Go Back   MP3Car.com > Mp3Car Technical > General MP3Car Discussion
Old 07-02-2006, 03:36 PM   #1
Unhappy Totally dissapointed with my carputer!
I installed my carputer over the weekend and I feel like it was a huge waste of money. I'm hoping someone here can help me fix some of the issues.
1. When I turn on the car, nothing happens. I have to jumpstart the computer to get it to come on. And when I turn off the car, the speakers shut off but the computer and screen stay on. And when I force it to hibernate, it works but the fan keeps spinning. I guess that's normal, but when I turn off the car and come back to it later, the fan is off and I have to cold boot it again. I should mention that I bought a stereo harness for my car, plugged it into the stock harness, and wired all the battery/switched/ground/speakers into that. For some reason these idiots made the switched red and constant yellow but that's a different story. Could it be that switched wire is not working properly? - [FIXED]
2. The viewing angle on the screen is horrible! When I sit in the driver's seat, I can't see anything. All the dark colours invert to light colours and I can't even tell which video I'm playing. And I have to lean over to the middle of the car to see the GPS. Plus, sunlight doesn't just make it unreadable, I can't even tell if the screen is on or off, it's ridiculous. Fixed this by turning up the brightness on the screen. - [FIXED]
3. When the amp comes on after the 5 second delay, it makes a loud popping noise in the speakers and then hisses until Windows boots up. Then it sounds normal. I had a ground loop but fixed that with an isolator. - [FIXED]
4. I still have iGuidance loading outside my skin. Sometimes it'll load but just be layered over top of the skin as its own application. But most of the time the GPS area of the skin will just be gray and it'll pop up for a second with the OK/Cancel box and when that dissapears, I'm just left with the gray. I have to keep fiddling back and forth between the different screens and eventually it'll load properly, menubarless and big buttons and all. - [TEMPORARY FIX]
5. When I first boot RoadRunner and hit volume up or down, it automatically brings the volume to 0. I then have to hit up a whole bunch of times to get it back where I want it but if I hit down in the first few seconds, it brings it right back to 0 again. - [FIXED]
6. When the woman is telling me to turn in iGuidance, she's way too loud. I want her to be the same volume as the music prior to the music being turned down. I'm pretty sure this is in the General.ini file so I'll find it. - [FIXED]
Please help me guys, don't make me regret my biggest project!
EDIT - 1, 2 and 6 have been fixed. And here is a link to the near finished project - http://mp3car.com/vbulletin/showthread.php?t=81109
Ampie Case
2.5" Hard Drive 80GB Toshiba 5400rpm
Kingston 512 MB DDR RAM PC3200
Xenarc 700TSV - VGA Monitor
VIA EPIA M10000 Mini-ITX Mainboard
M1-ATX 90 Watt - Smart Power Supply
2005 Honda Civic
Maheriano is offline   Reply With Quote
Advertisement Sponsored links
Old 07-02-2006, 03:49 PM   #2
Not a lot that can be done about the sun hitting the display I'm afraid.
I've only just recently seen some pictures of the Xenarc (I think they're all universally bad to be honest) and I was hoping it would be equivalent to an Alpine or Pioneer touchscreen, but it's terrible. Your only solution really is a transflective upgrade/screen - which, unfortunately, is quite expensive at the moment.
Sounds like you have the M1-ATX misconfigured if its not automatically powering on the system.
You have to expect teething problems to begin with to be honest. Expecting it to just drop in like any aftermarket system is a fallacy really.
Durzel is offline   Reply With Quote
Old 07-02-2006, 03:57 PM   #3
these are all things that can be sorted out
1. like durzel said you're psu is probably not configured/wired properly if its not turning you pc on.
2. most screens aren't that great, especially in the sun, can you improve the viewing angle/screen position?
3. look into having the amp comes on only when windows is loaded
5. how about not using roadrunner? there are plenty of frontends out there. i use Mobile Impact and love it
My install... check it out!
www.mp3car.com/vbulletin/showthread.php?t=56599
GreenBeast is offline   Reply With Quote
Old 07-02-2006, 04:12 PM   #4
DJiK's Avatar
For #6:
Open iGuidance.
There's a yellow speaker icon in the top-left corner of the window.
Click on that.
Then bring the volume slider down to about 50% and press 'Test'.
Fiddle with the slider.
For Sale: Carputer (CarPC) & RCA Y-Adapter
Newsflash: Take a look at my unsold stuff above, thanks!
Up Next: Make an OBD to Serial cable & Redo the "MMI buttons"
DJiK is offline   Reply With Quote
Old 07-02-2006, 04:14 PM   #5
With the screen, the sun isn't a huge bother. It's mostly the viewing angle, because I can't even use my screen in the nighttime. And I don't want to tilt it towards me because when I have passengers, their duties are to hold the wheel while I eat, answer my phone/email and work the music. They're the DJ so they have to be able to see it as well.
