Go Back   MP3Car.com > Mp3Car Technical > General MP3Car Discussion
Old 06-05-2002, 12:37 PM   #1
Question electronic part question~ help
I'm sorry to ask this but I don't know anything about electronic part and I need this setup for my mp3car.
what kind of electronic part do I need if I want just 0.5 pulse output when the neg or pos power input ? (just like used in car alarm)
thank you for your help, guys.
accord is offline   Reply With Quote
Advertisement Sponsored links
Old 06-05-2002, 01:04 PM   #2
Rob
Registered User
Rob's Avatar
0.5 seconds or 0.5 volts out, would something like a 555 work? what exactly are you trying to do?
Rob
And you say people actually pay money for M$ Windows?
www.mp3mini.co.uk (Does what it says on the URL) www.openclassic.co.uk (The new car, with zero rust!) www.rob-web.co.uk (My other site)
Total re-design underway: on the whole progress is very slow as the car is taking up too much time :)
Rob is offline   Reply With Quote
Old 06-06-2002, 12:55 PM   #3
I'm trying to use parallel port controller to control some car switches.(such as door , alarm , and more)
the problem is the controller is just relays , it can only turn on or off constant power. But for example , a door switch needs short pulse power (0.5 or 1 sec) .
And I was wondering if there is a simple way to make this work. ??
any idea???
Old 06-06-2002, 02:15 PM   #4
Rob
Registered User
Rob's Avatar
A 555 is a very cheap all in one timer chip that can be used in various modes, including one shot (monostable), ie when a signal is applied on it fires a single pulse which lasts for X sec. The lenght of the pulse is controlled bu two support components (a resistor and a capactior).
See this site for more info on 555 chips.
Figure 9a is probably what your after
Rob
Old 06-06-2002, 04:17 PM   #5
Registered User
huh? I don't get your problem, if you have relays connected to your PC you can program your PC so that it turns on your relay and 0.5 sec later turns the relay back off??
If at first you don't succeed.........
destroy all evidence you tried
for info on t6369c LCD or Presslab's powersupply check:
http://www.namms.tk <=updated!!
marsjell is offline   Reply With Quote
