Old 08-03-2007, 05:49 AM   #1
cgjt is an unknown quantity at this point
几个Road Runner的问题请教
这几天折腾Road Runner。现在有如下几个问题需要高手指教:
1、模拟同时按下键盘的多个按键。已知某一个单独键盘按键模拟参数(如现想点击设置的按钮如同键盘输入的“ k”按键,那么该按钮的数值是"SENDKEY;"{k}")。请问要模拟同时按下几个按键其数值是多少? 如模拟同时按下按键“Ctrl”+“c”,首先说明:不会是"SENDKEY;"{Ctrl;c}"或"S ENDKEY;"{Ctrl}"; "SENDKEY;"{c}",因为我已经测试过了。
可别说我的问题比较特别哈,如要用RR控制OZI等软件的GPS启动或停止就需要组合按键。
2、透明化。就是我想让RR的背景透明。因为如用城际通等导航软件,如果没有将RR背景透明将导致导航地图 的一部分被RR遮盖,但是如可以将RR的除需要使用的按键以外的背景透明化,那么就可以使导航地图尽可能的 看见。我用GIF图片设置透明化后用到RR上,图片的透明部分成了红色而不透明;我用PNG格式图片又不能 正常显示。
3、如何能够在导航页面使用如视频播放页面那样的自动隐藏方式?你看RR的视频播放页面的控制部分,在没有 操作后自动就隐藏了,如何在其它(如导航)页面使用这个“自动隐藏”功能?
cgjt is offline   Reply With Quote
Old 08-03-2007, 07:17 AM   #2
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
Uhhhhhhhhhh....
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 08-03-2007, 08:25 AM   #3
jonessc's Avatar
jonessc is an unknown quantity at this point
Quote: Originally Posted by DarquePervert View Post
Uhhhhhhhhhh....
CarPuter Progress:
Planning:-----> [||||||||||] 100%
Hardware Buying:-> [||||||||||] 100%
Software:-----> [||||||||||] 100%
Installing:-----> [||||||||||] 100%
Current Project= Making skins in photoshop...
jonessc is offline   Reply With Quote
Old 08-03-2007, 09:43 AM   #4
theheel is on a distinguished road
i understood some phrases like "Roadrunner" and up Sendkey
that just about covers it for this post
I wish i knew how to do fiberglass work...
theheel is offline   Reply With Quote
Old 08-03-2007, 09:56 AM   #5
jonessc's Avatar
Ok heres the translation, if it makes any sense
These days toss about Road Runner. Now has the following several questions to need the master to advise: 1st, the simulation simultaneously presses down the keyboard many pressed keys. The known some independent keyboard pressed key simulation parameter (for example presently wants to click on the establishment the button to be similar to the keyboard entry "k" the pressed key, then this button value is "SENDKEY;" K}"). Asked how many pressed keys its value wants to simulate simultaneously presses down is how many? If simulates simultaneously presses down the pressed key "Ctrl" + "c", first explained: Cannot be "SENDKEY;" Ctrl; C} "or" S ENDKEY;" Ctrl} "; "SENDKEY;" C} ", because I already have tested. But let alone my question quite special Kazak, like must use RR to control software and so on OZI GPS starts or stops needing to combine the pressed key. 2nd, 透明化. Is I wants to let RR the background be transparent. Because like passes and so on navigation software with the city border, if transparent has not caused the RR background the navigation map a part to cover by RR, but like may RR besides pressed key background 透明化 which needs to use, then may cause navigation map as far as possible seeing. After I use GIF picture establishment 透明化 to use on RR, picture transparent divided into has been red but is not transparent; I use the PNG form picture not to be able normally to demonstrate. 3rd, how can broadcast the page such automatic hideaway way in the navigation page use like video frequency? You looked RR the video frequency broadcasts the page the control section, automatic had not hidden after the operation, how (for example navigation) the page uses this in other "automatically to hide" the function?
CarPuter Progress:
Old 08-03-2007, 04:12 PM   #6
The Lavender Tie Just
Made It Obvious
Rafster's Avatar
Location: Bonita, CA (Hop, Skip, and a Jump from Tijuana, Mexico)
Rafster is a name known to allRafster is a name known to allRafster is a name known to allRafster is a name known to allRafster is a name known to allRafster is a name known to all
I think the original made more sense than that....
Rafster
Post # 3000
Items for Sale
PM me!! Not using new Classifieds because I don't particularly like the way it works...
http://www.speedtest.net/result/133342788.png
Rafster is offline   Reply With Quote
Old 08-03-2007, 09:01 PM   #7
感谢“jonessc”的精彩翻译,我的英文不行,但是相信您的翻译应该不错。望高手出来解答 。谢谢
Old 08-03-2007, 09:15 PM   #8
Made It Obvious
Rafster's Avatar
Could you possibly write in English?
Rafster
Post # 3000
Items for Sale
Old 08-03-2007, 09:26 PM   #9
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
Thanks "jonessc" excellent translation, the English No, but you believe that the translation should be good. Look out experts to answer. Thank you
Well unless we get a native chinese speaker who also speaks good English, he may not get an answer, as Google still has a long way to go, especially with technical stuff.
Enforcer is offline   Reply With Quote
Old 08-04-2007, 09:09 AM   #10
jonessc's Avatar
problem is chinese have 2 different languages, if someone wants to answer it il try and translaate it back
CarPuter Progress:
Old 08-10-2007, 11:35 PM   #11
MGD
MGD's Avatar
MGD is on a distinguished road
Ich glaube ich kann ihm auch nicht helfen. Ich spreche nur deutsch, english und spanisch. All the rest is GREEK to me.
MGD is offline   Reply With Quote
Old 08-11-2007, 03:27 AM   #12
kostyanj is an unknown quantity at this point
Are we going with all the languages all of the world? тогда я говорю на русском
www.computer-forums.net
kostyanj is offline   Reply With Quote
Old 08-11-2007, 09:28 AM   #13
Confusion Master
Enforcer's Avatar
je ne sais pas
Old 09-11-2007, 03:15 PM   #14
erezgur is an unknown quantity at this point
גם בעברית זה לא היה מובן יותר מדי
Isuzu Trooper 3.0 Diesel
CarPC: Mini ITX VIA 1500, 10.4 LCD Touch screen
http://www.mp3car.com/vbulletin/imag...5f72dc6c26.jpg
My Project Gallery (In hebrew):
http://www.jeeptrip.com/page.aspx?di...up=8&item=9224
erezgur is offline   Reply With Quote
Old 09-11-2007, 04:23 PM   #15
Nomader's Avatar
Nomader is on a distinguished road
κινέζικα μου μοιάζουν!
couldn't resist
Nomader is offline   Reply With Quote
