Old 07-07-2007, 10:53 PM   #1
Getting Pharos iGPS-500 to work after resume from hibernation
Hey.
I just got a Pharos iGPS-500 hooked up to my carpc. This is the same gps that is bundled with Microsoft Streets and Trips. The problem is, I cant get the GPS working after resuming from hibernation other than to manually unplug and replug it. iGuidance (embedded in Centrafuse) simply wont see my GPS unit. However, when I hibernate then resume a few minutes later, the GPS works fine. It doesnt work if the resume is an hour or more long.
Can anyone give some advice on what I can do? Could I do some software based tweaking? Or do you think giving the GPS unit constant power would work? If so, do I simply build a regulator (probably from a lm317) which gives out constant 5 volts and connect that to the GPS, while keeping the two data pins on the USB connected to the computer? What do you guys think?
nobb is offline   Reply With Quote
Old 07-08-2007, 12:55 PM   #2
Nevermind...I fixed it. I used the drivers from the CD instead of letting XP update it via Windows Update. I also plugged the GPS into a USB port built into my motherboard, rather than using the USB on my addon USB 2.0 PCI card.
Old 07-08-2007, 11:58 PM   #3
To tell you the truth, I never got mine working consistently from hibernate. It work 19 out of 20 times but that always bothered me. Hopefully I just got a defective one and yours fairs better.
-Chris
garto is offline   Reply With Quote
Old 07-09-2007, 12:09 AM   #4
Hmm...Ive only resumed from hibernation and used my GPS for less than 5 times (I just recently got the unit). Its worked perfectly since I did those fixes mentioned above, but I guess I shouldnt get too happy yet =(.
Prison vs Work ACHIEVER Off Topic 20 04-15-2005 02:53 PM
Resume from Hibernation Centrafuse neon_eddy CF Bug Reports 7 04-01-2005 02:03 PM
Connecting Pharos iGPS Dongle Magma GPS 3 01-11-2005 10:08 PM
Can't Get SAPI to work after Resume Jstarko0329 PowerVoice 5 10-18-2004 09:24 PM
XP hibernation doesn't work nicgalla Software & Software Development 3 08-03-2003 10:18 AM
