Go Back   MP3Car.com > Mp3Car Technical > General MP3Car Discussion
Old 08-31-2006, 03:02 AM   #1
AllThingsEnd's Avatar
SP13000 rebooting
ok i got my SP13000 all connected and everything, i go to boot it up and it gets to the windows boot screen for a split second and then the system reboots. ive replaced the ram, new hdd, new PSU. even when i try to reinstall windows it gets to the part where its about to install and then restarts. wtf is going on?
[::::::::::] 100% - Planning
[::::::::::] 80% - Computer
[::::::::::] 0% - Fabbing
CarPC:
SP13000 / 120GB SATA 2.5" / 512MB DDR
8" Innovatek TS / Globalsat BU-353 / Engenius EUB-362 EXT
Slot load DVDRW / PS3 Wireless Keyboard
AllThingsEnd is offline   Reply With Quote
Old 08-31-2006, 07:30 AM   #2
v8 scimitar's Avatar
Boot it off a dos boot disk and see if it happens. If it is stable in dos then you can run some utilities that will load the system and do logs. If it is still stable doing that then there might be something wrong with your install disk. Just to keep the Linux guys happy you could do it in that just as well if you can find any. If it fails doing the tests a look through the logs should tell you what happened. You have probably done this already but make sure the CPU fan is working properly as your getting about as far as I would expect with no fan. I had the same thing on my SP13000 a couple of months ago, turns out it didn't like the ram I was using. I put Kingston in and its been rock solid ever since.
Visit my site V8 Scimitar
SP13000, 300GB SATA HD, 1GB DDR. Opus 150, K301 screen, Cisco WIFI, AQmax GPS, RoadRunner and FreeDrive, Sony MEX-R5 head unit.
v8 scimitar is offline   Reply With Quote
Old 08-31-2006, 08:00 AM   #3
ok so strange thing happened. on a hunch i took the cmos battery out and unplugged it. left it out for a little while the put the battery back in a plugged it back up. works like a champ. hmm i guess the previous owner had something in the bios that was causing it to reboot. strange.....
CarPC:
Old 08-31-2006, 03:22 PM   #4
Glad to hear you got it working.
SP13000 won't boot Richard Alpha General Hardware Discussion 1 06-26-2006 12:20 PM
Terrible static noise on SP13000 (internal audio) BlackStealth Newbie 10 05-15-2006 02:44 PM
MII12000 vs SP13000 spaceskater General Hardware Discussion 1 03-07-2006 11:19 PM
epia sp13000 problems shocker1185 General Hardware Discussion 21 02-16-2006 12:37 PM
Epia SP13000, Ampie case, M1-atx skippy911 Classified Archive 4 01-28-2006 10:48 PM
