Go Back   MP3Car.com > Mp3Car Technical > General MP3Car Discussion
Old 12-01-2006, 08:19 PM   #1
roccomaniac is an unknown quantity at this point
psp to amp & RCA Y adapters
hi guys,
sorry if this is the wrong place
sorry if this question have been asked already
I did search, I did google
so please no flames
so I have two questions,
here comes :
I have a "conventional" car system and I want to feed MP3 into it
I have a PSP and can't find a clever way to plug it in
I'd like to rip the HU and use only the PSP
it works ! but it's about 1/4 as loud as the HU
I thought it would be easy to find some kind of preamp but NO !
google floods me with stupid psp accessories
or FM/tape adapters that I don't want
car centers sale guys open wide eyes like "do WHAT ?"
can't find the trick !
also
my door speakers are fed from the HU directly
I plan to use a small amp to replace this (if/when I find a solution for the previous point) but this amp only have a RCA input, no output.
for my two big amps, the one driving the woofer has input/output so it's fed by the RCA from the HU and it feeds the amp for the medium speakers
I'd figure I could use some Y RCA adapters that I have but I'm not sure if this is correct...is it ?
when I was doing studio, I know we used them but not sure it's the same stuff here (symetric/assymetric/whatever ?)
TIA for your help.
tchuss !
roccomaniac is offline   Reply With Quote
Old 12-04-2006, 11:16 PM   #2
1bad2v's Avatar
1bad2v is an unknown quantity at this point
Find a good quality Preamp/EQ. It will will take the signal from your PSP make is good for your amps. And then you can put as many amps as you want. You will get a few sets of RCA outputs from the preamp. And subwoofer control as well.
http://www.pioneerelectronics.com/pn...tailsComponent
It doens't really get rid of the whole "deck" but does add some great sound processing. Also you can wire 3 amps directy to it. with High-voltage outputs.
1bad2v is offline   Reply With Quote
Old 12-04-2006, 11:34 PM   #3
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
you don't need a PSP pre-amp. when you are searching, you are probably looking with "PSP" as a term. Dont. Just look for audio preamp that accepts 1/8 stereo and outputs whatever your amp will take (RCA's probably).
No need for PSP stuff. If you can plug headphones in, you can plug a preamp in.
What Amp would do the trick? LeythDC5 Car Audio 4 02-27-2006 01:54 PM
vw mk4 monson amp and another amp colorless Car Audio 33 10-03-2005 01:32 PM
What's up with my BRAND NEW speakers?? tbird2340 Car Audio 110 11-27-2004 08:28 PM
Sound not very loud have i bought the wrong amp rickyaswell Car Audio 7 09-26-2004 11:23 PM
