Go Back   MP3Car.com > Mp3Car Technical > General MP3Car Discussion
Old 05-25-2006, 12:05 AM   #16
RawsonDR's Avatar
Quote: Originally Posted by Rocky388
It has the be the fact that not because it's running on 1 molex connector, but because it's on 1 molex connector AND going 5 feet.:
Yes - exactly.
Though that's like saying you're broke all the time because you aren't paid well enough - not because you smoke 2 packs a day. (hypothetical) Point is that both factors contribute negatively to a sensitive situation.
I never would have though 2 devices, plus a fan really wouldn't be that much of a concern.
It's funny to consider the CPU a 'device,' like the hard drive. That device alone is responsible for 5+ Amps draw from your 12V rail - that is why they made a separate connector for it to begin with. They use to just draw from the ATX connector.
RawsonDR is offline   Reply With Quote
Old 05-25-2006, 04:03 AM   #17
The Lavender Tie Just
Made It Obvious
Rafster's Avatar
Location: Bonita, CA (Hop, Skip, and a Jump from Tijuana, Mexico)
http://www.tigerdirect.com/applicati...80342&CatId=17
Acer for $399......
Oeace,
Rafster
Post # 3000
Items for Sale
PM me!! Not using new Classifieds because I don't particularly like the way it works...
http://www.speedtest.net/result/133342788.png
Rafster is online now   Reply With Quote
Old 05-25-2006, 07:56 AM   #18
Quote: Originally Posted by Rafster
Are the celeron M's really that good though? Anytime i've used a celeron it always seemed much slower, compared to a pentium.
I was considering spending the extra money and getting a pentium M, or going with an AMD..I'm not sure if it'll be worth the extra money though?
Take 2 - '03 Audi A4
macmini with an 8" widescreen (in progress)
My 2004 Ford Ranger:
14" LCD w/ custom made aluminum bezel
Completly custom computer case
status: Totaled
Rocky388 is offline   Reply With Quote
Old 05-25-2006, 03:10 PM   #19
Made It Obvious
Rafster's Avatar
It does have 1MB Cache...
Put it this way...
What are you going to be doing on your car pc that you need it to be a 2.8GHz system?
I run a PIII 700MHz laptop and I can do MP3, GPS, and Video just fine...
Are you doing anything extra that requires more power?
Peace,
Rafster
Post # 3000
Items for Sale
Old 05-25-2006, 03:26 PM   #20
Put it this way...
Peace,
Rafster
No, I agree that my system is overkill, but the 2.8 P4 was given to me...so i figured 'why not'.
In a laptop I would want more power then probably needed for a carputer, only because I would set it up so I can easily remove it from my truck, and use it inside.
Thanks for the link though..$400 is still hell of a price for a laptop...maybe I'll start reading some laptop reviews and see what's out there..
status: Totaled
Old 05-26-2006, 03:28 AM   #21
RawsonDR's Avatar
Complex answer.
A "Celeron", alternative to Pentium4, sucks in my opinion. Quite the budget CPU.
A "Celeron M", alternative to Pentium M (think Centrino) is a different story (and quite literally a completely different chip all together). The relative performance drop is much more minor, when comparing same clockspeed. Now, why would Intel release a budget CPU that doesn't drop much performance? The reason is that 1) they are usually sold with lower clock speeds so there's almost an artificial performance drop imposed and 2) many of the Pentium M's complex power saving features are disabled. Number 2 is a big one... that's what makes it a viable 'budget' CPU. In a laptop, you get a bit less performance but your battery life also drops from 4 hours to 3 hours, or 3 hours to 2 hours, or whatever. In carPC applications this should hardly matter at all. A Celeron M laptop will still draw much less power than most desktops. You can probably find comparative benchmarks on the web if you search.
I think you'd be happy with either of those or an AMD as well. AMD would be similar story - Turion would give best battery life. Athlon 64 would give better performance if clock speed was higher for same price, and Sempron would still give decent performance and be cheaper.
Old 05-26-2006, 03:44 AM   #22
Made It Obvious
Rafster's Avatar
Quote: Originally Posted by RawsonDR
Complex answer.
+ Again, it's 1.5GHz....
What are you gonna be doing with this thing? Editing video? WHy do you need a SCREAMING fast machine... 1.5GHz is good for almost anything these days....
Peace,
Rafster
Post # 3000
Items for Sale
Old 05-26-2006, 09:44 PM   #23
Complex answer.
thanks for the reply, thats exactly the answer I was looking for. Through my experiences, like you said, celeron sucks compared to pentium, and I was wondering if it was the same for the M's.
..anyway...I ran a seperate set of wires to power the CPU, and still it locked up. After some troubleshooting and testing, I saw that even though the molex connector that went from the PSU to the HDD was connected all the way, the slightest tap would make the harddrive click (I even put a zip-tie around the connectors, thinking it was just getting loose...but still no luck) So, I cut the molex connector off and spliced the wires together. Works wonderfully now.
status: Totaled
Old 05-27-2006, 04:27 AM   #24
Made It Obvious
Rafster's Avatar
Problem solved then?
Peace,
Rafster
Post # 3000
Items for Sale
Old 05-27-2006, 02:07 PM   #25
Peace,
Rafster
Seems like it. It's been working with no problems at all since 2 nights ago.
..but even though, I think eventually I'd like to switch over to a laptop based system..
I read in another thread that you're thinking of switching from your laptop to a desktop (or similar?) system? Any particular reason for that?
status: Totaled
Old 05-27-2006, 04:27 PM   #26
Made It Obvious
Rafster's Avatar
Well... it's just the fact that it's so hard to upgreade the laptops, you're kind of stuck with what you have... the only thing you can upgrade is the RAM and HD...
In my case, running a PIII 700 is fine for right now, but probably in a little bit, I'll need something a little bit faster...
Also, it's a pain in the *** to reach under my passenger seat and turn the thing on each time I want to use it...
Peace,
Rafster
Post # 3000
Items for Sale
Close Buttons and Embedding ? RPM_VR4 Centrafuse 1 03-17-2006 11:22 AM
RR doesnt unload apps on close Mad Ad Road Runner 1 07-15-2005 07:03 PM
Close up pics Moneyfink Power Supplies 5 07-09-2005 11:19 PM
how close can screen be to subs (magnet)? CrazyModGSR LCD/Display 4 06-16-2005 07:21 AM
Subwoofer Placement-magnets too close? ddt General MP3Car Discussion 8 03-23-2003 01:49 PM
