The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General MP3Car Discussion
Thread Tools Display Modes
Old 02-14-2007, 02:30 PM   #1
shrinkydinx's Avatar
My Photos: (0)
what could be causing my windows to not sut down?
the last two times ive used my car, windows didnt automatically shut down when i turned off my car... and it caused the battery to drain completely..
what are some common causes for windows to hang like that? i havent changed anything since it started happening... before the past few days it had only happened like twice in the last year, but now every time i turn off my car, roadrunner is still on and music is still playing when i turn it on again...
carputer - done.
shrinkydinx is offline   Reply With Quote
Sponsored Links
Old 02-14-2007, 02:47 PM   #2
guizai's CarPC Specs
Vehicle: 89 BMW 325iT
My Photos: (0)
what startup/shutdown controller are you using? If it's still working when you get back then it means that there's no signal for a button press. Check your connections.
guizai is offline   Reply With Quote
Old 02-14-2007, 03:04 PM   #3
Fusion Brain Creator
2k1Toaster's CarPC Specs
2k1Toaster's Avatar
Vehicle: 2001 Honda Civic EX Coupe
My Photos: (1)
Or if you have it to never "pull the plug" and stay in standby or something, if a driver causes it to hang, then it wont shut off.
Most common are driver issues. Common of those, is USB stuff.
Sponsored Links
vB code is On
Trackbacks are Off
Ahhhhh Windows Can Blow Royally Sidewalksalvage Off Topic 10 01-25-2007 01:17 PM
New Frontend for Windows and Linux gbr Other Cool Front Ends 66 10-26-2006 05:08 PM
Installing Windows 2000 Pro on a 1GB Microdrive JeremyM WinNT Based 2 05-07-2005 09:56 PM
Windows Freeze When Crank, Crank again windows unfreeze antimatter Power Supplies 37 07-27-2004 12:40 AM
Windows ME and MediaCar dug1967 MediaCar 15 04-15-2004 01:30 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
