The MP3car.com Store
Thread Tools Display Modes
Old 08-22-2007, 08:59 PM   #1
My Photos: (0)
Iguidance 4.0
1st problem setting my home address is giving me problems, I enter info and it finds my location. I click save. I click on home and nothing is set. Same applies to favorites nothing is saved. Lastly I would like to load all the map read instructions still didnt understand. I know we can create simulated drive or I believe it called virtual drive to do the same thing. I have been searching around and Ive learn so much from this forum. Any help would be great. pc xp pro service pack 2 sx270
ggcr is offline   Reply With Quote
Sponsored Links
Old 08-22-2007, 09:32 PM   #2
My Photos: (0)
i was able to get it working.
Old 08-23-2007, 06:15 PM   #3
My Photos: (0)
how? I am having this problem too
Ryan711 is offline   Reply With Quote
Old 08-24-2007, 11:19 AM   #4
Uraijit's CarPC Specs
Uraijit's Avatar
Vehicle: 2001 Chevy Tahoe
My Photos: (4)
When you get a problem fixed, it's common courtesy to share what you did to get it working. Otherwise you're just wasting bandwidth...
The Hoe-Puter Worklog
Progress (Phase one):
Planning:
[----------] 97.3%
Parts Aquisition:
[----------] 95%
Install:
[----------] 95%
http://www.speedtest.net/result/187304447.png
Uraijit is offline   Reply With Quote
Old 08-24-2007, 11:25 AM   #5
Fusion Brain Creator
2k1Toaster's CarPC Specs
2k1Toaster's Avatar
Vehicle: 2001 Honda Civic EX Coupe
My Photos: (1)
Mmmmmmmmmmmmmmmmmmm.... Bandwith......
Old 08-29-2007, 01:34 PM   #6
My Photos: (0)
I am having the same problem. Would you share what your solution was please?
Jaguar77 is offline   Reply With Quote
Old 08-29-2007, 03:56 PM   #7
My Photos: (0)
LOL
i can't believe he's not sharing the info either.
it's the least we can do to contribute to the community.
Snortonnorton is offline   Reply With Quote
Old 08-29-2007, 04:13 PM   #8
tn6478's Avatar
My Photos: (0)
You guys should not have problem setting those up. To set up home location all you have to do is click set home and type in your home location and it should save. Same as all route that you go to. It should be in recent and if you want to save the location just set as favorite. If you have problems with it most likely because Inav the main program is install in the wrong location. If you are using ewf install the main program on the c: drive and then put the main onto the extended partition. Iguidance 4 should read it and all you favorite and stuff will be save.
tn6478 is offline   Reply With Quote
Old 08-30-2007, 03:10 PM   #9
My Photos: (0)
Fixed mine, I didn't have all the folders installed correctly. Initial install missed one of them. Thanks
Old 09-01-2007, 02:37 PM   #10
Fallout's CarPC Specs
My Photos: (0)
before you install iguidance, copy the cd onto your hard drive. install it from that folder not the cd.
My RSX Carputer finished!
Fallout is offline   Reply With Quote
Sponsored Links
Old 09-11-2007, 03:30 PM   #11
My Photos: (0)
I copied the whole dvd to my hd, ran the setup from the hd. Now when i run the program, it says
Quote:
cannot find map data files
Please make sure the storage card is properly inserted or reinstall map data from dvd.
Not sure what to do besides virtual drive.
Jae
ThurzNite is offline   Reply With Quote
Old 09-11-2007, 04:44 PM   #12
Uraijit's Avatar
My Photos: (4)
did you copy all of the folders before the install? you need to install from the harddrive. not the dvd. sorry my grammar sucks im typing on my pocket pc...
Planning:
[----------] 97.3%
Parts Aquisition:
[----------] 95%
Install:
[----------] 95%
Old 09-13-2007, 06:57 PM   #13
My Photos: (0)
I got mine to work. I copied the inav folder and setup folder to my c: root, ran setup from there, and it's been gravy ever since.
Jae
Old 11-09-2007, 05:53 PM   #14
01black_ac's Avatar
My Photos: (0)
Can someone here let me know if I'm missing a folder in my installation directory...? I've got the same issue as some of the previous posters. I type in a destination, IG finds it, I select it, add it to favorites, but it never appears in the favorites list... The favorites list is always blank... I installed from the hard drive from a folder on the D: drive which holds a copy of all the contents of the installation DVD....
I installed to the default location on C:
This is my directory structure after installation:
C:\Program Files\iNav (empty except for the iGuidance folder below)
C:\Program Files\iNav\iGuidance (contains the program files)
C:\Program Files\iNav\iGuidance\Snd (contains .wav files)
Is there some directory missing in which saved Favorites and Home data get stored? No matter what I do, I can't save Favorites or Home info...
'01
Hang on while I defragment my car...
the Acura ITX project
the Acura ITX skin for RoadRunner
project progress: 99%
01black_ac is offline   Reply With Quote
Old 11-09-2007, 08:46 PM   #15
DaveDog's CarPC Specs
DaveDog's Avatar
Vehicle: Baja 302 Compensator
My Photos: (1)
favorites and such are stored ing the C:\iNav iGuidance directory
favorites.dat
home.dat
recent.dat
itinerary.dat
Why is my laptop all wet?!
DaveDog is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
VMWare Fusion can't run iGuidance 4.0 pip MacCar 21 09-26-2007 09:01 AM
iGuidance 4.0 and RR? Outsider787 Road Runner 2 08-13-2007 01:24 PM
Purdoom's big book of iGuidance apps! (Faq) PURDooM GPS 17 06-15-2006 12:46 AM
iGuidance Font Size Fix summary thread Viscouse GPS 29 03-28-2006 06:21 PM
Custom log parsing automation… xcntrk75 Software & Software Development 4 05-11-2005 02:19 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
