Old 09-18-2007, 10:21 PM   #1
How to get cf gps receiver to work in car
Hello all I will get straight to the skinny I have a holux gr-271 compact flash gps receiver, my cpu set up is this http://store.mo-co-so.com/complete-c...c7-cpu-p-5.htm
I really dont want to spend more $$$$ on a gps receiver when I already have one so what i am asking is there a way to hook this in to a usb slot I thought of using a cf card adapter but not sure if that will send a signal through the usb port can this be done. thanx to all that answer.
BIGGKATT01 is offline   Reply With Quote
Old 09-19-2007, 12:15 AM   #2
JimmyFitz's Avatar
Most CF accessories other than flash memory were made for Pocket PC's. Usually there aren't any drivers for windowsXP for these types of devices. It isn't likely that you will get it to work. You should check the CF card manufacturer's web site to see what drivers are available.
2002 T-Bird, Via SP13000, Travla C158, M1-ATX, 1GB RAM, 120GB 2.5" drive, SlimSlot DVD-RW, XP, RR, Winamp, Xenarc 700TSV, HTC Touch PPC/Phone, BU-353 GPS/iG3, Elmscan OBDII, Griffin PowerMate, 2 Blaupunkt amps, Polk spkrs, 5 sec startup/S3 STR
~Jimmy
JimmyFitz is offline   Reply With Quote
Old 09-19-2007, 01:44 AM   #3
thanx for the input jimmyfitz the cf gps card that i have does come with winxp drivers so thats not a problem.
Old 09-19-2007, 09:09 AM   #4
JimmyFitz's Avatar
Your next hurdle then is finding a CF adapter that is designed to do more than just read flash memory cards. The common adapters go from IDE-->CF, SATA-->CF, and USB-->CF. Good luck and let us know what you find that works.
~Jimmy
Old 09-19-2007, 06:32 PM   #5
I sure will I am waiting for an email back from the manufacturer of my receiver as soon as I know I will let the forums know its only common courteously someone else may neen the info thanx to all.
Getting Started with GPS grepzen The FAQ Emporium 12 09-26-2006 06:54 AM
Are there any crossover GPS models that would work well in both a car environment, an rotarypower101 GPS 10 03-19-2006 04:37 PM
GlobalSat BT-338 Review tom2112 The Review Palace 8 06-27-2005 12:02 PM
i have a cf gps receiver ombastic GPS 10 07-08-2004 03:34 PM
