The MP3car.com Store
Thread Tools Display Modes
Old 11-09-2007, 08:58 PM   #16
01black_ac's Avatar
My Photos: (0)
Ok... is your IG being installed in
C:\Program Files\iNav\iGuidance
or
C:\Program Files\iNav iGuidance
Are those .dat files just text files? For some reason mine aren't being created and I can't figure out why... I just now created those 4 files in the iGuidance directory and tried to save an address as a favorite and nothing... I've uninstalled and reinstalled twice now, exact same behavior each time, which is to say, none.
'01
Hang on while I defragment my car...
the Acura ITX project
the Acura ITX skin for RoadRunner
project progress: 99%
01black_ac is offline   Reply With Quote
Sponsored Links
Old 11-09-2007, 09:03 PM   #17
DaveDog's CarPC Specs
DaveDog's Avatar
Vehicle: Baja 302 Compensator
My Photos: (1)
iGuidance gets installed into c:\program files\iNav\iGuidance
favorites are stored into another directory created when you load maps c:\iNav iGuidance
Why is my laptop all wet?!
DaveDog is offline   Reply With Quote
Old 11-11-2007, 01:05 PM   #18
Marvin Hlavac's Avatar
My Photos: (0)
The installation may be a bit confusing, but just try to follow the included installation instructions, step-by-step. It will work.
Marvin Hlavac is offline   Reply With Quote
Old 11-12-2007, 11:49 AM   #19
01black_ac's Avatar
My Photos: (0)
Yeah after several uninstalls/reinstalls I managed to get it running properly and saving Favorites/Home data... I couldn't, however, get it to run from a virtual drive mounted through Alcohol 120%. Whenever I try that it goes back to not saving Favorites again. But that's ok, at least it's running and not taking any more space on the HDD than it would have as a mounted ISO.
'01
Old 11-27-2007, 10:11 PM   #20
My Photos: (0)
after searching, i found this thread.......but its not helping so im bring it back up...
i have mounted n installed my IG but it wont also save. what am i missing? i tried creating the "iNavi iGuidance" folder in C but that didnt work.
sl33pyriceboi is offline   Reply With Quote
Sponsored Links
Old 11-27-2007, 10:16 PM   #21
Fusion Brain Creator
2k1Toaster's CarPC Specs
2k1Toaster's Avatar
Vehicle: 2001 Honda Civic EX Coupe
My Photos: (1)
You wont get help here about pirated software.
Old 11-27-2007, 10:30 PM   #22
Arrow's Avatar
Vehicle: 2001 Ford Focus
My Photos: (3)
Doesn't necessarily mean he's using pirated software. I have a virtual drive and (legally) mount ISO's all the time for software that requires the disc to be in the drive. I hate changing cd's. I try to live without them.
Arrow is offline   Reply With Quote
Old 11-27-2007, 10:33 PM   #23
2k1Toaster's Avatar
My Photos: (1)
I know for a fact that both iguidance 3 and 4 come one DVDs that are used for install only. You pop it in, enter the serial click next next finsish and it is installed. You can then put thermite on the disk if you want, because you dont need it again until you reinstall. No need for mounting an image.
Old 11-27-2007, 10:36 PM   #24
Arrow's Avatar
My Photos: (3)
Well, unless you're smart enough to copy the maps to the correct location on the C drive (most of us are) iGuidance requires the cd to be in the drive in order to obtain the map data. Besides, iGuidance wont install without a valid key, so a crack would have been needed whether the drive was mounted or not. This would render mounting useless for pirating purposes. And in the car pc world, not everybody has a CD drive.. I dont, so mounting images is the next best thing.... next to the fact that iGuidance can install from the files directly. But maybe he's not that smart.
Old 11-27-2007, 10:39 PM   #25
2k1Toaster's Avatar
My Photos: (1)
Hmm. I never had to do this. I just put the disk in, went through isntall and it automatically created the folder in c: root, and voila. For 3 I had to use the map loader, but it too automatically created the folder and copied everything over.
Maybe there are different versions, but that would be strange.
Old 11-27-2007, 11:00 PM   #26
Arrow's Avatar
My Photos: (3)
Hmm.. I actually had to reinstall it because unless I manually copied the maps to the root directory, it wanted a cd for the maps. My instructions even told me to copy the cd to the root then install and leave the files there. Maybe there are different versions. Interesting.
Old 11-27-2007, 11:01 PM   #27
Arrow's Avatar
My Photos: (3)
Oh I broke 100 posts.. just noticed.. Sorry, I had to say something.
Old 11-29-2007, 03:12 AM   #28
My Photos: (0)
ok ok ok wait wait wait...
first of all, i dont have a cd drive so i mounted it. i bought a fully legit copy so im not pirating crap.
imma hook up my external cd drive tormow n try to reinstall it.
Old 11-29-2007, 03:24 AM   #29
My Photos: (0)
hahhaha i got it to work... copied the folder to the wrong folder...
and yes, i .ISO everything so its easier for me.
Old 12-03-2007, 12:09 PM   #30
My Photos: (0)
when I installed it, it would load for me using the cd or from mounting an image, but saving favorites etc would not work. the reason is that it wants to save the favorites in the same location as the map files.
it will look for favorites and map files in c:\iNav iGuidance\
I installed the program, then afterward, copied the "iNav iGuidance" folder from the CD to the root of my c: drive. after that i was able to load the program without any cd or ISO and it was also able to save my favorites
tiamat6x3 is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
VMWare Fusion can't run iGuidance 4.0 pip MacCar 21 09-26-2007 09:01 AM
iGuidance 4.0 and RR? Outsider787 Road Runner 2 08-13-2007 01:24 PM
Purdoom's big book of iGuidance apps! (Faq) PURDooM GPS 17 06-15-2006 12:46 AM
iGuidance Font Size Fix summary thread Viscouse GPS 29 03-28-2006 06:21 PM
Custom log parsing automation… xcntrk75 Software & Software Development 4 05-11-2005 02:19 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
