Old 02-04-2008, 03:01 PM   #121
Update on Importing Data into PCN 7.
I was getting a crash on:
Find and Navigate / Imported Data / <Left Click> on 'Data List Title'
By trial and error have discovered that the Prog. does not like:
[ ’ ] but will accept [ ' ] as part of the fields in the data.
Will report any further findings, but so far looks very promising.
Best
BTW - If we wanted to publish a list of Keyboard Entries which are recognized, how can we set it up in the Forum so that new ones can be added.
e.g. CTRL M = Menu from Map Screen - Page Up/Down for Zoom In/Out - Arrow Keys for N/S/W/E - Tab and Arrow Keys to Navigate Menus.... - In Some Menus <Return> = Enter in others <Right Arrow> = Enter
OR - in the words of Peggy Lee's Song - Is that all there is?
FredFlange is offline   Reply With Quote
Old 02-29-2008, 04:13 AM   #122
Quote: Originally Posted by Grrrmachine View Post
Yeah, there's a volume control, which is basically a shortcut to the Windows Master Volume control. This means that if you have any music in the background, you have to configure that in balance with the deafeningly loud (in my system) level of Navigator's volumes - I have to have winamp cranked to full and then the master volume dropped to nearly zero in order to make it all sound balanced.
Also, how do you import data? I've done a drive with Netstumbler, and I'd LOVE to have the wifi locations as POI - is there any way of doing this in Navigator?
Yes it would be much better if you had the sound option of switching it to use an independant vol control or on the wave line instead of the master volume.
I love the program but for these reasons i am reluctant to use it very often unless i really dont know my way somewhere!
grandimperial is offline   Reply With Quote
Old 03-02-2008, 06:30 AM   #123
Are there any swedish voices?
Are there any swedish voices in Navigator7?
TRTR is offline   Reply With Quote
Old 05-27-2008, 07:48 AM   #124
Found an interesting tread over at The Land Rover Forum about speedcam import in PC Nav 7:
http://forums.lr4x4.com/index.php?sh...art=0&p=247560
Has anybody here tried that?
And did it work?
@TRTR: I will check for swedish tonight and post back.
Henrik
Sinobi is offline   Reply With Quote
Old 05-28-2008, 12:41 PM   #125
It has swedish text but you will have to do with either danish or norwegian voice.
Henrik
Old 06-10-2008, 03:39 AM   #126
Navigator8 is out. Can't find the changes. Anyone?
gabbe is offline   Reply With Quote
Old 06-12-2008, 03:02 AM   #127
I use PGPSW regularly. No problems. You have to rename the files to just cat999.mef and cat999.ttr. Works very well
brodgar is offline   Reply With Quote
Old 06-12-2008, 06:33 AM   #128
Does anyone know of a fix or if the option is available in PC Nav 8, where you can set it to use the WAVE volume line rather than the master?
Old 07-02-2008, 03:31 AM   #129
GTO
GTO's Avatar
I've imported a speed camera database but when I try to activate the warnings I get this.
"The object data file for scout functions is missing. Please check its installation"
Can anyone tell me what this means and how I sort this out?
Thanks.
GTO is offline   Reply With Quote
Old 07-02-2008, 04:10 PM   #130
Scout function
Hi GTO,
How did you import the database? I assume you imported a csv database file into exel saved the resulting xls file and then used the "getmef.exe" utility to produce a mef file.
The mef file must be named cat999.mef and copied to the europe_ta folder.
EFFUL is offline   Reply With Quote
Old 07-03-2008, 03:54 AM   #131
GTO
GTO's Avatar
I can't get getmef.exe to work properly because after loading the .xls file the 2 dropdown boxes where you select Lat & Long are blank.
I used POI Converter to convert a TomTom .ov2 file into a .csv then DiggerQt.exe which produced the following files.
digger_config.xml
id.tm6
import.mef
import.ttr
tie_2_d2m.tth
tie_2_m2d.tth
All these files were put in the "Import" folder and imported.
I can see the gatso icons on the map fine but I keep getting this object data message when I try to activate the warnings.
[EDIT]
OK forget that.
I followed your advice, renamed import.mef to cat999.mef then put it in the europe_ta folder and all is well.
The only thing that bugs me about Nav7 is that you have to be in nav mode to get the warnings.
With other GPS software like Sygic you can leave it running in the background and still get the warnings.
Old 08-31-2008, 01:01 PM   #132
can you use on PC navigator 6??
Ralphie is offline   Reply With Quote
VIA and Mini-box Announce First Sub-$300 Car PC Kit Goofus General Hardware Discussion 27 03-13-2006 11:28 AM
FS: CarPC 2.4 startup/shutdown controller evilragu Classified Archive 4 03-05-2006 04:28 PM
first car pc project machineshop Newbie 7 12-15-2005 03:17 PM
basic car pc idea Joseph Newbie 2 11-08-2004 02:04 PM
