Go Back   MP3Car.com > Mp3Car Technical > General MP3Car Discussion
Old 04-15-2007, 04:18 AM   #31
It ain't easy being a green moderator
meddler's Avatar
Location: Steps out the front of Henson's workshop or Sydney
Quote: Originally Posted by shotgunefx View Post
For shutting down, I just have it hibernate after x minutes on battery.
That's an interesting way of doing it. I never thought of that. How do you go about powering it back up?
I am just about to start bench testing the laptop I got with all the add ons I have. ie. FM radio, GPS, voice commands phone control etc.
Chat on the mp3car channel on IRC
Server: efnet Channel: #mp3car
No irc client installed? Go to http://chat.efnet.org/. In the channel drop down box select "other" and type in #mp3car.
meddler is offline   Reply With Quote
Old 04-15-2007, 09:13 PM   #32
Raw Wave
shotgunefx's Avatar
On the 8600 (not on all dells though), shorting the power button on the dock will cause it to start when power is applied. (My old Latitude CPTv would just reboot endlessly if you did this).
I just put in a NC spring switch inline yesterday so I can reset if need be, as with the button jumped, you can't power off with the button so you have to remove the laptop from the dock. I've only had to do it once or twice when I was working some kinks out of suspend2, but it's good to have.
So when I turn off the car (the laptop is powered with IGN), it's on battery so acpi takes care of the rest.
shotgunefx is offline   Reply With Quote
Old 04-16-2007, 12:15 AM   #33
how woudl you know what dells they work on. i have a 600m and would like to know if this method will work. oh yeah whats NC spring switch inline, IGN and acpi?
bangumandoo is offline   Reply With Quote
Old 04-16-2007, 12:23 AM   #34
Raw Wave
shotgunefx's Avatar
Sorry for all the abbreviations.
Well, if you have the doc, unplug the power, hold the power button in and turn the juice back on, if it starts up (still holding the button) and doesn't keep rebooting, it should work.
NC is normally closed, meaning when I push the switch, it opens and breaks the contact between the power button leads, IGN means Ignition as in, the circuit is only powered when the key is in the on position, so when I take out the key, it kills the auto-air adapter and the system is now running on battery.
ACPI is (Advanced Configuration and Power Interface), what most computers use for power management.
suspend2 is a linux thing that handles hibernation, etc.
Old 05-04-2007, 05:16 AM   #35
meddler's Avatar
hey shotgunefx,
I am looking at buying a docking adapter link but I am not sure if this will suit the inspiron 8600's. Do these laptops use a d docking port. I can't find the information anywhere. If is does, it's got a pci slot Half decent sound card here we come.
Old 05-04-2007, 05:32 AM   #36
Raw Wave
shotgunefx's Avatar
hey shotgunefx,
AFAIK, The D-Docks work, as you can see from that page, there are a few docking products. I was originally going to get one with the PCI slot, but didn't due to the size. I'd double check with the seller, but I think it's the one. You are probably looking at near ~18" though front to back.
Double check the power requirements as well. Think they are >=90W
Old 05-04-2007, 05:34 AM   #37
meddler's Avatar
space isn't really an issue. i will end up removing the housing anyway. btw is there a power button on your docking port? I know you said there was one on the monitor stand, but I don't want to use a monitor stand.
Old 05-04-2007, 05:41 AM   #38
Raw Wave
shotgunefx's Avatar
There is a power button on the APR, I cant' imagine the full dock doesn't have one. Never cracked these docks open btw. The main reason I used the monitor stand was to protect the laptop to a degree from stuff bouncing around the trunk (plus it makes a handy mount and has a built in shelf for my other crap)
Old 05-04-2007, 06:01 AM   #39
meddler's Avatar
true. I think I will give it a go. I have sent the guy an email and pictures to make sure that the connectors are the same.
I also just spent 1 hour on hold to dell (read waste of an hour) to see if the laptop had a D port connector or not. The guy on the phone said that it did, so hopefully I can use this. Then he gave me the phone number for the parts department and told me to check with them.
Old 05-04-2007, 06:33 AM   #40
Raw Wave
shotgunefx's Avatar
Get a definitive answer...
http://www.motherboardpoint.com/t563...iron-8600.html
Old 05-04-2007, 06:53 AM   #41
meddler's Avatar
you are using the port replicator aren't you. Maybe it doesn't work and I should just get the APR just in case the D/Dock doesn't work
Old 05-04-2007, 07:40 AM   #42
Raw Wave
shotgunefx's Avatar
Hmm, something ate my post, anyway, some sellers on ebay list it as compatible with the 8600, so if Dell is dumb and can't answer the question, you could always buy from one of them and if it doesn't return it.
Yeah, I'm using the APR. I wanted a PCI slot, mainly for video, but right now, I'm running Dual heads and it's not a problem, nv-xconfig actually lists 3 (lcd, vga,dvi), so I think I could get tri-heads if I wanted to chop up the laptop (I don't ) there are also a few upgrades as far as video for the 8600s if you are interested.
Old 05-04-2007, 07:48 AM   #43
meddler's Avatar
yeah, I might stick with the APR and the audigy 2 ZS sound card for the time being. At least other people here are using the APR and it works
Old 05-04-2007, 08:20 AM   #44
Raw Wave
shotgunefx's Avatar
That's the one thing that bugs me, usb sound support in linux isn't that great, not for my SB Live! 24 anyway. Though my built in laptop audio is fine for my tastes. (I'm not a huge audiophile)
Old 05-04-2007, 08:23 AM   #45
meddler's Avatar
I think the audio onboard is pretty crap. I would have liked the pci slot to be able to add a decent sound card.
Question about Laptop Power on/off ashiq32 Laptops, Tablets, UPMCs, etc. 1 02-01-2007 09:11 PM
What size inverter for 200w PC power supply? plus ATX shutdown question JiminyC Newbie 8 08-23-2005 12:43 AM
N00b Power Question jamiewhittingha Power Supplies 15 03-25-2005 01:08 AM
Noob question about power supplies Jagojon3 Newbie 10 03-09-2005 12:35 AM
anyone wire a power switch to their Inspiron? sohr Power Supplies 3 06-07-2004 01:35 PM