How do I change it so the amp comes on after Windows is loaded? I suppose that'll be less of a problem once I get the hibernation working properly.
And lastly, here is how I have the M1 hooked up. The three thicker wires, constant/switched/ground are hooked up like so, and they all go to their corresponding wires in the harness behind the screen. The constant and ground have to working (I guess) since I can jumpstart it with the key on. I haven't tried with the key off though.
red = +
white = SW
black = -
And I cut the black wire on the middle J2 jumper so it wouldn't blow the PSU. I read in another thread this was a common problem with the M1.
Ampie Case
2005 Honda Civic
Old 07-02-2006, 04:27 PM   #6
-zip-'s Avatar
Congrats on the install, the problems you have can be over come stick with it. Only your question #2 strikes as odd. It takes a lot of time to get it just right, the install is just the beginning.
You can search, most of the answers you are looking for have already been addressed.
Carputer
Installed Since April 2, 2005
Intel D201GLY|Fusion Brain|Audigy2 NX||ODBPros ODBII|Engenius362ext |Motorized lilli|GPS Rikaline 6010|Opus 150|Powermate|Ergonomic Touchpad|
Sound Stage
Eclipse CD8455|MTX TA3404+421D|Infinity Comps|ID 12" Sub
-zip- is offline   Reply With Quote
Old 07-02-2006, 05:23 PM   #7
v8 scimitar's Avatar
#1 I agree you either dont have it wired right or the jumpers arent set right
#5 map the volume control to master volume and not all lines like it is set right now (This is in RRconfig) its probably loosing its setting on boot because your PC is basically crashing out when the power supply cuts it dead.
Also sounds like you are going into standby and not hybernate. In hybernate nothing is left powered on the PC as it writes everything to disk and shuts down then on boot picks the system state back up off the disk. When the PC is off you can completely disconect it from all power and it will still resume normally from hybernate. In standby the system goes into a low power mode but the system state is still kept in the ram so it uses power and flatens the battery hence when you come back to the car the PC is dead because the M1 has done its job and cut power when it saw the battery voltage drop. Many mobos still keep the fans running in this state which is stupid but there you go thats what the manufacturers do. This is usually quite often the case with the PSU fan so if your running a case fan off the M1 it wont go off in standby.
v8 scimitar is offline   Reply With Quote
Old 07-02-2006, 05:44 PM   #8
yrean's Avatar
it might not be your ps. check under your control panel. power options. advanced. and there will be a box that says when power button is pressed. make sure it says hibernate instead of do nothing.
not sure about having the amp wait to turn on. I have an M2 and theres a pin to connect the remote for the amp. it waits a few seconds before the amp kicks on.
and for having it power up at start up. theres 2 plugs wired in series. in one you plug in your power switch. in the other you plug in a 2 pin connector that goes to your motherboard. that way the PS will turn on the pc, or the switch will if you have to use one.
MII12000 | 512MB PC3200 | 60GB 2.5" Samsung
M2-ATX 160W PS | SlotLoad DVD/CDRW | BU353 GPS
7" Lilliput 619 | WinTV | WIFI | Bluetooth
Audigy2 ZS | HQCT | Kyocera KR1 Mobile Router(3G)
Roadrunner | LSXvoid | IGuidance 3
My Worklog
yrean is offline   Reply With Quote
Old 07-02-2006, 06:15 PM   #9
I'm not understanding this. I have the M1 as pictured above. It's got the red/white/black wires in the correct positions on the PSU and wired correctly to the vehicle's wiring harness. I don't know what else it could be, it's a simple wiring setup. The ATX cable is 2 way right? It plugs to the PSU and then to the motherboard, could it be backwards? I didn't think it mattered. But what do you mean by the 2 plugs wired in series? What I just mentioned is all I have, there's nothing connected to the power/ground pins on the board. Just the three wires from the vehicle harness to the PSU and then the ATX from the PSU to the mainboard.
Ampie Case
2005 Honda Civic
Old 07-02-2006, 07:12 PM   #10
_
I'm sorry, but to simply install this and expect it to work 100% immediately means that you went into this not fully understanding what you were getting into. All of the things that you mentioned are normal, especially for a first install.
Take a few deep breaths, take your time, and think it all out. One problem at a time.
Once you get them sorted out, you will wonder how you ever lived with a normal HU in the first place.
I promise!
Jan Bennett
PLEASE do NOT PM/Email/IM me asking me to spoon feed you. Please post on the forums! Chances are, someone else has or will have the same questions.
