The MP3car.com Store
Thread Tools Display Modes
Old 09-25-2007, 07:52 PM   #1
Phatsacks's CarPC Specs
Phatsacks's Avatar
Vehicle: 2007 Corolla S
My Photos: (0)
Holux GR-213 - Someone upload WinXP Driver?
Got the Holux GR-213 in a package deal off mp3car's classified section, but didn't receive the driver disk, and was expecting to be able to download from holux.
www.holux.com
www.holux-uk.com
and the others...aren't working
I did try the GR-210 drivers, and they seemed to work, but it's always best to use the proper drivers for most any device.
So if someone has them on CD, and could .zip (or any compression method), and upload them to say mediafire.com, I'd really appreciate it.
Thanks!
(wasn't sure if this was more appropriate under support software?)
Phatsacks is offline   Reply With Quote
Sponsored Links
Old 09-26-2007, 02:47 AM   #2
My Photos: (0)
both my globalsat and microsoft pharos used the same driver... basically a driver that assigns the usb to a virtual com port. Scroll down here http://www.usglobalsat.com/item.asp?itemid=60
Jae
ThurzNite is offline   Reply With Quote
Old 09-26-2007, 07:39 AM   #3
Phatsacks's Avatar
My Photos: (0)
So most likely the Holux GR-210 "driver" is the same then? I didn't bother installing it to avoid having to uninstall it. I'll check it all out now.
Thanks ThurzNite!
Old 09-26-2007, 01:26 PM   #4
Neither darque nor pervert
DarquePervert's CarPC Specs
DarquePervert's Avatar
Vehicle: 2003 Toyota Tacoma X-Cab
My Photos: (26)
It's just a USB-to-serial driver.
The Globalsat units (BU-353 for example) use the Prolific USB-to-serial driver.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 09-26-2007, 02:17 PM   #5
Phatsacks's Avatar
My Photos: (0)
Sounds good. I'll test it out tonight.
Old 09-28-2007, 06:05 PM   #6
Vehicle: 1993 prelude SI
My Photos: (0)
i have the disc if u still need it
just let me know and i will try and figure out how to upload lol
hondaluder is offline   Reply With Quote
Old 09-30-2007, 10:31 AM   #7
My Photos: (0)
I have the GM210 and GR213U both use the exact same drivers.
From the looks of the driver disk all models use the same "USB -V2.1.0.exe" 9-3-2004 driver.
236
236b
240
210
211
212
213
213u
230
239
Hope that helps.
Scruge is offline   Reply With Quote
Old 09-30-2007, 10:39 AM   #8
Phatsacks's Avatar
My Photos: (0)
Looks like I'm set then, I have the 210 drivers, and they seem to pull up a signal in my basement (sorta have a half window in sight).
Very impressed with the sirfIII after seeing that.
Thanks everyone!
(iGuidance 3)
Old 10-01-2007, 08:45 AM   #9
faichiu's Avatar
My Photos: (0)
You should try:
http://www.holux.com.tw
98 Honda civic
In-Dash LCD Monitor K-301
cappuccino EZ3
PIII-1.2GHZ
256MB PC133
40GB HD
Holux GR 213 Sirf Star III GPS
IguidanceV2
CNX-P1900 power supply
Sound Blaster Live USB
faichiu is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Holux GR 239 anyone tried it? Hindmost GPS 2 04-02-2008 03:11 AM
SD crashes on startup mangus580 StreetDeck 7 10-05-2007 11:14 AM
System Choices and Questions BoondockSaints Car Audio 85 08-09-2007 10:52 AM
Globalsat BU-353 vs. Holux GR 213 cheqmate GPS 2 02-26-2007 08:03 AM
Holux GPS 213 USB Gmouse receiver virginblue Classified Archive 0 08-15-2006 12:15 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
