The MP3car.com Store
Thread Tools Display Modes
Old 09-04-2002, 09:39 AM   #1
My Photos: (0)
Angry Haicom 202E
I cant seem to find out how to get my GPS to work... its a Haicom model 202E bought from gpsw.co.uk
anyway.. iwe installed the latest driver from the webpage haicom.com.tw (which were for 98/me & w2k)
When i hooked it up for the first time. The Computer said, new USB device found.. I installed the driver, and it is after this the problem starts.. The mouse starts moving around the screen. Clicking and grabbing icons around, drop down the menu's .. sigh.. anyone know what the problem could be?
the driver said that if would install som sort of a usb to serial driver. ?
*strange* arg
Do GPS's make a lot of interferance ... ?
best regards
Richard
NORWAY
t0ffluss is offline   Reply With Quote
Sponsored Links
Old 09-04-2002, 09:47 AM   #2
Registered User
Vehicle: Ford Fiesta
My Photos: (0)
MMMmm I have the HI-201E, which is a ps/2 & serial connection and have no problems at all (infact its ******* wickied )
but more on your problem, do you have a serial/usb mouse by any chance? because it sounds like its taking over the mouse driver...
sorry couldnt' be anymore help!
dave- is offline   Reply With Quote
Old 09-04-2002, 09:53 AM   #3
My Photos: (0)
Post
no problem
hmm.. no.. have a PS/2 mouse... not serial nor usb..
wierd.. hope someone has a solution for my case...
richard
Old 09-04-2002, 10:06 AM   #4
Registered User
Vehicle: Ford XR3i Cabriolet
My Photos: (0)
This has been discussed a few times before and is a common problem with GPS and Windows, because Windows is too stupid to tell the difference between a serial mouse and a GPS.
I think the easiest way to stop it detecting as a mouse would be to plug in a serial mouse, boot windows and let it detect it, then choose disable device in device manager. That should stop it from searching for another serial mouse (your GPS) in the future.
Another solution is to change your mouse to a serial type and plug it into COM1, and your GPS into COM2. Windows will only install one serial mouse at a time.
Do a search on the board for more info.
(=========-) 99% complete
AMD K6/2 500 @ 450mhz to keep heat and power usage down, 64Mb, slim CDrom drive, 64mb USB pendrive for MP3 transfer, 10Gb 2.5" drive for MP3, USB>RS232
All jammed in external CDROM drive case.
Kenwood KVC-1000r In-Dash LCD. x-10 MouseRemote. Destinator V2 Gps. DC-DC with onboard Shutdown controller.
phil.45 is offline   Reply With Quote
Old 09-04-2002, 01:24 PM   #5
My Photos: (0)
thx phil!
ehm.. the GPS is a USB.. u keep repeating about serial thingy ?
have you gotten your info straight? or?.. ehm.. i dunno.. i did notice that the usb was detected as a microsoft ball mouse hehe
ehm... Haicom has the lamest driver support.. maybe ill try the GPS on windowsME
regards Richard
anyone else up for any info on this?
thx
btw: where the heck does windows put it's USB devices in hardware manager?? ..arg
Old 09-04-2002, 03:43 PM   #6
MP3DUB's CarPC Specs
MP3DUB's Avatar
Vehicle: 1993 VW Passat, 2006 VW Passat
My Photos: (7)
Anything usb should be under the usb root hub, but, as was said, windows does have the habit of making serial gps's into serial mice in the device manager, and the gps is still a serial gps with a usb bridge on it, and a driver that makes windows things its another serial port, which is why windows turns it into a mouse. So you can blame windows and not the driver .
-Nick
_____________________________
Monthly MP3Car Chicago Meets
www.mp3vw.com Last updated: 07/07/2008
MP3DUB is offline   Reply With Quote
Old 09-05-2002, 06:28 AM   #7
Registered User
My Photos: (0)
Quote:
Originally posted by t0ffluss
[b]thx phil!
B]
See MP3DUB's post. Windows couldnt give a toss what the physical connection is, only how it is presented to Windows by the driver. Yes it connects via USB, but only because it has an onboard Serial>USB convertor. Its like those seperate Serial>USB connectors you can get which add another DB9 serial port to your PC.
Old 09-05-2002, 02:13 PM   #8
My Photos: (0)
ok bump! btw
so, i got the GPS working today wee
another problem came up... the Roadmap software found the GPS and it was setup thru the USB 2 Serial Bridge... (to com5) anyway.. The GPS searches for satellites... but does'nt find any..
arg
even outside the house it does'nt find any satellites...
is the Hi202e supposed to have a extra antenna?
regards
Richard
Norway
Old 09-06-2002, 04:42 AM   #9
Registered User
My Photos: (0)
How long did you give it? Some GPS receivers can take up to 10minutes from cold start to find the location.
Sponsored Links
vB code is On
Trackbacks are Off
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