RedGTiVR6 is offline   Reply With Quote
Old 07-02-2006, 07:21 PM   #11
Neither darque nor pervert
DarquePervert's Avatar
You should have a 2-wire cable going from the M1ATX to the power button headers of your motherboard, which initiates the soft power-on.
You didn't mention that specifically with your details about wiring, so I figured I'd ask....
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 07-02-2006, 07:34 PM   #12
UWAHHHHHHH? I'll have to rummage through the packaging I got with the system but I never seen that. Not sure if the picture above is showing up for anyone else but that's exactly how I have mine connected except I cut that one black wire on the J2. There's some sort of wire to go to the power/ground pins? Where on the M1 does it connect? We may be a whole lot closer, thanks, Perv!
Ampie Case
2005 Honda Civic
Old 07-02-2006, 07:45 PM   #13
Calm
Down
Or
Get
A
2
Week
Vacation
-Love
The
Forum
Policeman
Wiredwrx's Avatar
First of all, you mentioned that you used the wiring from a harness for your stereo, that is a NO NO.
You need to run a dedicated wire to your battery for constant power, and then a seperate wire from a switched power source (which could be from the radio harness if you like).
Make sure that you have constant power on the constant wire, and switched on the switched wire. CHECK THE MANUAL FOR THE PROPER COLOR, since just assuming that red is constant, and yellow is switched MAY be incorrect. If you switch them around accidentally the unit might work, but it won't work correctly, and could cause such things as improper shutdown and startup. And assuming that the wires are connected correctly because" you can jump start it" is plain wrong. Oh ya, what do you mean by "Jump Start it"
Thanks for the picture of your PS, but it doesn't show a darn thing about what wires go where. And yes, that was sarcastic.
ALso, the unit should have several jumpers that set how the unit operates. Such things as how long till the shutdown and startup commands are sent to the MB after power on and power off of the switched wire, how long till hard off (that means that the M1 turns off all power to the MB, since in order to shutdown properly after you shut off the car, the M1 needs to power the MB for some time) and things like that.
Check all the wiring, make sure the wire from M1 to the MB power switch header is connected to the right pins, and check the jumper settings.
Good luck,
Michael
...I love the French language...especially to curse with...Nom de Dieu de putain de bordel de merde de saloperies de connards d'enculés de ta mère. You see, it's like wiping your *** with silk, I love it. www.yellinlawoffice.com
Wiredwrx is offline   Reply With Quote
Old 07-02-2006, 07:48 PM   #14
Calm
Down
Or
Get
A
2
Week
Vacation
-Love
The
Forum
Policeman
Wiredwrx's Avatar
Ummm, in your picture, you have TWO 2 conductor cables leaving the PS. Where are they going to if at least one of them is NOT going to the MB.
Michael
Old 07-02-2006, 07:58 PM   #15
Why is this? The wire from the wire harness is a constant battery wire unless they have some sort of built in wierdness for no reason. But the wire says BATTERY/CONSTANT right on the jacket. I'm not dissagreeing with you, just trying to understand where I'm confused.
I can clear this up.
- I have the wire coming from the + on the M1 and running through the case harness following the same line right to the BATTERY/CONSTANT wire in the vehicle harness.
- I have the wire coming from the - on the M1 and running through the case harness following the same line right to the GND wire in the vehicle harness.
- I have the wire coming from the SW on the M1 and running through the case harness following the same line right to the SWITCHED wire in the vehicle harness.
So that should eliminate any improper wiring possibilities. I just used colour earlier to prevent confusion.
I mean I can use a screwdriver to touch the power/ground pins together and make the computer start up. As if I had pushed a power button that was connected to them. So that means it's getting constant power and it's grounded.
In the hopes of upsetting you more, that's not even my PSU, I stole the picture from another thread! Just messing with you. I really did though, but mine looks exactly like that so it's okay to use it. There's honestly nothing different about mine except that J2 wire I cut.
Good luck,
Michael
I think this last part is where I'm failing. I never seen nor heard of any wire that goes from the M1 to the power pins. Are you guys messing with me? I never changed any jumper settings and I definitely never seen any wire like this. I have nothing connected to my power/ground pins which might be causing the problem. Anyone have more detail or pictures of this? I'm going to check the online manual of both the M1 and M10000 to see if they mention it.
Ampie Case
2005 Honda Civic
Carputer wont power up once Amp is installed Legrath Newbie 6 03-20-2007 11:16 PM
wikipedia: carputer definition pRoFiT Off Topic 2 12-31-2005 09:32 AM
The Mac OS (10.3/4) AS a carputer frontend... meatwad MacCar 67 02-28-2005 05:25 PM
My Weekend of carputer hell! Sonicxtacy02 General Hardware Discussion 10 01-05-2005 09:19 AM
Good time to buy carputer components? Linus General MP3Car Discussion 19 11-25-2004 09:57 PM
