Quote: Originally Posted by
evankuhl
... what should i assign it to then? a different com port? I just don't understand how else I'll get the device to be recognized by i guidance... i must be missing something basic here
BU353 is a USB-to-serial driver by prolific. Look it up in the device manager. It will tell you the COM port assigned to it.
If you need to change that, find that COM port in the device manager and change the assignement.
lexdiamond20
Try port 3 with Baud rate 4800. Had the same problem last night and took way too long to fix it.
That may or may not work. every device & setup is different. This isnt' a situation where "set it XXX way" will work every time.
