Old 10-15-2007, 01:23 PM   #1
GPS randomly disconnects
I have noticed over the past few weeks that my GPS connection in iGuidance randomly disappears for a few seconds at a time while driving down the highway, local road, or anywhere else. It seems like the entire com port is disappearing because the car icon becomes white (indicating no GPS receiver) instead of red (indicating no satellites). Within 2-3 seconds, it picks back up and gets all 7-8 satellites that I had before. It typically happens not more than once every 15-20 minutes (if even that), but if I have Goops running of another port supplied by xport, it seems to happen more frequently. Is this an xport issue or is there something wrong with my GPS receiver (AyAy Sir Ti-GPS)? Thanks
hari-bhari is offline   Reply With Quote
Old 10-19-2007, 03:06 AM   #2
bump....
anyone having issues with their gps com port randomly disappearing for a few seconds and then coming back with full satellite again?
Old 10-20-2007, 10:00 PM   #3
I see dead kittens
Quattro's Avatar
what receiver are you using?
This happens to me all the time, it much more frequent for me then it is for you. I haven't figured out what the problem is.
I think it might be the receiver, I'm gonna get my cousins and test with that one.
Installed
Asus A7N8X-VM - AMD Mobile Athlon 2400
512 Ram - 60GB HD - Opus 150w
Lilliput 7" - Rikaline 6010
[00000000000001100010-] 98% Completed
Check Out My Install!!!
Quattro is offline   Reply With Quote
Old 10-20-2007, 10:14 PM   #4
i'm using an ayay sir ti-gps
Old 10-24-2007, 06:00 PM   #5
Evo
Evo's Avatar
I am having similar problems with a BU-353; but i noticed if you start SirfDemo and watch the debug view the data from the GPS mouse itself seems to stop flowing and then starts again. I read a post on MSDN which suggested that a windows update had caused some issue with USB-Serial drivers
I need to do more tests, but are these the symptons you guys are getting if you run sirfdemo?
Life moves fast, so don't get left behind, buy a fast car!
Evo is offline   Reply With Quote
Old 10-24-2007, 06:03 PM   #6
im not sure exactly what sirfdemo is... can you please explain? what you describe about the data stopping flow and resuming again seems right. anything we can do about the baud rate or something?
Old 10-24-2007, 09:10 PM   #7
I see dead kittens
Quattro's Avatar
I haven't tested with sirfdemo, but when I'm running xport, it shows the nema sentences at the bottom and it does exactly as you described. You will see data running and then it stops and then starts again.
I know it used to work perfect fine before, but I have since reformated my hhd twice and since then it has not works properly. I'm going to connect the receiver to a laptop and test as well and see if I get the same results or if it something to do with my computer.
Installed
Old 10-25-2007, 01:35 AM   #8
NiSlo's Avatar
Have you tried changing the baud rates? Both in your application and in the com port system in device manager.
I installed my carpc into my pet Kangaroo, mate.
NiSlo is offline   Reply With Quote
Old 10-25-2007, 01:39 AM   #9
so if i change it in device manager and in xport itll work? i tried changing it just in xport earlier and it didnt work at all..
Old 10-25-2007, 01:48 AM   #10
NiSlo's Avatar
I would change the baud rate in anything using that port.
- The com port itself
- Xport
- Iguidance
How to setup iGuidance GPS for RoadRunner MatrixPC RR FAQ 27 07-08-2008 11:34 PM
PPC Car GPS and MP3 mini How To hotrod_nut General Hardware Discussion 1 02-25-2008 02:24 PM
MS Streets & Trips 2007 w/ GPS Locator EQNish GPS 3 08-10-2007 05:03 PM
few gps questions fuctup GPS 2 03-02-2005 02:40 AM
