Quote: Originally Posted by
nappyjim
I want my carpc desktop to look EXACTLY like my computer in my room. Icons, wallpaper, start menu, etc. So if I add a new shortcut icon to my computer in my house, once I sync it with my carpc, the carpc desktop will also be updated with the new shortcut icon.
Possible or not?
Everything is possible... just depends how much time, skill, money, etc you throw at something
I dont know if my ideas below will give your exact desired outcome, nor do I know if it will even work... it looks good, but couldnt say for sure until you tried it. I guess if you save an image of each machine before you try it you'll be able to be back up in 10 minutes.
to get your start menu and your desktop icons to be the same you could try syncing the c:\documents and settings\YourUser\Desktop and start menu folders. not sure about the wallpaper, I guess the easiest way would be to use a static file location and name, then when you want to switch wallpapers copy your NewPic.jpg to that location and rename it, that way to windows it always uses the same file, but its just something different renamed. I dont think theres any easier way.. but we'll see what others come up with.
I assume that you already know that "generally" speaking a carpc doesnt have as many programs on it as a desktop does, and if you sync your start menus, you will probably have a lot of programs which are not installed one one or the other machine which will just end up as dead links.
let me know if you try this and if it works as you were looking for. Microsoft just came out with a new Powertoy called SyncToy and it works pretty decent. Its free, and available on their powertoys page.
