Old 10-26-2007, 12:02 PM   #1
XPort3 dont work ;-(
WinXP SP2 - Xport3 - Navilock Sirf3
I scan for the gps-port. xport find com6 with 4800 (or is the baud always 9600?).
i click on "enable ports", take com20 and com21. The radio-buttons on the left side are NOT checked (??).
I see data on the bottom of xport3, but there is no data on com20/21.
???? help
danyball is offline   Reply With Quote
Old 10-26-2007, 12:44 PM   #2
Fusion Brain Creator
2k1Toaster's Avatar
why are you using 20 and 21?!
If you are using with iGuidance for example, the COM cannot be greater than 9. I am sure most programs have a built in limited number of COM ports. Set it to something reasonable. I am sure you dont have 20 com ports.
Old 10-27-2007, 07:18 AM   #3
I can set com20 to my programs. But youre right... i will test it with lower-coms....
Old 10-27-2007, 08:07 AM   #4
The radio buttons on the left never show anything. Enable service is the only button that matters. If it's working all of the com ports you have selected will be grayed out and you'll see data scrolling below.
kbreeden is offline   Reply With Quote
Old 10-27-2007, 12:17 PM   #5
Now it works!!!! I took com8 and 9, and it works fine!! Thanks!
Quality of work BMVEE RR Skins 3 03-14-2007 08:38 AM
How to make Winamp TV Plugin work with RR ramez75 Road Runner 18 02-22-2007 04:35 PM
Prison vs Work ACHIEVER Off Topic 20 04-15-2005 01:53 PM
Stealthy surfing at work? e_z_street Off Topic 14 10-21-2004 07:02 AM
Will the Toshiba LTM10C021 (10.4") LCD work ok with an AD2 (standalone) controller? pooshda LCD/Display 4 11-18-2002 08:59 PM
