Go Back   MP3Car.com > Mp3Car Technical > General MP3Car Discussion
Old 03-22-2007, 05:37 PM   #1
Will this PC work for a car?
Hi Guys,
I'm new to this hobby and I been reading around a bit. Wanted to ask if this pc will work for a car. I notice that building one would cost alot. I was at compusa tha other day and i saw a acer aspire minitower which look small enought to fit under a car seat. Is there alot of moding that require if i was to purchase a pc like this that has already been built. Thanks for any input.
Newegg.com - Acer Aspire ASL310-UD631A Core 2 Duo E6300(1.86GHz) 1GB DDR2 320GB Intel GMA 3000 Windows Vista Home Premium - Retail
tlr_justin is offline   Reply With Quote
Old 03-25-2007, 08:12 AM   #2
pasan's Avatar
Quote: Originally Posted by tlr_justin View Post
Hi Guys,
Hmmm I think building a PC for car is more fun.
Pasan...
pasan is offline   Reply With Quote
Old 03-25-2007, 10:07 AM   #3
Looks like it has a DC input of some sort, does it say on the case what input it accepts like 12V or 19Vdc or something ?
Transflective Lilliput 8", LV-677DC Core Duo 1,83Ghz, , Mpegbox uSDC20D, Shuttle Express, HQCT, PG XS6600 http://carpc.boyakasha.dk
_dopehead_ is offline   Reply With Quote
Old 03-25-2007, 10:31 AM   #4
Neither darque nor pervert
DarquePervert's Avatar
Hi Guys,
Understand that any PC can work in a car. Some PCs have issues that are difficult to overcome.
As someone mentioned, it has a DC input, which would likely be served by a Carnetic PSU like the P1900. It all depends on the output voltage of the power brick:
Remember that heat and power consumption are two factors you have to consider.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 03-25-2007, 11:34 AM   #5
Hey tlr_justin, Welcome to MP3Car! Don't focus on the power hungry pc for your Carputer unless you're thinking about making it a hardcore gaming rig in your car... and if you're not worrying about a budget, because Core2Duo can set you back a few. Try a standard P4 Motherboard with a P4 1.8ghz processor. I have a MSI Socket 478 Motherboard with a 1.8ghz Processor and a Gig of ram, and it works wonders. I'm going to move this into my car soon. So don't focus on PERFORMANCE. You can find something that will run solid in your car but you dont need anything power hungry. Hope that helps and once again WELCOME to our world :-) *You'll understand once you're here for a while*
"PEBKAC - Problem Exist's Between Keyboard and Chair"
Methodic Virus is offline   Reply With Quote
Old 03-25-2007, 12:41 PM   #6
treetop777's Avatar
Read about some difficulties with Vista so do some research..
treetop777 is offline   Reply With Quote
Old 03-26-2007, 11:40 AM   #7
ty guys,
It was an example. I did read before that member suggest not have the most powerful pc in car. and i did saw a acer with the P4. just didnt know if going this way would work or do i have to built one. i built all of my home pc but never a carpc so i don't know if there were a huge difference, i figure it would be safe to ask before i act. I'm never afraid to admit that I'm stupid, it just a way for me to learn thank you very much for all the helpfull advice.
I forgot to say that i got a 400watt inverter for advance autopart, which will be my powersource. would tat be ok for the regular power connection of this type of pc?
Old 03-26-2007, 11:57 AM   #8
It all depends on how you want the fucntionality of the carpc to be. Inverters cant be tapped into the ignition to automatically start and shut down the computer. You can buy a startup/shutdown controller or better yet get a Carnatrix PSU to power it....
2002 Mitsubishi Galant
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
Souund Blaster Audigy2 NX
OPUS ITX PC Case
Cheekz185 is offline   Reply With Quote
Old 03-28-2007, 10:36 AM   #9
MP3DUB's Avatar
You can build some simple circuits to turn on an inverter/pc automatically. I don't use an inverter to power my pc any longer (onboard dc-dc instead) but I still use the inverter, and have a circuit to turn both on with the stereo.
Edit: That said, if I were starting fresh (and didn't have 6 years of baggage) I'd go straight dc-dc for everything. Makes for a much more efficient and much cleaner install.
-Nick
_____________________________
Monthly MP3Car Chicago Meets
www.mp3vw.com Last updated: 07/07/2008
MP3DUB is offline   Reply With Quote
Old 04-18-2007, 08:08 PM   #10
I actually have an older model of this same computer, comes with a amd 64 3500+ and 512 ram but the same pretty much otherwise. i plan on using this for my carputer as well, the only real problem im having is that it gets real warm. not a problem running under regular circumstances but i figure in a car in the summer i will have issues. more then likely i will build a new case with only a slightly larger footprint in order to accomondate a fan or 2. If you live close to a circuit city they may have these open boxed which is how i bought mine with a warentee. mine cost me 350$ practically brand new before the warentee. Vista may be problematic with gps drivers and some of the programs, more then likely all the front ends actually.
jddelrosso is offline   Reply With Quote
Old 04-19-2007, 03:25 PM   #11
maniaxzero's Avatar
according to newegg, the dimensions are 2.4" x 9.8" x 7.9" which is perfect for me. They even fitted a dvd drive and a 3.5" HDD in there. Is there any way for us to buy just the case w/o the computer components?
maniaxzero is offline   Reply With Quote
Old 05-09-2007, 09:10 PM   #12
purchasing the case
you can call acer they are located in Temple Tx. if the item is orderable / saleable. they can sale it to you.. If you want to order it i can get you guys the part numbers for it..
mchipser is offline   Reply With Quote
Old 05-09-2007, 09:42 PM   #13
EL CAMINO's Avatar
interesting, can you do that? post it here please!!!
EL CAMINO is offline   Reply With Quote
Old 05-10-2007, 12:44 AM   #14
sure
i will post them tomorrow when i get to work
Old 05-10-2007, 06:18 PM   #15
acer parts
there are more than 10 parts that make up the chassis.. DO you want all the parts? please take a look at this and see if it is even worth it...
Car PC & Bose/Philips CCR800 Aux input Gamer64 Car Audio 1 01-25-2007 04:13 PM
VIA and Mini-box Announce First Sub-$300 Car PC Kit Goofus General Hardware Discussion 27 03-13-2006 12:28 PM
Car PC EZ 2.4 SDC/Inverter Controller - NOW Avail! hd54321 Power Supplies 1 02-24-2005 01:42 PM
New toys for the pc car gizmomkr General Hardware Discussion 10 02-06-2002 05:55 PM
