Old 05-15-2007, 12:39 PM   #1
GPS receiver with both bluetooth and usb?
Is there a GPS receiver with BOTH USB and Bluetooth ? Most bluetooth dongles I have had lose connection intermittently, especially in downtown areas.
bathukoli is offline   Reply With Quote
Old 05-15-2007, 01:14 PM   #2
Neither darque nor pervert
DarquePervert's Avatar
One or the other.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 05-15-2007, 01:29 PM   #3
mwmcginn's Avatar
I would look at some of the pharos units, for the gps500 it can be docked for use in bluetooth or attached via usb. The dock also works for the microsoft reciever.
Mike M
2006 Accord VP Sedan
My worklog
http://www.mp3car.com/vbulletin/work...-dads-car.html
mwmcginn is offline   Reply With Quote
Old 05-15-2007, 05:21 PM   #4
blauhung's Avatar
just curious, but why would you need both?
(\__/)
(")_(")
I have a Worklog, but I have to take pictures as it's completely out of date now.
blauhung is offline   Reply With Quote
Old 05-15-2007, 07:16 PM   #5
mwmcginn's Avatar
I dont know about the author (so shut up right?) but I want the BT for use with my pocket pc, and usb for the carpc (since I dont want to worry about charging it seperatley.
Mike M
My worklog
Old 05-15-2007, 08:53 PM   #6
Raw Wave
USB for the car PC, BT for cellphones/PDAs.
Use a good serial GPS then connect a SERIAL to USB dongle and a SERIAL to BT dongle. Only use the TX line of the GPS though. The RX are used for configuring the GPS, you can connect this on the SERIAL to USB so your GPS can be configured via USB (only).
Chris31 is offline   Reply With Quote
Old 05-15-2007, 11:31 PM   #7
yep
Holux GR 236
http://cgi.ebay.com.au/New-Holux-GR-...QQcmdZViewItem
dom00 is offline   Reply With Quote
Old 05-16-2007, 03:37 AM   #8
Thanks for the replies guys. For some reason, the connection between my globalsat 338 and my laptop fails randomly in the LA downtown area. While I would like to have something better (a USB) for the laptop, I need the BT feature for the phone. I was wondering if there is a single solution.
Mike, do you know if the gps 500 unit can work on both usb and bt simultaneously ?
Globalsat BT-359W Bluetooth GPS Receiver PCcivic25 GPS 7 10-06-2006 03:55 AM
Getting Started with GPS grepzen The FAQ Emporium 12 09-26-2006 06:54 AM
WTT: Bluetooth GPS for USB GPS arebelspy Classified Archive 6 09-29-2005 12:53 PM
Bluetooth or USB GPS receiver? Shearer GPS 13 08-05-2005 06:32 AM
USB GPS receiver For Ext Antenna? McGreggor GPS 4 08-01-2005 05:07 AM
