWTronics Input Devices 8 09-27-2003 07:20 PM
DVD Burners who?, what? how? sleddog4 General Hardware Discussion 6 12-01-2000 06:51 AM
