Quote: Originally Posted by
popztarr
I've been running a trialversion of Centrafuse the last few days, very promising software! But there's a few things I don't like:
1) When the car is moving you can't access the navigation menu, of course I know this is a securitything. But it doesn't make any sense when you can access every other program and menu. As an example I was able to program and connect my mobilephone with bluetooth and ports and everything while the car was moving, which is an much more complicated operation than finding an gas-station nearby in the navigation menu. Doesn't make any sense to me, is it possible to turn this stupid security-thing off? I mean, when you drive on a highway where it's not allowed to stop the car, and you are nearly out of gas, there should be a possibility to search for the nearest gas-station even if the car is moving.
2) I don't like the securitywarnings in the startup of Centrafuse either. Having to click ok twice each time I start the program is irritating. Several times the warningswindows goes behind the window of centrafuse, and you are not able to operate the program at all, before going behind it and click OK twice (The first time I didn't even realize what whas the problem. I thought the program had crashed, and restarted my computer the hard way).
Some questions at the end:
1) Centrafuse doesn't change the look when I change to another skin I downloaded. What to do to make it use the new skin?
2) I also downloaded some of the plugings available at the Flusmedia webpage, but I don't find away to integrate them. How to do to integrate new plugins?
Solved the plugins integration, they just installed in the wrong map. Haven't got any closer with the skin issue.
Found something that maybe will solve the phone-issue
here Worth a try after all, don't had the time yet...
Also found a solution on accessing the navigation menu while driving and removing the security warnings in the startup. Just added "-nowarning -nolimit" after the centrafuse.exe like described
here, and both the warning and the accessing navigation menu limitation is gone (haven't added it into a batchfile though).
