Old 08-08-2007, 03:59 PM   #1
iGuidance v4.0 without disc????
How do I run the maps and iGuidance straight from the computer without it needing the disc to open?
NickN is offline   Reply With Quote
Old 08-08-2007, 04:20 PM   #2
There are several programs out there that will make it able for you to copy your dvd straight to the harddrive, and then simply map a drive for itself, to run from.
Daemon tools is one of them...
If you can't drive a stick... You can't drive!
Angel_OD is offline   Reply With Quote
Old 08-08-2007, 05:17 PM   #3
Ive downloaded the Daemon tools like u said, now if you can give me a quick run down of what i have to do to make this happen, would be great. Im quite unfamiliar with the emulating process.
Old 08-08-2007, 05:23 PM   #4
Fusion Brain Creator
2k1Toaster's Avatar
Right click your drive and you should see a save to *.iso option. Do that. It will create a file the size of the DVD. Then take that file and right click--> mount. That will then mount it to your new "virtual drive'.
Old 08-08-2007, 05:42 PM   #5
Marvin Hlavac's Avatar
I may be wrong, but if the original poster is asking how to install iGuidance (any version) on a computer in such a way so that the program doesn't require the DVD to run, then the answer is just simply to install the program as per installation instructions.
Marvin Hlavac is offline   Reply With Quote
Old 08-10-2007, 05:59 PM   #6
there is no option of the sort in the setup process
Old 08-10-2007, 06:01 PM   #7
I didn't think so either... I had to have my dvd in the drive all the time, untill I found the Daemon. And it works like a charm! :-)
Follow 2K1Toaster's advice, or ... google it! :-)
Old 08-10-2007, 06:21 PM   #8
The trick is: "...install the program as per installation instructions." While most programs don't require us to read the included instructions, iG4 does (at lease the first batch). The instructions explain that a folder (w/all its content) has to be copied from the installation DVD to your hard drive - running the installation application is not good enough.
Copy iNav iGuidance folder from the DVD to your C:\
Old 08-11-2007, 03:47 AM   #9
pip
pip's Avatar
Marvin is quite correct, part of the instructions was to copy the map data to your C: drive. If you dont do this it looks for it on the DVD. Beats mounting a DVD image
pip is offline   Reply With Quote
Iguidance v4.0 thadude GPS 251 08-25-2008 10:00 PM
Indexing music in 1.0.9.8 Failed hovalistic StreetDeck 0 07-07-2007 12:19 PM
iGMon - Solution for integration between iGuidance and Road Runner (I hope) b8bboi RR Plugins 567 10-07-2006 10:52 PM
Purdoom's big book of iGuidance apps! (Faq) PURDooM GPS 17 06-15-2006 01:46 AM
iGuidance Font Size Fix summary thread Viscouse GPS 29 03-28-2006 07:21 PM
