Go Back   MP3Car.com > Mp3Car Technical > General MP3Car Discussion
Old 09-27-2006, 07:25 AM   #1
Viper alarms with AUX to turn on computer
Sorry if this was mentioned before but I tried searching and got no answer.
I'm new to this carputer scene, but I was wondering if it was possible to activate/turn-on my laptop with my Viper 2-Way Alarm Remote.
I manually turn on the laptop everytime I get into the car. This would be great for me because my computer boots up kinda slow and I wanted to make it boot ahead of time before I reach my car.
My alarm model number is Viper 791xv.
Please help me, this would be a great feature.
tweaker is offline   Reply With Quote
Old 09-27-2006, 08:27 AM   #2
Would the laptop stay in your car permanetly? Or would it be used for other things as well? Are you worried about voiding the warrenty of the laptop?
New car means time for a new carputer.
Planing.
trebuchetguy is offline   Reply With Quote
Old 09-27-2006, 04:56 PM   #3
this laptop will be permanently stored in my car. Also there is no warranty anymore. Its over 3 years old. Don't really care about this laptop thats why I'm using it as a carputer.
O yeah, i don't mind opening up the laptop. If you got a trick to this, help me out.
Old 09-27-2006, 11:55 PM   #4
Do you know if your viper can temprarly trigger a relay?
Planing.
Old 09-28-2006, 12:01 AM   #5
yea u would need to use a relay, and 30 should go to 12 volt battery
87 to the power for the laptop
your aux should be a low amp negative trigger so connect it to one side of the coil and 12volt battery to the other
1stclasso is offline   Reply With Quote
Old 09-28-2006, 04:02 AM   #6
almera's Avatar
You can use accessory trigger
download installlation manual :
791xv install manual
http://www.directechs.com/guides/man...N564V_6-03.pdf
almera is offline   Reply With Quote
Old 09-28-2006, 05:27 AM   #7
Ok I read the manual and have no clue about this sorry.
From what I read my Viper Alarm has two AUX output.. Channel 4 and 5. I will be using channel 4 which would be the violet/black wire. Where exactly do I connect the wire to? A relay? If so, can somebody draw up a quick diagram. It would be much easier if I have a visual concept of what I'm trying to accomplish. A simple MS Paint schematic is good enough for me.
Thanks in advance guys.
Old 09-28-2006, 07:21 AM   #8
almera's Avatar
Laptop Auto Power-On:
http://mp3car.com/vbulletin/showpost...06&postcount=1
Old 09-28-2006, 08:50 AM   #9
I have already read that thread/post. I don't want my laptop to turn on with my ignition. I want my laptop to have remote start with channel 4 of my Viper alarm transmiter.
Sorry if I have confused anyone.
Old 09-28-2006, 07:22 PM   #10
Jahntassa's Avatar
That wire creates a 'ground trigger'. Basically you need to hack into the power switch for your laptop and get it so you can just connect two wires together to turn it on (which is what the power switch does)
Once you have these two wires, the simplest thing to do is get an automotive relay (overkill, yes, but it will work and they're fairly cheap and easy to work with)
Connect up like this:
12v to pin 85
The purple/black wire from the Viper to pin 86
One of the wires you hacked from the power switch to pin 30
The other wire you hacked from the power switch to pin 87
As for 'hacking your laptop' for the power switch, well, you'll need to do some more research if you don't know how to do that.
Jahntassa is offline   Reply With Quote
Old 09-29-2006, 03:32 AM   #11
Jahntassa you are the best!!!! I'll give that a shot tommorow. Thats all I wanted to know and what to wire.
Opening up the computer is not a problem at all. I've done it before when I solder LED's. So this will be easy.
Thanks a whole lot!!!
Turn your computer on by remote control PaulzY General Hardware Discussion 22 03-02-2005 03:06 PM
When you turn off your computer do you have to recalibrate the touchscreen abz123 Input Devices 2 03-20-2003 09:37 AM
opus supply & computer on/off ShinkunoNamida Power Supplies 2 10-07-2002 07:35 PM
RF atx startup/shutdown. Kinnish Power Supplies 16 09-26-2002 07:46 PM
How can I turn all these at the same time? Circuit? izaram Off Topic 0 07-23-2002 12:45 AM
