Go Back   MP3Car.com > Mp3Car Technical > General MP3Car Discussion
Old 08-01-2006, 12:58 AM   #1
extra usb?
i need more usb plugs, what should i do?
hoodlum is offline   Reply With Quote
Old 08-01-2006, 01:28 AM   #2
Buy pci usb adapter.
Check mobo for extra USB headers.
Buy a HUB.
1999 Grand Prix GT
o Alpine CDA-9811 w/ Aux In adapter
o CarPC control with no display (yet), using Bemused on my Nokia 6620 over bluetooth to control linux CarPC. Details coming soon.
timothy is offline   Reply With Quote
Old 08-01-2006, 01:31 AM   #3
Buy pci usb adapter.= no room in my case.
Check mobo for extra USB headers. = already used it up(only one on m10000)
Buy a HUB = notenough power to run 4 ports. and extra power requires 5V and car is 12v.
any ideas?
Old 08-01-2006, 01:40 AM   #4
any ideas?
Tap into the 5volt rail(red wire) on a molex connector, now you will have 5volts for a USB hub. Be sure you won't over work your PSU with a USB hub added.
kjones2k1 is offline   Reply With Quote
Old 08-01-2006, 09:20 AM   #5
MySQL Error
Sonicxtacy02's Avatar
buy the opus POL from the mp3car store and wire up a 10 port usb hub
03 Acura RSX Coupe
a K.I.S.S Flash, VB, and Autoit Programmer
Developer of: RRFusion, MovieTimes, (new)RRMail, & RR Plugin Manager
Coming Soon:RRChrome, & CentraFusion
Is Your RR Plugin Managed?
Old 08-01-2006, 11:27 AM   #6
I have m1-atx.
Old 08-01-2006, 12:30 PM   #7
I have m1-atx.
You still need to calculate how much power your already drawing without the hub from the PSU to make sure you haven't reach the 90w limit. Here is a power wattage calculator from the FAQ section under power supplies.
http://carpc.kyferez.com/Tools/PSUWattageCalculator.php
Old 08-02-2006, 01:02 AM   #8
I thikn i am good.
m10000 epia
512 ram
40GB HD
usb-cdrom
usb-touchscreen
usb-touchpad
usb-hub -> Wifi, External harddrive.
serial -> infra red
USB port power dies?! pixelflash General Hardware Discussion 1 10-22-2007 10:26 AM
Installing a USB Hub up-front? Read this... hd54321 General Hardware Discussion 13 02-09-2007 12:49 PM
USB hub does not always initialize on boot d_sellers1 General Hardware Discussion 5 05-29-2006 04:41 AM
extra usb external drive-how to add to directory? glennwoudenberg MediaCar 1 12-26-2004 05:51 AM
USB Sound Card with ASIO driver and volume control tbdombrosky General Hardware Discussion 0 02-04-2003 12:00 AM
