Old 10-09-2002, 07:44 AM   #1
Registered User
felix99's Avatar
Angry Pc rebooting while soft is connecting GPS :(
Hi,
i'm triing till 3 h to get this damn gps i bought to work. Everytime when i start navigation my computer reboots
Have GPS USB receiver winxp and travelbook .
Anyone having had same problem ?
Felix
=>> Carpc Version2 -- Epia M 10K based<<=
::Epia M10k,7"VGA/40GB2.5",GPS,Opus90W ::
::trying to build second low cost carpc::
::Automp3.de :: CAR= Renault Clio2 - 2 seats 1.9D
felix99 is offline   Reply With Quote
Advertisement Sponsored links
Old 10-09-2002, 01:36 PM   #2
Registered User
felix99's Avatar
tried to log with hyperterminal: my record 6min before rebooting- after disabling the auto reboot option of winxp i got a blue screen saying BAD_POOL_CALLER
google says => mosty grafic card problems - but what the H*** has my gps to do with my grafic card ?
Any solution - working on it since approx 9 h - no success -
Fx
Old 10-10-2002, 10:02 PM   #3
DodgeCummins's Avatar
WinXP uses ports differently than win98. I would look up your software and make sure it is WinXP compatible...also there maybe a hardware driver patch for the GPS.
current projects
DodgeCummins is offline   Reply With Quote
Old 10-11-2002, 02:40 AM   #4
Registered User
felix99's Avatar
Hi, Thanks for your answer.
what i recently did to check out:
- made new install on other hdd => same error
- installed it on my homepc(also XP) -=> works fine
i have a special xp driver - ( its called host bridge - just to give a virtual com port to usb gps )
Now my last chance is a USB PCI card - it it won't work i have 2 possibilitys - change the mainboard and buy a new one [too expensive]
or try to change the gps in a normal com-port one. [depends if the seller wan't to]
Regards felix
Old 10-12-2002, 12:28 PM   #5
Registered User
felix99's Avatar
Finally got it working! but tested only on my new test install HDD . will port the config tomorrow.
so the why and who of the story :
who ? the damn onboard usb was the bad guy in this story - know i have a pci USB card and it works ( when i disable internal onboard usb )
why - don't know because my DAP jukebox worked fine on the onboard usb - probably because i only connected the datapins because jukebox connected to my front panel doesn't need any current.
so i hope it will work on the other install tomorrow
I posted this reply to help people with same prob's in future .
felix
Old 10-24-2002, 12:00 PM   #6
Registered User
felix99's Avatar
Finally got serial Receiver and all is working now
Think I'll never know why I had the probelem with this damn USB GPS receiver
Felix
If you ahve the same problem - try to get a serial gps !
