Go Back   MP3Car.com > Mp3Car Technical > General MP3Car Discussion
Old 08-13-2006, 01:28 PM   #1
Processor/Mobo Question
I am very close to beginning my build, but I wanted a 2nd opinion on the processor and motherboard I am considering.
I have been trying to decide between a VIA micro board with a built in 800MHz-1 Ghz processor or a micro atx board capable of carrying an Athlon 64 3200+ processor on it.
Any pros/cons to either choice, opinions, or a completely different suggestion would be greatly appreciated... Thanks!
ctsoccer13 is offline   Reply With Quote
Old 08-13-2006, 01:43 PM   #2
pip
pip's Avatar
These are vastly different solutions.
The VIA option is cheap, is low pwer, uses little power and does not develop a lot of heat. It will run GPS and will play music and probably movies...but not a lot more. Front ends with a lot of flash animation will give it problems.
A microATX board and 64 bit processor on the other hand will ba able to handle anything you want to throw at it. But....
Make sure it has decent onboard video. Better than using a seperate card.
Make sure you use a mobile processor. This reduces heat & power requirements.
MAKE SURE YOU CAN POWER IT. Such a setup will require a hefty power supply. Even using onboard video & a mobile processor you'll need much more power than the VIA requires.
It will develop a lot more heat. You'll need a low mass heatsink...stops it moving too much.
Read the FAQs, this has been covered before.
Personally, I'd say go for the more powerful option. It allows you to do more, the video will be better, you can use flash in your fron end skins and will run thing faster.
pip is offline   Reply With Quote
Old 08-13-2006, 04:21 PM   #3
DeltaFX's Avatar
Ludicrous speed ?
Now Galileo is real. Muhahahahaha :p
DeltaFX is offline   Reply With Quote
Old 08-13-2006, 05:04 PM   #4
An Athlon 3200+ is only rated at 1.8-2GHz depending on the socket type. I don't deem it to be too ludicrous as I'm hoping for a quick startup and to be able to run all the things I'm wanting to.
Old 08-13-2006, 05:11 PM   #5
Self proclaimed spoon feeder
TruckinMP3's Avatar
Sure, it only compares roughly to a P4 3+ ghz processor....ludicrous in a car environment.
You asked for opinions. Do not argue when you get them... even if you do not like what you read.
TruckinMP3
Self Proclaimed Spoon feeder!
Read the FAQ!
TruckinMP3 is offline   Reply With Quote
Old 08-13-2006, 05:28 PM   #6
No, don't get me wrong--I'm looking for feedback. I know I don't know everything I'm about to get myself into, so I want to know if the processor is too much.
I didn't mean to come across as defensive, I was just expressing what I thought and waiting to see if someone would tell me I'm on the right or wrong track.
What type of processor would you suggest? I'm hoping to be able to run a combination of GPS, phone control, and music at the same time while looking for fast startup speeds as well.
Old 08-13-2006, 06:25 PM   #7
Neither darque nor pervert
DarquePervert's Avatar
Low power is the rule for in-car installs, plain and simple.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 08-13-2006, 07:50 PM   #8
TruckinMP3's Avatar
Pentium 2 era 400 to 500 mhz would be plenty of processor... or lower,
That means it is easier to power and cool.
TruckinMP3
Read the FAQ!
Old 08-16-2006, 10:14 PM   #9
Timecloud's Avatar
You really have to decide what you want the computer to do. MP3's, Video, GPS, mobile office setup, etc.. A small processor can handle this as multi-tasking will be limited. The smaller the processor the less heat generated as well. Heat and confined spaces I would say don't go well together. Also you stated an Athlon 64 3200+, not XP there's a difference there. I would look for an early AMD Duron, Thunderbird or low Athlon CPU. I got a 2500+ cause it was $40. I was going to use a Duron 800.
2000 Excursion 4x4 Limited V10
Generic DVD
2 7" Headrest monitors
Acorp 7km400QP 2500+ 1GB DDR400 - m1ATX
Delorme Earthlink GPS
XM-PCR1000
7" TS
Worklog
Timecloud is offline   Reply With Quote
Old 08-16-2006, 11:07 PM   #10
i have an amd 3200 on a micro atx board using the DSATX power supply and 2 60mm fans and have had no issues with it in my case in my car in 100* days. and jeez does it fly! i would reccomend this route for expandability. if you want to use streetdeck ( TWO THUMBS UP) in the future then youll be glad you went the amd route. plus i wouldnt say its cheaper but eiterh way you go, its about the same price in the end.
