Go Back   MP3Car.com > Mp3Car Technical > General MP3Car Discussion
Old 01-12-2007, 02:34 AM   #46
Quote: Originally Posted by Sham-Mobile View Post
For my setup, I bought the Carnetix CNX-P5V 15 Watt +5V Regulator from the mp3car store. 5v output at 3amps, did the trick and no problems since.
Wow man, thanks a TON, that's pretty much exactly what I need down to the exact amperage.
So I can just plug my 12v lines in on one side, and add my AC adapter's plug in on the 5v output and plug that into my hub and be good to go? That's actually cheaper than what Best Buy wants for their cell chargers and only like $5 more than Radio Shack wants, I'm definitely ordering one now.
spoonraker is offline   Reply With Quote
Old 01-14-2007, 06:31 PM   #47
I found a very simple solution. I picked up this Targus USB hub
http://www.targus.com/us/product_det...p?sku=PAUH217U
from my local Office Depot for about $10, and discovered that the car charger for my LG VI-5225 phone uses the exact same barrel plug and voltage. Since I already have a 3 socket cigarette light setup spliced into my tank circuit, this was truly a plug and play solution.
I haven't been able to find a link for my specific charger, but it's the one which came with my phone and has the "sprint" logo light up when plugged in.
wooga is offline   Reply With Quote
Old 01-15-2007, 09:19 AM   #48
Ruffy's Avatar
simple solution in connection but the phone charger does NOT put out enough power to supply 500ma to every device plugged into the usb hub. you're giving it more juice yes. but its still underpowered.
It's not about having the same barrel plug, its about pushing enough current.
Car : 00' Chrysler 300M
Speakers : Rainbow Audio SLC 265 | Subs : Diamond Audio D6 12" Subs X2
Amp's : Hifonics ZXi 6006 AB | Hifonics BXi 1606 D
CarPC: HP Laptop AMD Sempron 3000+ | 1.5GB RAM | DVD+RW | 80GB 5400RPM HD | ATI R200 Video
Ruffy is offline   Reply With Quote
Old 01-22-2007, 02:07 PM   #49
My cell charger outputs 5v 1A to my USB hub, which passes the hub requirements. I think that's sufficient.
It's not like I'm trying to power a hair dryer through my USB hub...
Old 01-22-2007, 03:46 PM   #50
Fusion Brain Creator
2k1Toaster's Avatar
it wouldn't surprise me if they made a USB hair dryer
2k1Toaster is online now   Reply With Quote
Old 01-25-2007, 01:49 PM   #51
usb adptor 5v
I found a very simple solution dc car converter 2100ma you can find 800 ma or 1200ma only 8 pounds and you can plug direct on your hub
http://cgi.ebay.co.uk/DC-CAR-ADAPTOR...QQcmdZViewItem
calado91 is offline   Reply With Quote
Old 11-25-2007, 02:03 AM   #52
Do most of these hubs come with the a/c adapter? I'm looking online, and most of the product specs are vague.
elimenohpee is offline   Reply With Quote
Old 11-25-2007, 01:50 PM   #53
Curiosity's Avatar
Look on newegg. It's usually in the description or the pictures.
XPort 1.26 -GPS port splitter, logger, and USB device resume fix
Curiosity is offline   Reply With Quote
Old 12-27-2007, 12:44 PM   #54
Raw Wave
HiJackZX1's Avatar
Ok I tried connecting my Belkin 4 port hubs directly to my OPUS and it resulted in them catching fire. Can I simply buy the Targus and modify the USB cable that supplies the extra power and connect it directly to the PSU...... Or can I get a USB connector to come off of the 5v rail and that way i dont have to modify the Targus's cabling....? Esentially adding USB ports that do nothing but supply power.... no data. Also what are the connectors, which one is positive, and which is ground..... Doing it this way with no adapter inbetween will not result in another fire I hope!!!!!!!!!!
HiJackZX1 is offline   Reply With Quote
Old 12-27-2007, 12:50 PM   #55
MySQL Error
Sonicxtacy02's Avatar
the carnetix 5v add-on PSU is what powers mine. You can use either that or the OPUS POL
03 Acura RSX Coupe
a K.I.S.S Flash, VB, and Autoit Programmer
Developer of: RRFusion, MovieTimes, (new)RRMail, & RR Plugin Manager
Coming Soon:RRChrome, & CentraFusion
Is Your RR Plugin Managed?
Old 12-27-2007, 01:47 PM   #56
Raw Wave
HiJackZX1's Avatar
OPUS POL? Im sure its right infront of my face, but i am to frustrated to think clearly.... Its seems that with this PC build I am having so many issues..... I thought buying the OPUS would be the end of all the problems, but looks like it isnt.... thankfully i am almost done when it comes to building... only have to build my XM adapter and thats it....
The way i connected the Belkin 4 Port USB Hubs is by using the 5v molex connector. Is that what you mean by POL?
PS: here is the hub I bought, it too comes with the y-cable. http://www.targus.com/us/product_det...sp?sku=ACH63US
Old 12-27-2007, 01:51 PM   #57
Raw Wave
Laidback's Avatar
It's a product, look in the mp3car store under PSU > Point Of Load
Laidback
Laidback Carputer
Laidback is offline   Reply With Quote
Old 12-27-2007, 02:02 PM   #58
MySQL Error
here's the carnetix unit
http://store.mp3car.com/Carnetix_CNX..._p/pwr-016.htm
and the opus pol
http://store.mp3car.com/Vehicle_Poin..._p/pwr-022.htm
i have both items and both work as intended.. the opus cost a little more money but with that u get more amps and a switchable point of regulation between 5v, 7.5v, 9v, or 12v. Either way you cant go wrong
03 Acura RSX Coupe
Old 12-27-2007, 02:25 PM   #59
Raw Wave
HiJackZX1's Avatar
and the opus pol
So I have to buy this on top of the 228.00 dollars I spent on the OPUS 320 Its just never ending........ I am so to the point that i want to just get hammer and go ballistic. I thought it would be as easy as just connecting the USB to the 5v rail
Old 12-27-2007, 02:30 PM   #60
Thats exactly what I did and all seems fine.
Disefyl is offline   Reply With Quote
Power USB Hub with M2? Arty13 Power Supplies 17 01-04-2007 09:16 PM
USB power question maxxell General Hardware Discussion 3 04-13-2006 04:06 PM
Usb hub power source? dmcdlrn Power Supplies 5 04-01-2006 03:03 PM
My USB/Wifi troubles. JPuma General Hardware Discussion 0 09-23-2005 12:44 PM
usb hub power problem modUlarBeing Power Supplies 2 11-21-2004 07:34 PM
