So the amp is actually turning on? That's interesting...
I would check like toaster said, make sure your amp isn't going into protection mode. If you don't know, check the outputs with a multimeter.
If the amp is on, and not in protection mode, then it's either sending a signal and it's not being played because the subwoofer isn't properly hooked up, or it isn't receiving a signal from your head unit to output. First check your RCAs. Make sure are all properly connected in the correct spots. Then check your subwoofer to make sure something didn't rattle loose or mistakenly not get reconnected.
