Go Back   MP3Car.com > Mp3Car Technical > General MP3Car Discussion
Old 08-16-2006, 11:35 PM   #1
Help Mobo is acting wierd
hey everybody,
so i bought the via epia m10000. I tested it on my home psu and it fires up fine (fan spinning, etc) but there is no display on VGA. Also I dont see any smoke but it smells like burning electrical components. I unplugged everything and went over it w/ a magnifying glass and found no damage or evidence of burning. Not sure what to do.
DesolationAngel is offline   Reply With Quote
Old 08-17-2006, 12:16 AM   #2
Fusion Brain Creator
2k1Toaster's Avatar
Clear the BIOS. In the BIOS, you can select VGA out, RCA out, or PCI I think. Clear it to the default VGA. If no go, hook up to a TV and see.
To change it once you get the thing to show up, it is in the BIOS (Del Key).
And I have found that a lot of new products smell like it is sort of... not burning, but really hot because dust and stuff is burning off transistors and out of the heatsink area. Thermal paste and burn-in of CPU.
Be careful, but it can be normal. Monitor temps closely for a day or two though just in case.
2k1Toaster is online now   Reply With Quote
Old 08-17-2006, 01:21 AM   #3
well thats comforting to know about the smell. however this is the first time i've hooked it up. Not sure whats wrong just no display. Its a new HD so the spool is quiet i cant tell if its spooling up. however the slimline dvd player isnt responding. Question: there is no power input for the slimline right? it just runs off the ide...?
Old 08-17-2006, 01:24 AM   #4
2k1Toaster's Avatar
No IDE does not carry power. usually has a floppy connector on the adaptor.
The JAE-50 on the back of the slimline takes power and data, but once converted to IDE, no data. Seperte.
Did you clear the BIOS? Just because it's new doesn't mean it couldn't have been altered. Also make sure the jumper setting is set to normal and not clear. Some boards ship that way so the CMOS battery doesn't drain while being stocked in a warehouse for a year.
Old 08-17-2006, 01:29 AM   #5
I cleared it and it is set to normal. no luck. fan still spinning and it still smells kinda wierd. I really wish i could get a display. no response from monitor @ all.
Lilliput touchscreen acting wierd Mitski's Rider Input Devices 9 08-02-2006 01:18 PM
Xm radio acting wierd boomintrac General Hardware Discussion 2 05-02-2006 12:02 PM
Asus Micro Mobo and AMD XP-M 45W Barton MatrixPC General Hardware Discussion 47 01-05-2005 06:26 PM
Mobo Woes - Enlightenment needed nzKAOSnz Off Topic 0 05-17-2004 09:24 PM
mpxplay acting wierd lstrunk Software & Software Development 3 09-05-2001 02:01 AM
