Go Back   MP3Car.com > Mp3Car Technical > General MP3Car Discussion
View Poll Results: Have you had problems with cold weather and your carpc?
Yes 25 34.72%
No 47 65.28%
Voters: 72. You may not vote on this poll
Old 02-13-2007, 01:10 PM   #1
Has Cold Weather Killed your Carpc?
My hdd in my HP xe3 laptop died which I believe is from the cold weather. Chicago has -7*F -30 windchill. It was actually doing some crazy clicking of death the other day which was also subzero temps, and it finally died. New harddrive from the local tigerdirect outlet works great now, but I'm not putting the laptop back in the car anytime soon.
Has this happened to anyone else with more carpc experience? Since this is the first winter with my carpc, I didn't know what to expect.
Cars:
2001 Lexus es300 carpc Complete!Lexus es300 thread
CarPC: Hp laptop, Lilliput 7'' ts, ig3, bluedevil skin, hauppage tv tuner, bu-353, griffin powermate, backup camera, ps2, headrest monitors, nightvision camera.
2006 Lexus es330 next project.
spiike is offline   Reply With Quote
Old 02-13-2007, 01:35 PM   #2
what part of chicago u live in. i'm actually hearing the hard drive start to click too. so i have been takin it easy on the computer and have just been using the headunit. man it's been getting cold around here. btw im not even using a laptop drive im using a regular 3.5.
05k20A3 is offline   Reply With Quote
Old 02-13-2007, 02:41 PM   #3
I'm out in Naperville. If your harddrive is clicking I would start to back up your data, since it is the first signs of a dying harddrive.
Cars:
Old 02-13-2007, 04:22 PM   #4
ShawJohn's Avatar
Sounds like it was on its way out anyway
My 3.5" works fine down to -5C
ShawJohn is offline   Reply With Quote
Old 02-13-2007, 11:44 PM   #5
yeah im here in niles/glenview area and this weather has seriously been gettin on my nerves. the inside of my car is all dirty n ****. my car went from black to white cuz of all the salt and so did my floor mats. luckly i havent really had any problems with the computer booting up, but i do have a problem with my wifi adapter. ill try to connect to my network and itll say connected signal strenght good then a sec later it'll say wireless networks available and when i click on it, it wont be connected to any wireless network. so i keep clicking my network or anyone else and it just does the same thing. ive only had the adapter for like 3 weeks. its http://www.newegg.com/Product/Produc...82E16833130111 this here. it works really good and it has some good reception but i cant get it to stay connected for more then half a second.
Old 02-14-2007, 12:49 AM   #6
Every now and then mine won't boot because it's so cold, the HDD freezes up, so I just wait a few minutes and try to boot again and it always works. This almost never happens since I have remote start though. I wouldn't say that's a problem though, it was expected, that's why I have a switch on my ignition line going to the psu
spoonraker is offline   Reply With Quote
Old 02-15-2007, 04:22 PM   #7
my carputer doesn't boot up if it's less than -5-10*C. My CF card doesn't like the cold.
Also, my usb hub doesn't work very well in the cold either
dyne is offline   Reply With Quote
Old 02-15-2007, 04:32 PM   #8
Fusion Brain Creator
2k1Toaster's Avatar
-20C and still cooking.
Old 02-21-2007, 06:25 PM   #9
I voted no but after reading the thread I realize that likely all my infrequent problems over the last couple months could be related to cold weather. For a couple of weeks I had some intermittent startup problems. Like sometimes it wouldn’t start and I would have to flip it off and on a few times to get it to go.
I also had a couple of times when the screen went either white or stayed off and I had to cycle power a few times to get it to go.
EricE is offline   Reply With Quote
Old 02-22-2007, 01:03 AM   #10
Yep, cold weather keeps my Toshiba A85's hard drive from working when it gets too cold. Waiting about 5 minutes usually solves that. That's okay though, I have to put my car away 3 months out of the year so whenever it starts having problems booting I know it's soon time to put it away .
2001 SS Camaro carputer
scotty562 is offline   Reply With Quote
Old 02-22-2007, 01:13 AM   #11
W3bMa5t3r's Avatar
Location: Washington, DC - Alexandria, VA N/W Area - NOVA
I voted no. We've had around -10C (14F) (actual/not windchill) at times over the past week or two here in the Northern Virginia area, the only slight issue I've had is the touchscreen being a bit funny in reaction to my finger, but within a few minutes it was back to normal. No boot issues at all.
W3bMa5t3r is offline   Reply With Quote
Old 02-23-2007, 04:13 PM   #12
EvilLawnGnome's Avatar
I had a problem once a couple of weeks ago. When I booted the computer, it said that it couldn't find the startup disk. I let it run for another minute or two then pushed restert. Booted right up after that. I guess it just needed to heat up a bit.
Build Two:
Planning: [==========]100%
Purchasing: [=========-]90% (Other 10% is still in Beta)
Design: [=======---]70% (Still trying to get into my schools protolab)
Install: [=========-]90% (Still working on screen beisel)
EvilLawnGnome is offline   Reply With Quote
Old 02-27-2007, 03:31 PM   #13
david69leonard's Avatar
the only prob. ive had is the contrast on my TS is a little off, but the PC boots just fine
david69leonard is offline   Reply With Quote
Old 02-27-2007, 04:48 PM   #14
Random reboots, relay cycling on/off when I first start car...only happened since it was cold. Think it may just be related to the low-voltage setting, but unsure. Fixed my overheating problem though
MII-12000 / Ampie / Lilliput 7" / BU-355 / PicoPSU / uSDC
Currently: Enjoying the setup, but always contemplating my next move...
rsd212 is offline   Reply With Quote
Old 02-27-2007, 09:47 PM   #15
Yep, dead USB hub.
Might just be a coincidence, though
Cold Weather may have killed HD Smitty0881 Newbie 30 02-16-2007 02:28 PM
Cold Weather LCD Question rodgers412 LCD/Display 6 02-10-2007 01:19 AM
Radar Gun Killed My CarPC? buurin General MP3Car Discussion 34 06-03-2006 04:53 PM
CarPC audio problems aal2000 Car Audio 2 09-07-2005 09:40 PM
Cold weather hurt it at all?? Cue General MP3Car Discussion 4 01-10-2001 11:40 AM
