In my opinion, integrated devices will make the component carpc semi obsolete in the next couple years. For instance you can get the following for $200 and it does basically everything I need except interface with my magesquirt (which is easier on a laptop anyway). I can barely buy an Opus and build a case for $200.
$200
http://search.ebay.com/search/search...%27eo+PVP+E320
This PVP E320 portable media player beautifully combines the functions of a portable media player with an outstanding GPS Navigational System. You’ll be able to watch, listen and feel –while knowing exactly where you are!
Powered by an Intel XScale 400 MHz CPU, the Dream'eo PVP E320 is one of the most advanced mobile platforms that you’ll see in this price range. It’s perfect for sharing audio and video files, as well as preserving all your critical digital data all on a 20 GB hard drive. And you’ll see it all on a remarkably clean and clear 3.5-inch color TFT screen.
You can use your PVP to enjoy digital media files, copy music, videos and photos from desktop computers to your PVP, and then take them with you anywhere for an on-the-go media experience. Thanks to its USB connection, this Dream'eo PVP E320 Portable Media Player is the ideal personal digital companion for your leisure activities as well as business data storage
Features/Specifications:
* Dream'eo PVP E320 20GB Portable Media Player w/GPS
* General Features:
* Intel XScale 400 MHz CPU
* Windows CE.NET 4.2 Core operating system
* 32 MB SDRAM internal memory
* 20 GB of hard drive storage
* 3.5-inch TFT touch screen LCD 64 K colors, 320 x 240 pixel resolution
* Internal mono speaker and microphone
* Stereo audio in and SPDIF audio out
* High speed USB 2.0 interface
* Type-1 Compact Flash card slot
* Supports MPEG-1, MPEG-4 SP, ASF, WMA, AVI video format
* Supports MP3, WMA, and WAV audio format
* Supports GIF (exclude Gif89a), JPG, PNG, BMP image format
* Audio recording encoding MP3 @ Bit rate: 64 kbps, 128 kbps, 192 kbps
* Up to 7-hours play back on MP3 or 3-hours for video on built in LCD
* GPS Receiver Features:
* Compact Flash interface
* Acquisition time:
* Warm start: < 38 seconds
* Cold start: < 45 seconds
* Hot start: < 8 seconds
* Snap start: <3 seconds
* Re-acquisition:
* 100 ms
* Interface:
* RS232 (NMEA protocol)
* Update rate:
* 1 second continuous
* Antenna:
* Built-in, External MCX antenna connector
* Accuracy:
* Position: 5 - 25m (SPS).
* Position: 2 - 5m (EGNOS)
* Velocity: 0.1m/s
* Time +/- 1us
* Power:
* < 30mA @ 3.3VDC ± 10%
* 30% duty cycle trickle mode
* Altitude:
* Velocity: 515m/s
* Acceleration: +/- 4G
* LED function:
* Off: unit powered off
* On: Unit searching for satellites
* Blink: 3D fix obtained
* Regulatory Approvals:
* FCC
* CE
Package Includes:
* GPS Compact Flash receiver w/external antenna
* Stylus
* Remote control
* Headphones
* USB cable
* S-Video cable
* RCA audio out cable
* Wind shield mount w/base
* Software CD
* Power adapter (100-240V ~ 50/60 Hz 0.3A)
* 12V car power adapter
* Quick start guide
Additional Information:
* Notes:
* Model: PVP E320
* UPC: 7 41456 00106 6
* Product Requirements:
* Available power outlet
* Available 12V car power outlet
* Available USB port
* CD-ROM drive for software CD
