Go Back   MP3Car.com > Mp3Car Technical > General MP3Car Discussion
Old 07-19-2006, 09:34 PM   #1
Need advise on mounting my computer in my MR2
ALright basically, im having some trouble figureing a better spot to mount my carputer, i dont like having to move it everytime someone else drives my car, since the current way its setup, its based off how far the seat is when I am driving
anyways, ya i drive a toyota mr2 (91 NA) and, no pics of the carputer itself but here
its on the floor right in front of the driver side sub, again its not pictured as those pics are old, but ya
the carputer is mounted on a piece of wood and the carputer rests on it (horizontaly) and when i drive, the seat is pushed back and its touching the computers case, heres a mock up
again, since the driver seat is right up against the computer when its adjusted for me (im like 5' 4") anyone else who is driving it WOULD NEED to move the seat back, and that means repositioning the computer, which i hate doing
so does anyone have any ideas on how/where i can mount it, to have extra room? i cant fit it in the storage compartments
any help would be much appreciated, thanks
also, my frunk is taking up by my amp
Bboy_jon is offline   Reply With Quote
Old 07-19-2006, 09:49 PM   #2
pepsibobby's Avatar
lol i like the drawing.
Cant code cause I dont know how, but give me the paint bucket and my eraser and have at you!
pepsibobby is offline   Reply With Quote
Old 07-19-2006, 09:54 PM   #3
well you should, i put almost an hour into it...
Old 07-19-2006, 09:59 PM   #4
fiberglass a good custom case..
Yellow-Snow is offline   Reply With Quote
Old 07-20-2006, 01:02 AM   #5
should i buy one of these and shove the comp inside?
http://cgi.ebay.com/ebaymotors/JDM-9...ayphotohosting
http://cgi.ebay.com/ebaymotors/JDM-M...QQcmdZViewItem
i have this case
http://www.mp3car.com/store/product_...2431cc6d1a541d
should i just make a case (out of aluminum) that is small enough to fit under the seat?
Old 07-20-2006, 08:35 AM   #6
binary.h4x's Avatar
On the armrest between the subs. I think that is where those cd holders go anyway.
binary.h4x is offline   Reply With Quote
Old 07-20-2006, 04:40 PM   #7
ya i was thinking of that originially, but then people can see it, but its still an idea
any ideas how to mount it? cuz the center is all slanted and stuff
Old 07-21-2006, 04:24 AM   #8
Need more pics! Need to see the front of the dash, the floor space, need to see distances with the seat down, I'll gove you some ideas, but you dish out more pics!
Mrcat88 is offline   Reply With Quote
Old 07-21-2006, 04:39 AM   #9
I would mount it above the driver's sub, sideways, with a dvd slot loader facing the passenger. Hide the wiring under the back carpet. Just be sure to wrap the wires with heat sleeving.
Old 07-21-2006, 09:42 AM   #10
_
the first thing that stuck me when I opened up this thread was "CRAP!"
You need to move that strap that's going over the drivers side sub. You're not doing that sub any good by preventing it from extending when it needs to.
Secondly, I'd start looking behind panels:
Jan Bennett
PLEASE do NOT PM/Email/IM me asking me to spoon feed you. Please post on the forums! Chances are, someone else has or will have the same questions.
RedGTiVR6 is offline   Reply With Quote
Old 07-21-2006, 09:46 AM   #11
would the comp have trouble sitting on top of the sub?
heres SOME stuff, not of my car
http://carpron.com/multisite/v/toyot...mkii_interior/
edit: the straps arent on the sub most of the time, there not all that tight either, the strap sits mostly on the mounting part of the sub, the pic was taken the second i put the subs in, no adjustments or anything
btw, the computer is normally sitting horizontally, not slanted like that, its disconnected right now
Old 07-21-2006, 12:23 PM   #12
I dare say, that yellow car is a little too messy of an install for me, leaves too many wires exposed. You can do the same kind of thing without so many exposed wires. I think it will be fine above the sub, but don't rest it on the sub. I would get 4 studs/special jam nuts or something and put them where needed through the back peice, then make 4 simple angle brackets bolted to the case. That way, if you need to remove it, you can just unbolt it from the floor.
If you have it above the sub, on mounts, attached to the carpet/fiberboard stuff that makes your firewall, it shouldn't have too many issues. A buddy had a computer under the seat, with the sub right behind it...it was in direct line with the vibration from the sub. I personally have not had a vibration issue, and I have motor mount insert which makes idle vibrate quite a bit....more transfer from the motor.
But why isn't inside the panel a good spot? That looks like it works great!
Old 07-21-2006, 12:54 PM   #13
FC3S's Avatar
i doubt an MR2 has enough room behind any panels to work, lol
the panel pics are from (i assume) one of reds builds, not bboy_jons
FC3S is offline   Reply With Quote
Old 07-21-2006, 01:29 PM   #14
_
correct, it's the current install in my car. It's the area behind the rear seat pannel behind the driver.
You would be amazed at what kind of room you can find behind interior panels.
Jan Bennett
Old 07-21-2006, 02:15 PM   #15
ya theres no room in my car (behind the panels)
i didnt say it in this thread, but in your thread (mrcat, on mr2oc) i said the wires are messy (well i thought i did) and that id be running it through the carpet after i relocate the comp
FAQ: Glossary of Terms Bugbyte The FAQ Emporium 13 11-07-2006 05:00 PM
Troubleshooters! Computer turns off randomly and wont turn on, need help phatbimmer General MP3Car Discussion 4 06-05-2005 06:09 PM
computer theft tracking - PC PhoneHome Question General MP3Car Discussion 9 07-16-2003 03:14 PM
Can the Camry or mr2 handle it? Seabass General Hardware Discussion 5 06-23-2003 11:26 AM
Computer Mounting Location freestyler General MP3Car Discussion 2 01-20-2002 05:22 PM
