09-06-2007, 03:35 PM
#76
what program says not your version ?
Transflective Lilliput 8", LV-677DC Core Duo 1,83Ghz, , Mpegbox uSDC20D, Shuttle Express, HQCT, PG XS6600 http://carpc.boyakasha.dk
09-09-2007, 04:38 AM
#78
Just tried to access the IndieVolume web site.
They seem to have disappeared. I keep getting a 404 error.
09-09-2007, 06:07 AM
#79
That would probably mean that you aren't running 7.0 already.
09-09-2007, 12:56 PM
#80
Disk cover says PC Navigator 7 but on the Disk it says Navigator 7.1
Version it 7.1.17
Thats why I guess.
Paul
09-10-2007, 01:20 PM
#81
Version it 7.1.17
Thats why I guess.
Paul
Any ideas anyone???
09-10-2007, 03:20 PM
#82
Did you try to just run your 7.1 version with the cmdline params for window mode ? If your current version is 7.1.17 then using the patch to 7.1.13 would be a downgrade, maybe thats why it is saying this.
try this perhaps : C:\Program Files\Navigator7\PC_Navigator\PC_Navigator.exe --window_border=no --window_position="0,0,800,600"
09-10-2007, 04:19 PM
#83
cheers, will try tomorrow
Paul
09-15-2007, 01:27 AM
#84
PC Nav + RR + iDrive. Works out of the box
I have been messing around with PC Navigator 7 on my Everun. Seems like a good value solution. Especially for Europe. Nice touch interface.
Had been running it with iCT but have switched to RR with an iDrive skin.
Initially I had problems but I re-installed a new version of RR last night and it seems to be working 100% windowed out of the box.
I used the RR installer from here. (CarPCnet) and just set the GPS external path to pick up Navigator and set the window name to 'Navigator'
It embeds without a problem but leaves a menu bar on the LHS. Sorry about the terrible pic but you get the idea.
09-26-2007, 03:58 PM
#85
Just getting round to playing with my v7
the guide you done dopehead, does that apply if you use the alternative launcher? ie if i just give the path to the launcher as my gps ('external'), will that then embed streight without all the messing with editing the skins?  , i want it to be generic so that it will work whatever skin i load
cheers
Also anyone know to install more maps (other than re-installing?) im thinking just extract the rar files in the root folder?
CarPuter Progress:
Planning:-----> [||||||||||] 100%
Hardware Buying:-> [||||||||||] 100%
Software:-----> [||||||||||] 100%
Installing:-----> [||||||||||] 100%
Current Project= Making skins in photoshop...
09-27-2007, 09:42 AM
#86
Yes actually, once you have the windowsize update on there i have recently found that just putting in pcnavigator as external GPS menu in RRconfig will resize the window all on its own. No need for the special launcher anymore.
09-27-2007, 11:55 AM
#87
sweet, is the update the one from the link on this page? v 7 1 13-1?
CarPuter Progress:
09-27-2007, 02:35 PM
#88
Yes
09-27-2007, 02:59 PM
#89
Yes
Did you find a solution to your map problem as well?
CarPuter Progress:
09-27-2007, 04:02 PM
#90
If you mean with the roads not being found in the right city when searching...then no, i am currently thinking of using the sdk to search through the data myself, and then putting the coords in using the TCP send routes function in pcnav7
| Thread Tools |
| Display Modes |
Linear Mode
