The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General MP3Car Discussion
Thread Tools Display Modes
Old 05-28-2006, 04:28 AM   #46
d_sellers1's Avatar
Vehicle: 2000 Ford Taurus & 2001 Ford Focus ZX3
My Photos: (0)
Quote: Originally Posted by ZtH01
Carefull... My screen's (Sp-716) e-brake wire gets hooked to ground. So, I have it tied in with the actual ground wire, so it works regardless of e-brake position. I think a lot of screens are this way...
-ZtH01
I have the same screen. It has the following connections: +12V, Ground, Ignition, and another Ground. I assume the second ground is supposed to go to the ground on the brake. I simply have the two ground wires connected to each other with no problems.
Legally, you cannot view full motion view from a screen that is in the view of the driver. If the screen is in the passenger visor then that one would be okay. The indash screen has the e-brake safety to make it so you can only view the view when the e-brake is applies (as other have said). If you were to take you car to a shop to get the screen installed, they would have to wire it up to the e-brake or they could get it lots of trouble.
You take the risk of getting a ticket if you're caught watching a video while driving. It shouldn't be a problem by day but at night it would be more noticeable.
Derek
Progress [||-------]
View my Worklog to see some of my progress.
Downgraded Progress - Starting with another car... 09/13/06
d_sellers1 is offline   Reply With Quote
Sponsored Links
Old 05-28-2006, 09:15 AM   #47
GHETTOFIED GEEK's Avatar
My Photos: (0)
Quote: Originally Posted by Crawfish
Thanks guys. Glad to be able to help a little bit.
As for the button to open the CD slot...it is above the volume dial at its upper right corner. It is a mechanic lock system and the way to take off the face plate is kind of old....I afraid the plasitc will be worn out if I do this often. Like I said, the build quality is average....you cannot expect it to have Sony or other bid brand's quality.
You can find pictures you need from ebay:
http://cgi.ebay.com/DV-990-IN-DASH-3...QQcmdZViewItem
Another complaint... sort of...the romote control can do a lot of things so it is not very user-friendly. Have to read mannual carefully.
THANKS A HOLE LOT, AND WHAT A GREAT REPORT ON THE DVD990...EVERYBODY LET'S GIVE IT UP FOR CRAWLFISH
LOOK OVER THERE ACROSS THE STREET QUICKLY LOCK YOUR DOORS...IT'S A BUM,IT'S A BEGGAR, IT'S A CRACKHEAD, NO HONEY IT'S JUST YOUR FRIENDLY NEIGHBORHOOD GHETTOFIED GEEK.
GHETTOFIED GEEK is offline   Reply With Quote
Old 06-01-2006, 03:06 AM   #48
My Photos: (0)
backsight... i mean back up camera
If you wire the back sight wire to a camera's 12 volt positive cable and then connect the both of them to the rear back up lights of the vehicle, when you put the vehicle in reverse the camera will power on and the video screen will display the image as long as the cameras video input is connected to the receiver....
jhart is offline   Reply With Quote
Old 06-01-2006, 09:41 AM   #49
My Photos: (0)
I haven't used Backup Camera yet...just a question: how does the Head Unit know when you put the vehicle in reverse?
Crawfish is offline   Reply With Quote
Old 06-01-2006, 10:25 AM   #50
My Photos: (0)
it doesnt know you put the car in reverse per se, it simply gets a +12 volt signal from the backup lights (which only come on when you put the car in reverse). Thats my own way of hooking it up. The other way is to spice into the electronic transmission wiring.... but i think we can just go with the first suggestion.... If you wire the power to the camera the same way, the only time the camera will come on is in reverse also. It really doesnt matter because thats the only time the dvd990 will display it anyways.
Sponsored Links
Old 06-01-2006, 10:34 AM   #51
My Photos: (0)
I see...the Backsight (+12v) wire to the Unit will get the 12v signal from Backup camera to trigger the screen display. Thanks for the information!
Old 06-01-2006, 11:34 AM   #52
GizmoQ's CarPC Specs
GizmoQ's Avatar
Vehicle: Several
My Photos: (78)
Now my question is how well does this integrate with your CarPC? I have a similar unit (actually I have just a piece of junk that I wanted to play with) its a Boss DVD-5000. I connected one of my video out lines to my WinTV composite in and created scripts and buttons on the CarPC so I can also watch whatever is playing on the external DVD through the TV function of the PC. The primary video out and audio out RCAs feed headrest screens. I've seen some nice dual zone models, too, just haven't had a chance to play with them yet. For some reason my cheapy DVD headunit has some noise bleeding into the video but it does support Dolby surround and 5.1 so my kids prefer playing videos in it rather than the CarPC.