2003 Ford F-250 7.3L Diesel Crew Cab
Anyone play Trukz Online Truck Driving Simulation game? Check it out, I have my own company as well, join up, were hiring drivers now. http://www.trukz.com/company_display.asp?ID=842
sciontC is offline   Reply With Quote
Old 08-17-2006, 01:25 AM   #11
The Lavender Tie Just
Made It Obvious
Rafster's Avatar
Location: Bonita, CA (Hop, Skip, and a Jump from Tijuana, Mexico)
I have a PIII 700MHz with 256MB Ram and with Tiny XP, I'm ready from cold boot and in my frontend in +/- 40 seconds... From hibernate more like 10 seconds...
OPnly thing that I wish was that I could get more RAM into it... Unfortunately it's a Dell Latitude L400 with a max of 256MB...
You don't need a high power/speed processor in a car. I can do Music/GPS/and most videos just fine!
Peace,
Rafster
Post # 3000
Items for Sale
PM me!! Not using new Classifieds because I don't particularly like the way it works...
http://www.speedtest.net/result/133342788.png
Rafster is online now   Reply With Quote
Old 08-18-2006, 04:59 AM   #12
Nomader's Avatar
i am running a sempron 2800 on a micro atx. and 512 ram. on board video and audio. powered by the DSATX. I have no power isues.. no heat issues (4 fans in my case.. 1 for cpu 1 for case sucking air out. 1 small for hard disk, 1 small for dsatx.)even though the temp is 38 degrees celsius this month. and the thing is in my TRUNK.
I would also recommend this route as the PC rule is (even in cars) install as higher specs as you can afford, you will need it soon..in cars however i would add "install as much as you can afford, and can afford POWERING"
Nomader is offline   Reply With Quote
Old 08-18-2006, 05:42 AM   #13
~Rob's Avatar
Can I suggest maybe going back to a Socket A rather than AMD 64? It's cheaper (second hand only I believe now, they're rare) and if you can go for the Xp-Mobile. I've got a 2400XP-M in mine at the moment. Still plenty of grunt and doesn't use too much power
~Rob is offline   Reply With Quote
Old 08-18-2006, 05:01 PM   #14
DeltaFX's Avatar
Did I say Ludicrous out Loud ? oops
'nyway, remember that a via 1Ghz chip scores like a P3 700 Mhz (and that the so-called Mpeg 4 hardware support of C7-Cn400 via combo is more vapor than real stuff, cause there's NO windows / linux drivers available)
So between such a via proc and the AMD 3200+, you have choice. Really.
Old 08-18-2006, 06:37 PM   #15
jschrauwen's Avatar
Lightbulb
I was more or less in the same situation your in now, a few weeks ago. I spent a fair amount of time trying to gleen the information I needed to come to the same decision you're attempting. Although the VIA boards/processors seem to be best suited for most of my needs, It appeared to me to be 2.5+ year old technology and I thought of something perhaps a little newer / with a little more grunt. The shop doing the build foe me suggested the Commell line. We/I decided that the Commell LV675D would best suit my needs when it came to multi tasking - GPS, WIFI, DVD/CD-RW, AM/FM Tuner, USB's, Serial port for Megasquirt and it had a key feature I was looking for - a Tos-Link out for better sound options.
http://www.commell.com.tw/Product/SBC/LV-675.HTM
This also meant a good choice available for processor selection to but also meant more power requirements and a higher base cost value also. I've found it's all hand in hand. I'm not a good one at all to comment on the previous options you've given but only thought it might be worth a look at other options available to you. Hope this helps, cheers,
John
1990 RHD JDM 300ZX TT 2+2 5sp T-Top
491RWHP / 18psi / 94 octane
jschrauwen is offline   Reply With Quote
Any in-dash monitor with built in FM Radio QUESTION. ??? 74Camaro LCD/Display 2 05-02-2006 06:15 PM
Forum Etiquette Enforcer Newbie 5 01-09-2006 06:58 PM
Paint And Polish Question gboy Fabrication 8 08-13-2005 08:22 PM
FM Card Question.... Superbike1k Car Audio 1 05-16-2005 10:03 AM
Just wanted to introduce myself, and I have a small question. Choser Newbie 5 02-02-2004 10:52 PM
