The MP3car.com Store
Thread Tools Display Modes
Old 07-07-2007, 05:08 PM   #1
Pandaman72's CarPC Specs
Pandaman72's Avatar
Vehicle: Ford Falcon XR6 Turbo
My Photos: (0)
Cacheing Google Earth Roads
I've been playing around with Google Earth on my carputer using Goops to track my movement. I've got no dramas with the maps while on the road because I have cached 2GB using the Google Earth Cache Builder.
I have also used Netstumbler to plot all of the WAP's around town then used GPS Visualiser to overlay them in Google Earth.
So I've got the maps cached, I've got the WAP's saved and Google Earth can display them without an active internet connection. My question is - is it possible to cache the street names (Google Earth overlays them from Google Maps) so that they can display while I am on the road without an internet connection?
I have experimented with simply copying the images from Google Maps and overlaying that image onto Google Earth, but this would take months.
Has anybody else tried this?
Thanks,
Panda
Car - Ford Falcon XR6 Turbo, footwell lights, Pioneer front speakers
Carputer- P3 966MHz, 256MB RAM, 200GB HDD, 300W PSU
Pandaman72 is offline   Reply With Quote
Sponsored Links
Old 07-22-2007, 02:31 PM   #2
My Photos: (0)
A different google cache app with street names
I found this app http://bx11.gratis-server.de/gecacher.htm and used it to cache alot of Connecticut with street names. I am able to use Google Earth with streetnames while disconnected from the Internet.
Now I just need ot find out how to do routing while offline ....
John
johndickjr is offline   Reply With Quote
Old 07-24-2007, 06:39 AM   #3
Pandaman72's Avatar
My Photos: (0)
Quote: Originally Posted by johndickjr View Post
I found this app http://bx11.gratis-server.de/gecacher.htm and used it to cache a lot of Connecticut with street names. I am able to use Google Earth with streetnames while disconnected from the Internet.
Link was no good - got a file not found error.
Panda
Old 07-24-2007, 03:59 PM   #4
My Photos: (0)
Panda
link worked for me.. downloaded the file.. will play with it a bit later.
rotozuk is offline   Reply With Quote
Old 07-26-2007, 09:09 PM   #5
My Photos: (0)
Looks like he/she hosted it on a free service with a download limit that was reached. I have put it up with my ISP at http://homepage.ct.metrocast.net/~jo...r/GECacher.zip
I don't know how long this link will be valid so get it while you can.
Last edited by johndickjr : 05-14-2008 at 11:20 AM. Reason: Updated URL due to ISP change.
Old 07-27-2007, 08:31 AM   #6
leatherboy's Avatar
Vehicle: Ford Focus 2.0 Zetec
My Photos: (0)
Does anybody know if we can cache pictures too?
leatherboy is offline   Reply With Quote
Old 07-27-2007, 10:09 AM   #7
My Photos: (0)
so are you gonna be able to use this as your maps in freedrive etc?
neil_ross is offline   Reply With Quote
Old 07-28-2007, 11:40 AM   #8
My Photos: (0)
Cacheing of Google Earth is for use with Google Earth only.
Check out this thread for using Google Earth instead of Freedrive, etc ...
http://www.mp3car.com/vbulletin/rr-p...th-plugin.html
Most GPS apps use local maps.
GE uses their maps on a download as necessary basis, and because you probably don't have internet connectivity in your car, you can use this application to pre-load the images to GE's local cache file.
You do NOT need GE Pro in order to use it as a full GPS application (Or so I read, just waiting to get my own GPS puck).
You can preload your trip, and move the screen as you drive (not recommended ... don't sue me), and as long as you have cached the route to the level of detail you need, then you don't need an internet connection.
Hope that helps.
JD
Old 07-28-2007, 11:58 AM   #9
My Photos: (0)
Here are the instructions from the unavailable link above ...
How to use:
Start GEcacher. If your firewall asks, allow it to access the net.
