Old 08-09-2007, 01:26 AM   #1
LiquidKernel's Avatar
iG 3.0 Crashes When Driving Through Tree Shaded Areas?
I've noticed this since I upgraded to iG 3.0 over a year ago now. I didn't uninstall 2.1.3 before the upgrade, just installed 3.0 over it. Never had a single issue with 2.1.3 but for some reason 3.0 has always been iffy.
I can usually recreate it by driving through any area where there a lot of trees surrounding the road.
I am using a Holux GR-213. But as I mentioned, iG 2 worked fine.
95 Volvo 850 T5 • Konis • ECU @ 17psi • 5+20% Tint • Orange Ambient-Light + LED Dash Lights • DigiMotive Dimmer • Custom LED Brake Lights • 2.5" BOSCH HID Projector Retrofit
Carpc: [▓▓▓▓▓▓▓] 99% Cleanup.
LiquidKernel is offline   Reply With Quote
Old 08-09-2007, 01:37 AM   #2
When you look at the GPS info in IG is it losing all the satellites?
www.computer-forums.net
kostyanj is offline   Reply With Quote
Old 08-09-2007, 01:40 AM   #3
Haven't checked. But would that still cause it to crash?
Old 08-09-2007, 01:49 AM   #4
I'm just asking questions. I haven't had that problem. Does it give you an error? My GPS just has lots of trouble picking up signal in wooded areas but IG hasn't crashed on me yet.
Old 08-09-2007, 08:47 AM   #5
fixerofallthing's Avatar
Mine would do that too, but only in 3d mode. I switch to 2d when it happens and it works fine until I get out of the area then I put it back. Hope this helps.
The Car 2005 Scion xB
The Truck 2004 GMC Canyon
fixerofallthing is offline   Reply With Quote
Old 08-09-2007, 11:41 AM   #6
Interesting theory. I'll check next time I drive and see if that's causing it. Perhaps 4.0 might cure it?
Old 08-15-2007, 08:56 PM   #7
I tried out your method and it worked. But I think that's a poor solution and not sure why iG does this in the first place. Does 4.0 fix this by any chance? I'd upgrade if it does.
Just for reference, here is my setup (it might have something to do with it, I suppose):
Holux GR-213 behind glass
Win XP Pro stripped w/ nLite
Latest RoadRunner w/ iDrive theme
Old 08-19-2007, 01:20 AM   #8
Finally got iG 4.0 and it solved the problem and added cool new features Love how it re-routes without flashing the screen.
Old 08-21-2007, 06:46 PM   #9
scottgs's Avatar
Does it sill flash when it goes to the "guidance" screen? I think that's what it's called, the screen it switches to when you near a turn.
scottgs is offline   Reply With Quote
Old 08-21-2007, 07:13 PM   #10
I actually turned off the guidance screen because it looks a bit tacky in the iDrive theme I use. I'll try and let you know.
Old 08-22-2007, 06:10 AM   #11
wizz's Avatar
GPS Receiver
Just a tip.
I'm in the UK and originally had my gps receiver in the left side front of my windscreen.
I had problems with reception in this position when there were overhangs. I moved it to the right side, and because we drive on the left, this positioned it nearer to the centre of the road.
In this position, the reception was significantly improved.
So for you.....if it's on the right side.......move it to the left
Car : Ford Focus Zetec 1.6
Carpc :Lin-ITX Plus 7" touchscreen/Toad 8" roof screen
Morex 3688 case/M2-ATX PSU/Commell V-672 P4 3.2Ghz/1024DDR2/40GB 2.5" SATA HDD/Sony DVD/CDRW
BU303 GPS/Mercury 11b WiFi/Parking Sensors
Colour I/R Reversing Camera
wizz is offline   Reply With Quote
ig 3.0 on PPC Cheekz185 GPS 2 05-07-2007 05:40 PM
Good news to IG 3.0 users! and IG 2.0 mbkowns Centrafuse 23 08-11-2006 08:24 AM
