Old 08-21-2007, 02:07 AM   #1
xpluis's Avatar
xpluis is an unknown quantity at this point
gps USB or SERIAL?
What is better, a USB gps, or SERIAL gps??
The Bu-353 USB stop work some times after hibernation, i need restart my pc for get the correct sats again. What about serial gps? is better?
xpluis is offline   Reply With Quote
Old 08-25-2007, 07:54 AM   #2
weltrekord is an unknown quantity at this point
i think the usb is better, but not sure, usb is a better and newer technic
weltrekord is offline   Reply With Quote
Old 08-25-2007, 09:07 AM   #3
kbreeden
I've been using the BU-353 for years and it has never not come out of hibernation. Make sure it's plugged into a USB port on the computer rather than a hub.
kbreeden is offline   Reply With Quote
Old 08-29-2007, 11:52 PM   #4
Themutt is an unknown quantity at this point
Side note usb signal looses strength the longer the wire, serial does not suffer as much from this. Also most GPS seem to work better plugged into a primary (on the MB) slot inorder to get full power usage.
Themutt is offline   Reply With Quote
Old 08-30-2007, 11:52 AM   #5
MySQL Error
MatrixPC's Avatar
MatrixPC is on a distinguished road
For anything else, USB will be easier. For GPS with current update rate, serial is much better. With serial, no suffering from hibernation problem, no additional driver needed. The only draw back of serial is you have to find a way to power the device as most of them isnt' getting power from serial port.
Current USB do need be bridge/convert to serial for 3rd party apps and that what the driver is doing.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 08-31-2007, 09:22 AM   #6
DeltaFX's Avatar
DeltaFX is on a distinguished road
On some industrial motherboards, the serial port has its own powerline, sometimes you can even choose if you want it to be 12v or 5v
Now Galileo is real. Muhahahahaha :p
DeltaFX is offline   Reply With Quote
Old 08-31-2007, 05:11 PM   #7
jonessc's Avatar
jonessc is an unknown quantity at this point
CarPuter Progress:
Planning:-----> [||||||||||] 100%
Hardware Buying:-> [||||||||||] 100%
Software:-----> [||||||||||] 100%
Installing:-----> [||||||||||] 100%
Current Project= Making skins in photoshop...
jonessc is offline   Reply With Quote
I have a big question about BU-353 (USB GPS receiver) GPS_guy GPS 4 10-06-2006 08:36 AM
garmin mapsource and usb gps mouse thecrow GPS 9 09-26-2006 03:24 PM
USB vs Serial GPS? drPheta GPS 12 08-22-2006 05:02 PM
WTT: Bluetooth GPS for USB GPS arebelspy Classified Archive 6 09-29-2005 12:53 PM
Problem with USB to serial converter openminds GPS 7 08-08-2004 05:50 PM
