Old 10-30-2007, 09:40 AM   #1
doublet's Avatar
Problem with Xport 3 (serial ports)
The scan will not find any serial port on xport. I can select ports in the drop down boxes and enable them but it won't show up in device manager or gpsinfo scan. The only thing that showed up in device manager is COM1 and COM2. As for gpsinfo, when it gets to any port besides 1 and 2, the scan hangs or freezes. Please help.
02 Accord Coupe EX V6
doublet is offline   Reply With Quote
Old 10-31-2007, 09:31 AM   #2
doublet's Avatar
Anyone? I'm going out of my mind. I don't think it's my receiver (BR-355) because it's blinking red and it was still working right before I reformat the PC. It just not communicating with the ports. I checked the bios and device manager and the COM ports are enabled.
Old 10-31-2007, 09:35 AM   #3
SD beats everything. So there.
danielkh's Avatar
Silly question......did you go into the serial ports and change the baud rate to 4800? Also, are you going into the mouse/keyboard ps/2 connector or using a ps/2 to serial port converter?
danielkh is offline   Reply With Quote
Old 10-31-2007, 09:43 AM   #4
doublet's Avatar
Thanks for the reply. Yea I did change the baud rate for both COM ports to 4800 in device manager properties. I'm using a ps/2 to usb adapter. And I did install the prolific driver for it but nothing works. Unless I install the wrong driver but I'm pretty sure I have the right one.
Old 10-31-2007, 09:50 AM   #5
danielkh's Avatar
hmmmm.....which serial port emmulator did you use? It probably would not come up as com 1 or 2. If the emmulator is working it would probably come up as com 3-5 as 1 and 2 are the built in serials. Another thing to try is actually turn the serial ports off in the bios. See if the emmulator is coded for one them (1 or 2) and is competing.
In case I am reading this wrong, xport is not an emmulator. It splits the port AFTER the emmulator.
Old 10-31-2007, 09:52 AM   #6
doublet's Avatar
I have not tried an emulator since I didn't need it before the reformat. What do you suggest?
Edit: Wouldn't the driver convert the signal to serial? Then Xport will split up one of the COM ports? Or am I understanding this wrong?
Old 10-31-2007, 09:56 AM   #7
danielkh's Avatar
Unfortunately, I am not familiar with that particular GPS. I have an earthmate and microsoft. I'm doing some searching to see what I can find. Not sure how it could have converted usb to serial before. Wondering if there was something loaded that you don't remember. Still have the installation disk? See if there is a USB folder on the disk. It might have something there.
Old 10-31-2007, 10:05 AM   #8
danielkh's Avatar
Try unplugging the USB and plugging into another USB. See if and WHAT the computer is installing. Does the device manager show any unknown devices?
On the driver, again, I am not familiar with that GPS. And the only drivers I can find so far are for PocketPC. I'm not finding any windows drivers at all for that unit.
Old 10-31-2007, 10:12 AM   #9
danielkh's Avatar
Another silly question......what software (operating system) are you running? Seems there is something special for Vista.
Old 10-31-2007, 10:13 AM   #10
doublet's Avatar
I used the driver for my particular model on here: http://www.usglobalsat.com/custom.asp?recid=6 . Unfortunately, I don't have the installation disk anymore--it's been a while since I bought it. The device will show unknown device until I install the driver. I've been searching like crazy since yesterday but I can't find the answer.
Old 10-31-2007, 10:17 AM   #11
doublet's Avatar
I'm running XP, just like I was before.
Old 10-31-2007, 10:19 AM   #12
danielkh's Avatar
See if there is something here to help.....
http://www.usglobalsat.com/forum/forum.asp?FORUM_ID=5
Old 10-31-2007, 10:21 AM   #13
doublet's Avatar
I looked yesterday but I'll look again to see if there's anything related. I really appreciate your help. I'll post my progress as I go along. If you have any other suggestions, please let me know.
Old 10-31-2007, 10:29 AM   #14
danielkh's Avatar
Did you try this?
Same page you got the driver. Did you go through this? Also, until it works, I would disable your serial ports in the bios.
Old 10-31-2007, 10:34 AM   #15
doublet's Avatar
Hmm..honestly I haven't. Let me take a look, but I'm at work right now so I can't mess with the carpc. Will post back.
Edit: Well, that article didn't tell me much. The driver is correctly installed but I didn't see "Prolific USB-to-Serial Com Port (COM X)" under the ports drop down in device manager when I plug in the receiver.
Automatically connecting bluetooth serial ports? Confused PhoneControl 13 03-15-2005 04:40 AM
Epia M (900) and missing serial ports? slboytoy General Hardware Discussion 2 11-07-2004 07:48 PM
Problem with USB to serial converter openminds GPS 7 08-08-2004 05:50 PM
Bad Serial Ports on EPIA M9000 wi77iam General Hardware Discussion 6 05-06-2004 12:49 PM
FS: Add PCI Serial Ports to your system in seconds! dbinnc Classified Archive 1 01-07-2004 04:07 AM
