The MP3car.com Store
Thread Tools Display Modes
Old 11-13-2007, 05:53 PM   #16
S4Per's CarPC Specs
S4Per's Avatar
Vehicle: 2002 Audi S4 - Not quite stock
My Photos: (0)
Sorry, here's clarification:this should fix the issue on both XP and Vista.
When I had sent the question to their support I was running XP, so their reply was in regards to XP. Over the weekend I installed Vista and found that it was exhibiting the same issue (locking up). I then tried the files they sent me on Vista and they seem to have fixed the issue also. So - it should fix it on both OSes.
Note: the directions from support state you should place the files in the system32 folder. I found out that for Vista, they need to be placed there AND into the system32/drivers folder in order for it to work (I went into device manager and looked at the properties of the COM port, checked driver details and saw that it was using one of those files in the system32/drivers folder also, so I copied both files into both locations).
Hopefully that clears it up.
S4Per is online now   Reply With Quote
Sponsored Links
Old 11-13-2007, 08:39 PM   #17
_
RedGTiVR6's CarPC Specs
Vehicle: VW GTi VR6 / Ducati 900 SS & S4R / Dakota R/T Supercharged
My Photos: (73)
I'll give that a try tomorrow then!
Thanks!
Jan Bennett
If you're needing someone to tell you what to buy, how to install it, or how to make it sound good, I charge a consulting fee.
RedGTiVR6 is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
The legalities of wardriving. PURDooM Wireless Communications 200 01-29-2008 05:26 PM
Remotely turn on computer (not necessarily car) Triggerhappy Power Supplies 14 06-22-2006 12:23 PM
What kind of computer to pick pulz Newbie 5 02-02-2006 04:08 PM
Computer Crashed? Rocky388 General Hardware Discussion 16 11-30-2005 09:39 PM
Computer becomes unresponsive, inverter problem? tsb4k Power Supplies 9 10-23-2005 02:22 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
