The MP3car.com Store
Thread Tools Display Modes
Old 09-03-2007, 10:00 PM   #1
briderx's Avatar
Vehicle: 1996 Jeep XJ
My Photos: (0)
Navigation software that runs SMOOTH?
I have iGuidance. Have been running it for awhile now. I'm now onto version 4. My problem with it is this: I had a MIO C310x handheld GPS unit, and LOVED how smooth the transition turns were. It always seemed to be continually updating, as iGuidance has a second delay or so.
My question: Is there software out there that will work SIMILAR to the Mio C310x software, or the AVIC software? I don't mind cost.
briderx is offline   Reply With Quote
Sponsored Links
Old 09-03-2007, 10:20 PM   #2
Fusion Brain Creator
2k1Toaster's CarPC Specs
2k1Toaster's Avatar
Vehicle: 2001 Honda Civic EX Coupe
My Photos: (1)
iGuidance updates at 1Hz as all other non-proprietary software does. \
You can get 5Hz receivers and that will help. I think iGuidance is very smooth as long as your receiver sends a good signal. iGuidance is as smooth as all the Garmin units (standalone car nav), and better than the Garmin handheld.
Old 09-03-2007, 10:35 PM   #3
briderx's Avatar
My Photos: (0)
I have the BU-353 running @ 4800. That's what the instruction manual said to run it at, as it's the "perfect" setting for that receiver. Is that correct? or am I missing something?
Old 09-03-2007, 10:36 PM   #4
briderx's Avatar
My Photos: (0)
and as for smooth. I'm talking like, it EASING into turns instead of skipping every half second to a second.
Old 09-03-2007, 10:55 PM   #5
rjankowski's CarPC Specs
rjankowski's Avatar
Vehicle: 99/Chevy/Silverado
My Photos: (0)
With the BU-353 and SiRFDemo you can adjust the number of times per second that the reciever sends each signal. Youll have to figure out which strings iG uses to update your location, and I think you can go to 1/10 sec (10 hz) for each message. Just keep in mind you can only shove so much information thru at 4800 bps. You can search for the nmea sentences and play around with them. I poked them with a stick for a while and removed alot of the sentences that I didnt think were used. I dont know how much of a diffrence you will see, but it does seem to make things a bit smoother in MS Streets and RR.
It works!!
Almost all of the time too!
rjankowski is offline   Reply With Quote
Old 09-04-2007, 03:15 AM   #6
My Photos: (0)
I have a Mio 310x with Miomap 3.2 (older version, not 2007). How does Iguidance 3.0 or 4.0 work on it compared to Miomap?
Thank you.
Victor
VictorGreen is offline   Reply With Quote
Old 09-04-2007, 05:04 AM   #7
Neither darque nor pervert
DarquePervert's CarPC Specs
DarquePervert's Avatar
Vehicle: 2003 Toyota Tacoma X-Cab
My Photos: (26)
iGuidance won't run on teh handheld GPS device.
It runs on a PDA or a PC.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 09-04-2007, 11:19 AM   #8
briderx's Avatar
My Photos: (0)
Thank you.
Victor
I was referring to the display of Mio's Mapping software. How the transition from corner to corner is very smooth and no hiccups. You can't run iGuidance on that handheld (even though you CAN run other Windows CE programs on it.. But, we're talking about iG and the BU-353.. Ha ha..
Anyways, So, I guess I'll start messing around with that demo then! do I need to be driving to mess with it?
Old 09-05-2007, 02:42 AM   #9
rjankowski's Avatar
My Photos: (0)
No, you can mess with it, drive around a bit... see if thats what you want, and adjust it.
The way to access it is connecting to the gps, switch to SiRF protocal, then switch back to NMEA. You will see the refresh rates for each type of line and you can adjust it.
It works!!
Old 09-05-2007, 06:56 AM   #10
bambam's CarPC Specs
bambam's Avatar
Vehicle: 1995 Mitsubishi 3000GT SL
My Photos: (0)
iGuidance will run on the Mio c310x. Many people are doing it now and I will be shortly. Read
http://www.gpspassion.com/forumsen/t...TOPIC_ID=72645
and do some searching in gpspassion for procedures.
Funny, iGuidance locked up in an endless "make U turn" loop this weekend at coords 43.0292 N - 77.43947 W. We had to ignore it and go straight for a mile (of course in the wrong direction) until it started working correctly again.
bambam is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
SD compatible navigation software dangregory007 StreetDeck 1 06-04-2007 01:17 PM
?? GPS Navigation Software ?? DagegeN_ZA Road Runner 1 05-04-2007 06:11 PM
Wich navigation software? _GdR_ Software & Software Development 9 03-15-2005 03:52 PM
Suggest a well priced navigation software for Europe (Germany) carpcnoobie GPS 1 06-06-2004 10:37 AM
gps navigation software llmask GPS 4 10-26-2003 01:00 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
