12-08-2006, 12:04 AM
#1
Cold Weather! To do or Not to do!
Aight...
I've searched thru the threads but no luck with this question...
I know that the recommend temperatures for a PC is around 40 degrees to 130 or so... The 130 doesn't bother me... B/c in lil ole Kentucky... I never seen it get above 103... Lol
But the 40 degrees does... Right now its 25...
So the general question is... Whats the coldest temp that you ran ur pc under...
Yet I wander why they would set such a high -- low temp recomendation... Cuz... Me being an X gamer (counter-strike) We always wanted or computs.. To run as cool as possible.. Which gave us op cpu response...
But anyways... Give me some info.. Thanks guys...
** MP3car.com.. is prolly the greatest site on the net...
12-08-2006, 12:38 AM
#2
its 8 out and my computer starts fine, i usually leave the heat on for awhile though before just to be safe, also your lcd monitor will most likely be very dim when it is cold untill it heats up, i know mine is, and some hard drives wont work right if its to cold, so if your computer doesnt start wait untill the car is warm and try again, i've never heard of damaging a computer from being to cold its the shift from warm to cold and back again that wears electronics out, but i've never seen any problems. just with subwoofers because the rubber surround could crack.
12-08-2006, 12:39 AM
#3
12-08-2006, 12:49 AM
#4
well i live in saskatchewan, canada and if i were you i wouldn't worry about it gettin to cold were you live.
i just put in my setup 2 months ago(see sig for my carpc specs) and, i was worried about cold weather but hasn't been a problem yet.
and now for the temp i've been running it at
the coldest so far
-30 degrees Celsius which is -22 degreed Fahrenheit
the the coldest with the wind chill factor
-40 degrees Celsius which some how is the same as -40 degrees Fahrenheit
so unless you have weather colder then that i would not be to worried
PC
AMD 3500+ 2.2Ghz, MSI K9VGM-V Motherboard,
Geil 512MB PC4200 DDR2-RAM, 7" Lilliput Touchscreen, 30GB HD
Audio
300 watt RMS 2 Channel MTX AMP, 500 watt RMS D-Class MTX AMP, 2 Front - 5 1/4" Sony Xplods,
2 Back - 6 1/2" Sony Xplods, 12" MTX Sub
12-08-2006, 12:52 AM
#5
see i freeze my arse off when its 8 F outside, how do you do it when its -40.... i cant even imagine wow
12-08-2006, 12:54 AM
#6
i guess when you grow up in the cold you adapt to it
and we are crazy
PC
Audio
12-08-2006, 01:29 AM
#7
Mine works perfectly until the hard drive reaches about 10 degrees. The only time that ever happens is when I leave it overnight, if it's ten degrees outside, and I drove the car earlier in the day it retains enough heat to boot right up.
I decided not to wire my remote start to the computer, that way on a really cold morning I can get the car nice and warm, and then when I come and put the key in the hard drive is warmed up and the computer boots no problem.
12-08-2006, 01:45 AM
#8
Fusion Brain Creator
and we are crazy
Yup us Canadians are crazy! In colorado it doesn't get too cold unless you are up to 14k feet. I have worn shorts every winter. The only time where I have actually gotten cold was Thunder Bay, Ontario. Damn that place is cold!
My PC has booted up fine in at 0F just fine. Took a bit longer than usual, but perfect none the less. Full size HD btw.
12-08-2006, 04:51 AM
#9
and we are crazy
UK.
Its 6c outside, I'm not going out until it gets to at least 10c, so I guess nothing will be done on the car until at least March now.
Yes I hate cold weather!
Lez.
XM 2.1TD ~ Morette triple headlights+HID ~ Leather kit ~ XC70 alloys
Exhaust rear boxes removed ~ meshed air filter
12-08-2006, 02:41 PM
#10
Damn... i also hate the cold weather... The thing about Kentucky... Last week it twas 70 this week 15... Next week suppose to warm up to 50 or 60... So its gay... So i pretty much stay wit a sinus infection lol...
Guys thanks for the input...
12-09-2006, 10:55 AM
#11
Wow, -40, -22, even 10 degrees above zero. I don't know what would happen around here in Louisiana if it ever got that cold, but it would be something like the end of the world. Schools would probably close along with a lot of the roads. It rarely ever gets below 30 degrees here in the winter. This has been the coldest week (I thought I was going to get frost bite or something with it being 22 degrees the other morning). I can't imagine anything like the temps you all are quoting. I drove to NY once and my car's heater actually had to be defrosted because somehow the ice froze some of the passages for the air in my car. It wouldn't even blow (I always run the a/c even in the winter to dehumidify the air). That was a first for me. It usually doesn't stay cold for long around here. Now summer is another story. It gets pretty hot down here (sometimes around 110 degrees + heat index for humidity makes it around 115 to 120 sometimes). My problem is opposite. I guess I'll see next summer if heat will be an issue for me.
Lexus SC400/Factory Amps/Sub
HP/AMD 1.1 Ghz Mobile/Upgrade Imminent
512 RAM-DVD/7" Touchscreen
WinXP-Shelled to Roadrunner for now
Progress:
Software: Still trying to decide
Hardware: 95% done. . .need GPS
Installation: 90% done. . .clean up phase
12-09-2006, 12:15 PM
#12
Cold!!!!
Today it is 20 Degrees outside and I just jump in my car fire it up and roll. I believe that it is my hard drive that is the ticket but who really knows for sure. Three years running the same computer all original hardware...
Epia M1000 1.2gig, Toshiba 40gb HD, Itronix 60gb HD, 512ram,PCR, Audigy2zs, 2 Xenarc 7" , FRODOPLAYER Trying RR frontend , 2@1600/w Harrison labs amps & Caps, Focal & MB-Quart midrange, Diamond Audio D6 Subs, Mb Quart Tweets, 2-Audiocontrol three.1 !
12-09-2006, 03:53 PM
#13
about 3 years ago when i was in grade 10, it got to -52 degrees Celsius with the windchill(thats -62.6 degrees fahrenheit) and we were still required to goto school, that was one f***'n cold walk.
PC
Audio
12-10-2006, 12:13 AM
#14
-5 degrees
My only problem is that my cpu fan makes a whirring sound, so I'm going to have to find a new one
12-10-2006, 12:15 AM
#15
The Lavender Tie Just Made It Obvious
Location: Bonita, CA (Hop, Skip, and a Jump from Tijuana, Mexico)
It got really cold here in San Diego, CA. I think like 35F....
It rarely gets too hot or too cold here... we're usually at a nice 60 to 70 here...
Rafster
| Thread Tools |
| Display Modes |
Linear Mode
