Old 12-15-2007, 12:03 PM   #31
I cannot change the map color in IG4...Anyone else having this problem?? I can only change night and day, and the night has a white background with Flourecant green writing!?
Dougw133 is offline   Reply With Quote
Old 12-21-2007, 04:53 PM   #32
Bump's Avatar
here is a trick to saving Home setting even if your address does not come up on the map.
make sure you have no other location in your favorite folder.
drive to the location you want to call home.
Put a way point at that location on the map. call it anything you want to call it.
Save it in your favorites folder in IG3 or IG4.
Now, close IG3/4 . go to your maps folder on c: drive ( C:\iNav iGuidance ).
You should see files called:
" favorites.dat "
" home.dat "
delete the file " home.dat "
now copy " favorites.dat " and paste it in the same folder.
It should copy it out as "Copy of favorites.dat "
Now , just rename " Copy of favorites.dat " to " home.dat "
and that location will now be your HOME setting in IG3/4
Bump is offline   Reply With Quote
Old 12-24-2007, 07:22 PM   #33
is it possible to use iguidance 4 maps with iguidance 3.0??
jnthn205 is offline   Reply With Quote
Old 12-25-2007, 06:11 PM   #34
Marvin Hlavac's Avatar
No (to the best of my knowladge no user yet found a way to succesfully do it).
Marvin Hlavac is offline   Reply With Quote
Old 02-01-2008, 02:28 AM   #35
im starting to have the same problem..so since i have mine installed, i have to uninstall it and reinstall it again but without the cd? what about the license key? that will be reusable?
pnyboy27 is offline   Reply With Quote
Old 02-03-2008, 05:46 PM   #36
anything?
Old 02-04-2008, 05:35 AM   #37
I started a new thread about somethig like this, but i wanted to ask here too. Is there a way to change the location that iguidance looks for the map at? I dont want it to look for c:\inav guidance, but rather point to another location, ie d:\programs\iguidance....
I'm running an CF install of windows and have limited space on my C:, so i have to install the maps on a differnet hdd.
[H]Bugster is offline   Reply With Quote
Old 09-09-2008, 01:45 PM   #38
Raw Wave
shotgunefx's Avatar
I don't know if this helps you guys, but I had the same problem, though I'm trying to run it under WINE on Linux.
I tried uninstalling, reinstalling, but not such luck. I looked at my c:\inav guidance folder, and noticed that it was set to Read only, changed the permissions and now it works just fine.
shotgunefx is offline   Reply With Quote
Old 09-10-2008, 12:15 AM   #39
I install it from a folder on my HD, got it to work. shut it down know its telling me to reinstall cant read maps. Go figure?
diggla is offline   Reply With Quote
VMWare Fusion can't run iGuidance 4.0 pip MacCar 21 09-26-2007 10:01 AM
iGuidance 4.0 and RR? Outsider787 Road Runner 2 08-13-2007 02:24 PM
Purdoom's big book of iGuidance apps! (Faq) PURDooM GPS 17 06-15-2006 01:46 AM
iGuidance Font Size Fix summary thread Viscouse GPS 29 03-28-2006 07:21 PM
Custom log parsing automation… xcntrk75 Software & Software Development 4 05-11-2005 03:19 PM