Switch to Configure tab
On first run verify (and modify) settings if you use a proxy server for HTTP or installed Google Earth to a nondefault folder:
Caption...: This window will be shut down on Reload.
EXE...: This is the Google Earth application. On Reload this will be started.
Local...: GE cacher will act as a HTTP proxy on this port.
Read timeout...: How long GE cacher should wait for a read operation from the Google Earth servers (seconds).
(Don't panic, you should not tamper with these settings usually!)
Proxy configuration is read from the registry. Check (uncheck) the Use Proxy and modify proxy configuration, if needed.
Switch to Use tab.
Choose a location and filename for the Network link KML file, this will be needed within GE in a sec.
Click on Start caching then on Stop caching after a second. Now a KML file was created as specified in the Network link KML.
Now click on Reload Google Earth... and wait until Google Earth loads. If your (proxied or direct) connection is working you should see some activity around the TX bar and next to it. This means Google Earth is connected to its servers through GE cacher.
Open Tools -> Options -> Control tab. Set Fly-to and Tour settings Speed: sliders to Fast.
Create a new network link (Add / Network link...) in Google Earth as follows:
Fly to View on Refresh must be checked.
Uncheck the checkbox in Places before GE cacher, and navigate to the area you are interested in.
Set the top left and bottom right coordinates (or any two opposite corners) of this area in GE cacher. Set Visible area width to the required level (~ Eye alt.). (The default was good enough for my needs)
Next to Area count progress bar the number of required snapshots to cache the whole area is displayed.
Check in the checkbox for GE cacher in Places then press Start caching. Next to ETA an estimation of the remaining time will be displayed.
Google Earth will go frame by frame for the required number of snapshots required.
My personal recommendations:
Set GE to display Lat/Long in decimal so you can get accurate numbers into GECacher.
Input Lat/Long numbers into GECacher with at least 3 decimal places accuracy, Lat of 71 is a long way away from Lat 71.06 when it comes to required snapshots.
Old 07-28-2007, 10:10 PM   #10
Pandaman72's Avatar
My Photos: (0)
Yep, I used GE Cache Builder and it worked a treat for the maps, but what it did not store is the street names etc.
That is what I want to cache - not the maps
Panda
Sponsored Links
Old 07-29-2007, 10:20 PM   #11
My Photos: (0)
It caches the street names for me. You need to have the street name layer turned on while caching, and make sure you are zoomed in close enough for the names to be displayed.
I think you can cache any layer that is on while running GEcacher, like restaurants, borders, town names, etc.
My only wish is that it would also allow you to get directions off-line.
Has anyone heard of a way to do that?
JD
Old 07-30-2007, 04:13 AM   #12
Pandaman72's Avatar
My Photos: (0)
I actually had every layer turned on when cacheing, but it does not display it when disconnected
Panda
Old 05-13-2008, 11:01 AM   #13
greatwhite's CarPC Specs
greatwhite's Avatar
Vehicle: 2004 Chrysler 300M Special
My Photos: (1)
Hate to "necro" an old thread, but does anyone have a copy of ge cacher that they can make available for download?
As mentioned above, http://bx11.gratis-server.de/gecacher.htm is no longer online...........
Leonardo Da Vinci
greatwhite is offline   Reply With Quote
Old 05-14-2008, 11:19 AM   #14
My Photos: (0)
Link updated
My ISP changed hands so my repost of the cacher is located at
Have fun,
John
Sponsored Links
vB code is On
Trackbacks are Off
Needed: BETA Testers for Google Earth Plugin guino RR Plugins 407 07-04-2008 11:32 AM
Google Earth -Programming zapwizard MacCar 19 03-10-2008 10:00 AM
Google Earth with VIA EPIA EX10000 jamedinar GPS 0 06-21-2007 05:42 AM
Google Earth: How? sux89 MacCar 9 03-15-2006 08:05 PM
Embedding Google Earth to RR Asskick Road Runner 11 02-10-2006 09:44 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
