Old 08-31-2007, 03:28 PM   #1
ukraini9mofo is an unknown quantity at this point
Google earth and BU-353
Hey I just ordered the BU 353 to go along with my 1.,5 Ghz and 512 RAM carputer system.
I was wondering if BU-353 will be compatible with google earth and how does googel earth wrok. Does it get its maps from internet(does it have to be constantly connected to internet) and if not why si it onlt 35 Megabytes size when Iguidance is over a gig
thanks
ukraini9mofo is offline   Reply With Quote
Old 08-31-2007, 05:06 PM   #2
jonessc's Avatar
jonessc is an unknown quantity at this point
thanks
yes is should work (buy your gps wont be selectable until you buy the upgrade for google earth or use the google earth road runner plugin)
google earth gets its maps from the internet, however it is possible to cache the maps on your had drive, so a internet connection isnt needed
its 35mb because the maps arnt stored until you start browsing, then the size will increase
you can reduce the size iguidance takes up by selecting map regions, and only installing areas you will go to @ 1gb id imagine thats all of the maps!
CarPuter Progress:
Planning:-----> [||||||||||] 100%
Hardware Buying:-> [||||||||||] 100%
Software:-----> [||||||||||] 100%
Installing:-----> [||||||||||] 100%
Current Project= Making skins in photoshop...
jonessc is offline   Reply With Quote
Old 08-31-2007, 06:01 PM   #3
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
1 - Last I heard, Google Earth won't interface w/ a GPS receiver unless you lay out the cash for the plus version. It's only $20.
2 - Yes, the BU353 will work with Google earth.
3 - Google Earth does pull map data from the internet, however there are utilities that will cache map data locally.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 08-31-2007, 06:33 PM   #4
briderx's Avatar
briderx is an unknown quantity at this point
Well, I have the BU-353 and it works great with Google Earth.
In my opinion, Google Earth is TOO SLOW of an update to keep up with your car (refresh is like 1 second). That, and the screen doesn't pan fast enough to keep up with my car.
briderx is offline   Reply With Quote
Old 08-31-2007, 07:03 PM   #5
jonessc's Avatar
Plus you carputer will have to be reasonably beefy to run it
CarPuter Progress:
Old 01-08-2008, 02:51 PM   #6
rijndael's Avatar
rijndael is an unknown quantity at this point
what about Virtual Earth or whatever it's called from Microsoft? will the BU-353 work with that?
Trouble deciding on car speakers? Clicky Clicky
My Myspace page (view my pics for carputer worklog...needs updated)
Speakers: DLS Ultimate Iridium 6.3 Link
Subwoofer: removed
Amplifier#1 (Front Stage): DLS Ultimate A4
Amplifier#2 (Sub) removed
rijndael is offline   Reply With Quote
