Old 09-22-2007, 02:24 AM   #1
erricson_nguyen's Avatar
erricson_nguyen is an unknown quantity at this point
gps loosing signal at gas station
every time i stop for gas my gps loosing signal i checked b4 stop 4 gas at least there were 7/10 sat, any 1 have similar problem please help this newbie how to fix it i use MS usb reciever i believe it's a Pharos gps 500 Sirf III iguidance 4.0 i place it on dashboard , to get signal back i have to restart pc exit iguidance relaunch won't help
thank in advance
erricson_nguyen is offline   Reply With Quote
Old 09-22-2007, 02:40 AM   #2
Marassa is an unknown quantity at this point
Are you sure the gas station does not have a metal roof?
Marassa is offline   Reply With Quote
Old 09-22-2007, 02:58 AM   #3
i have no idea but i went 5 different station same thing happened
Old 09-22-2007, 05:37 AM   #4
BiG K is on a distinguished road
Simple fix really.....don't go to a gas station :P
The gas station will have somesort of a roof, which will block the signal from getting through, you could hack the GPS and fit a stronger aerial onto it.
GPS works by time. All the sattelites have a precise time, which they broadcast. The GPS receiver than works out where the satelites are judging by the time. GPS microwave signals take time to reach the ground, I can't be bothered working out the exact time, but the further away a satelite is, the longer the signal takes to reach you.
For example, if you have four satelites, each one will give a slightly different time down to the nanosecond, whch the GPS receiver can then work out where you are! With a roof, those times can get a little skewed and you'll have "lost signal" while in all reality, you won't have lost the signal completely, the GPS receiver will get widely varied times, so the GPS receiver cannot pinpoint your location.
At any one time, there are always three or more GPS satelites above us ;-)
With the launch of the European GPS satelites, we will actually be able to accurately work out where we are....to a meter!! Currently, US GPS sattelites can work out only to 10 meter range.
Try to use a petrol pump near the edge of the forecourt, which should help you with your signals
BiG K is offline   Reply With Quote
Old 09-23-2007, 04:25 AM   #5
Raw Wave
Laidback's Avatar
Laidback is on a distinguished road
I think you're all missing the point! When he drives out of the gas station he should get the signal back in seconds, not have to restart the pc.
Laidback
Laidback Carputer
Laidback is offline   Reply With Quote
Old 09-24-2007, 04:31 AM   #6
Banned
eliza721 is an unknown quantity at this point
I think it's normal, sometimes it also happened to me
eliza721 is offline   Reply With Quote
Old 09-26-2007, 12:34 PM   #7
i dont think metal roof is the only cause the signal lost, there maybe something els
while im listening an AM radio with clear n clean reception then there're a tromendous amount of interference when approaching any gas station, i think this might also effect
and cause the gps signal lost, just my though
Old 10-08-2007, 02:18 PM   #8
jonessc's Avatar
jonessc is an unknown quantity at this point
the gps reciever should reaquire satellites within a few seconds...?
CarPuter Progress:
Planning:-----> [||||||||||] 100%
Hardware Buying:-> [||||||||||] 100%
Software:-----> [||||||||||] 100%
Installing:-----> [||||||||||] 100%
Current Project= Making skins in photoshop...
jonessc is offline   Reply With Quote
Old 10-08-2007, 04:40 PM   #9
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
personal experience pharos gps = garbage. I had two.. neither lasted a year after purchase. Got a BU-353.. its on my roof and rock solid no matter where i am.
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
Old 10-08-2007, 04:59 PM   #10
kbreeden
+1 on BU-353. My BU-353 is in my trunk, covered by a closed metal trunk lid, and it's still rock solid no matter where I am.
kbreeden is offline   Reply With Quote
Old 10-08-2007, 09:07 PM   #11
Marvin Hlavac's Avatar
Marvin Hlavac will become famous soon enough
For the past couple of months I've been using the same Microsoft/Pharos GPS-500 receiver without any problem. Mine isn't even on the dashboard close to the window, yet still works just fine (even at gas stations ). I suspect something else is at play here - perhaps something in your car is causing the GPS unit to not perform as it should. A metallic tint in the car's windows could reduce signal strength and make it more difficult to reacquire satellite fix. Interference from computer, LCD monitor, or other electronic equipment could cause the same. Chances are good that if you place the GPS receiver outside your car (at least for testing purposes) it will work just fine.
Marvin Hlavac is offline   Reply With Quote
Old 10-08-2007, 10:35 PM   #12
KryptonianJorel is an unknown quantity at this point
I don't have experience with your particular receiver, but I am a big hardware person, and this def sounds like a hardware problem. As said above, metals and even glass mess with the signal, kinda the same concept how wifi doesn't go thru cinderblocks. The metal tops of the Gas Stations probably cause the loss of signal, and your receiver cant reaccuire these signals easily.
I suggest: Check for a firmware update, try a different USB-to-Serial software driver, and lastly try a different receiver. I have a BU-353 crammed between 2 metal plates and it works great, so something must be up with your receiver.
The BU-353 is like $35 on ebay. I know you probably dont want to have to buy a new receiver, but its probably necessary
CarPC status:
[XXXXXXXXXX] 100% Complete
[XXXXXXXXXX] 100% Installed
[XXXXXXXXXX] 100% Software
CarPC v1.2 is now in effect. Software updates and hardware additions to come.
KryptonianJorel is offline   Reply With Quote
Old 10-14-2007, 10:48 AM   #13
problem solved
thanks all for your replies, after severals days of testing at exact locations i found that the usb reciver fail but the bluetooth worked the problem is if i plug direct to usb port on mobo it work fine , but it failed if run through non powred hub so i replace with a powered hub now it work fine almost every where
using OEM GPS signal for carpc met152 GPS 3 11-01-2006 07:34 AM
Cant get good GPS signal in car. Ricky327 GPS 8 01-29-2004 10:28 PM
I want to send the GPS Signal to the internet powertiger GPS 16 01-16-2004 11:02 PM
GPS signal strength - Haicom 202 GPS ChrisC GPS 0 01-12-2004 07:33 AM
FS: LCD Controllers - $90.00+shipping infrared Classified Archive 98 07-20-2003 09:30 AM