HARDWARE: Fujitsu Stylistic 4121w/ WiFi & mini dock, Sierra Wireless Aircard 550, EXP PCMCIA Portable DVD-RW, Silabs FM, WinTV USB w/-26dB diversity antenna, XM Commander w/Timetrax USB, Delorme GPS, Saitek X-52 USB joystick, BluSoleil USB Bluetooth
GizmoQ is offline   Reply With Quote
Old 06-01-2006, 10:44 PM   #53
My Photos: (0)
Just received the package yesterday and read through the crapy manual. Here is my first impression:
1. The packaging is kind of cheap looking.
2. The Unit itself looks average. Maybe it will look nicer when lit up.
3. The manual is very simple and the wiring diagram and some info are not accurate.
4. There are actually 1 Video Out, 4 Audio Out (one for each channel), 1 Video In for Backsight (backup video camera), 1 Video In and 2 Audio In, 1 Radio Antenna In, and 2 TV antenna In (don't know why).
5. Backsight (12V) is to power the backup camera (I think). For Brake (12V), I guess we don't need to hook it up at all.
6. In manual, there is no mention of TV tuner, RDS-EON, Video In, backup camera, and system clock.
7. There is Preset EQ (Pop/Rock/Classic), but you cannot customize it. Loudness button is to boost bass, but again no customization.
8. In the manual, it says it can play DVD, but no mention of DVD-R or DVD+R.
I am awaiting my Installation kit to come in this weekend, and will update my review.
So there is no dedicated subwoofer rca outputs? Just the 2 preouts for front/rear channels?
eugenile is offline   Reply With Quote
Old 06-02-2006, 01:22 AM   #54
My Photos: (0)
Thats correct. There is NO dedicated subwoofer preout.
Old 06-02-2006, 05:49 AM   #55
My Photos: (0)
DARN! All the listings on ebay say there is. Thanks for clarifying that. That is just something I must have. I went on Innovatek's website and they have several other models that are all in on like the 990. However I can't find any place that sells them. And if I do its only the 990. This is still a good deck IMO if I wasn't so anal about the dedicated sub preout.
Old 06-02-2006, 11:48 AM   #56
My Photos: (0)
I recently bought a DVD-990 and would like to add a flip down monitor in the rear, can any of you tell me if I have to buy a particular screen for it to work with the DVD-990? Also Crawfish, thanks for the pictures and info.
breedenb is offline   Reply With Quote
Old 06-02-2006, 12:03 PM   #57
Vehicle: 1996/Dacia/1410
My Photos: (0)
Hi. I`m a newbie here and i want to buy this dvd-990 from mp3playerstore.com. But first i`d like to ask you, owners of it, to post some pics with the menu`s screen. Another problem.. does it read DivX ? Thanks you very much and pls excuse my spelling, i am from Romania.
Pitila is offline   Reply With Quote
Old 06-02-2006, 12:38 PM   #58
My Photos: (0)
We are in the same boat!
I just ordered a 9" roof mount monitor:
http://www.amazon.com/gp/product/B00...lance&n=172282
I choose 16:9 ratio because most DVDs are in that format. And having a 16:9 screen will save you some space to be blocked in the rear view mirror.
The only problem I see is that the DVD-990's own screen is 4:3 ratio but it can be configure to show 16:9. The picture will be distorted though.
Old 06-02-2006, 12:40 PM   #59
My Photos: (0)
I will scan the manual next week. But I have to say the manual was terribly written.
Old 06-02-2006, 12:42 PM   #60
My Photos: (0)
Thank you very very much Crawfish. Do you have any ideea about where to buy it to get it shiped in Europe? Cause i only find it on US sites.
Sponsored Links
vB code is On
Trackbacks are Off
DVD mp3 playback crackling barney0001 General Hardware Discussion 12 07-22-2006 09:03 PM
HELP with DVD Overhead Fabrication & Mounting! Man Ace Fabrication 47 05-13-2005 08:40 AM
MediaCar DVD RobMR2 MediaCar 1 06-04-2004 02:38 AM
Storix External USB 2.0 DVD Review VWTronics Input Devices 8 09-27-2003 06:20 PM
DVD Burners who?, what? how? sleddog4 General Hardware Discussion 6 12-01-2000 05:51 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
