The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General MP3Car Discussion
Thread Tools Display Modes
Old 06-02-2006, 12:42 PM   #61
My Photos: (0)
I have been looking at a couple different monitors also. I was curious about the 16:9 versus 4:3. It helps to know that it can be configured to 16:9 though. When do you plan to install your screen?
breedenb is offline   Reply With Quote
Sponsored Links
Old 06-02-2006, 12:51 PM   #62
My Photos: (0)
I am looking at the Innovatek IN-800bx. It can be used either with the 16:9 or 4:3 ratio. I figure that if it is the Innovatek brand it should work with hteir DVD player. Do you know anything about installing the flip down monitor?
Old 06-02-2006, 01:20 PM   #63
My Photos: (0)
Quote: Originally Posted by Pitila
Thank you very very much Crawfish. Do you have any ideea about where to buy it to get it shiped in Europe? Cause i only find it on US sites.
Go to ebay and search DV-990 or DV990 or All-in-one DVD, you will find many vendors from HongKong will ship it to you.
Crawfish is offline   Reply With Quote
Old 06-02-2006, 01:22 PM   #64
My Photos: (0)
Originally I was thinking to have the audio shop to install them. But after reading from tips over Internet, I plan to try it by myself in two weeks. All people who installed the monitor said it was NOT as hard as expected.
Old 06-02-2006, 01:29 PM   #65
Vehicle: 1996/Dacia/1410
My Photos: (0)
Man, you are right ! And thi China sellers have real cheap prices. I hope the quality is not too low...
Pitila is offline   Reply With Quote
Old 06-03-2006, 03:05 AM   #66
My Photos: (0)
dts
someone said it decodes dolby 5.1? will it decode dts?
also does this use a full usb or is it a mini usb to read flash drives?
many thanks to those who can help.
I was going to purchase a jvc avx2 unit... pyle and soundstream has one like it too.
sam604 is offline   Reply With Quote
Old 06-03-2006, 08:49 AM   #67
My Photos: (0)
I doubt it can decode 5.1 or DTS since it really just have two channels. But I will play with it to confirm.
The unit has a mini usb port, but comes with a mini usb to standard usb cable (male-to-male type though). I will not use this usb port much since it has a SD port too.
Old 06-04-2006, 09:10 PM   #68
My Photos: (0)
my 2 cents ... plus a couple of ???
Quote: Originally Posted by Jahntassa
Connect the wire labeled 'Brake 12v' to ground. You can even wire it to the black ground wire of the radio.
The reason they're only seeing video when the lights are off is because their headlight switch shows ground when the headlights are off.
If you leave the wire disconnected, you'll NEVER see video.
I just installed this unit in my Jeep this weekend. The install was easy and pretty straight forward. I agree with everyone on this board that the instructions are terrible. I originally hooked up everything but the power antenna (since i don't have this) and the "Backsight". Everything worked fine until i turned on the head lights.
Then i get this error message "Warring Please stop WAT video player"
so i opened everything up and hooked the "Backsight" to the GROUND. But I still got the same error message. Please...does anyone know how to fix this error.
Also what type of antenna do i need to purchase to get TV signals. The two inputs look like RCA cable inputs.
As far as the good and bad.
Good
The unit plays backup DVDs in DVD+R format.
The unit plays MP3 burned onto DVD. It is nice to have all of my favorite songs on one CD.
Detachable face
Better then expected quality in movie mode
Bad
The units display while on the radio is cheezy at best.
Every time the power is turned off the unit has to read the entire DVD which takes a couple of minutes
The display is fuzy while playing the CD music files (see pictures)
Manual - Learning curve - ease of use
Several people have asked for some pictures so here are mine. Hope this helps.
Loading a DVD...takes a couple of minutes
Directory of Music files on DVD
Blurry screen...impossible to read while driving. Not too bad if you get this close
Folded down to access CD/DVDs
Taking the face off
The cheese.... thought they could have done a better job on this screen. RDS only picks up the station slogan. No clock.
skyedog is offline   Reply With Quote
Old 06-05-2006, 02:59 AM   #69
My Photos: (0)
Thanks for the pics. The display looks really BAD. I think I wont buy this. In the close up pic, it looks that the pixels are huge. Is it normal to wait a couple of minutes to read the dvd?
Old 06-05-2006, 10:39 AM   #70
My Photos: (0)
DVD-990 Manual
Here you go.
Sponsored Links
Old 06-05-2006, 11:26 AM   #71
My Photos: (0)
You may try the reset button on the unit. Also "Backsight" wire has nothing to do with the ground. I just leave the Backsight and Brake wire alone and everything works.
I belive it is a mini plug. I ordered one Antena but it has only one mini plug. Maybe we need two antenas?
Good
Nice to know!
I have a 2G SD card and it scans fairly quick. I guess accessing CD/DVD is slower.
Nice setup!
Old 06-05-2006, 12:44 PM   #72
My Photos: (0)
I will try the reset button first. If that doesn't work then I will disconnect the brake and backsight lines.
I assume from your comment about the antenna that yours didn't work with just one. I have seen some online that have two mini-plus on one antenna. I wonder if that is what we need. I might stop by Hi-Fi Buys on the way home.
Anyone with ideas about an antenna please speak up.
Old 06-05-2006, 12:49 PM   #73
My Photos: (0)
When I ordered the Antena, it showed two plugs. But after it came in, there is only one plug plus leads to 12V power. I really didn't have a chance to test TV function so cannot say much.
Old 06-05-2006, 05:51 PM   #74
My Photos: (0)
Please let me know if the TV works with your antenna. I stopped by Circuit City on the way home but they didn't have anything that would have worked.
I unplugged the Brake and Backlight as you suggested and the DVD now works when the lights are on..... THANKS.
Old 06-06-2006, 10:15 AM   #75
My Photos: (0)
A better unit?
http://cgi.ebay.com/Power-Acoustik-P...QQcmdZViewItem
Do a search in ebay with the key words: 4004 DVD
Sponsored Links
vB code is On
Trackbacks are Off
DVD mp3 playback crackling barney0001 General Hardware Discussion 12 07-22-2006 09:03 PM
HELP with DVD Overhead Fabrication & Mounting! Man Ace Fabrication 47 05-13-2005 08:40 AM
MediaCar DVD RobMR2 MediaCar 1 06-04-2004 02:38 AM
Storix External USB 2.0 DVD Review VWTronics Input Devices 8 09-27-2003 06:20 PM
DVD Burners who?, what? how? sleddog4 General Hardware Discussion 6 12-01-2000 05:51 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
